4WD Low
Discussion in 'Off-Roading & Trails' started by EGtaco, Apr 9, 2009.
  1. Apr 9, 2009 at 5:07 PM
    EGtaco
    EGtaco [OP] Well-Known Member
    2009 Tacoma
    Since I really dont know the answer I thought someone here could enlighten me. What exactly does 4wd low do compared to 4wd high??? I know you have to go SLOW when engaged in low but why??? Does it lower the gears or something.
    They only time I have ever used 4wd low was in a jeep and I was stuck in sand on a beach. I tried everything and eventually stuck it in low and was able to climb out. Was I just lucky or was it because lowering the drive really does something special.
  2. Apr 9, 2009 at 5:10 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    To engage it you must be on a surface that would allow the tires to slip a little. It make yout engine work in low range and puts out MUCH more low end power. It is ONLY for low speeds
  3. Apr 9, 2009 at 5:39 PM
    DanGer
    Yes i meant to include that. The part you quote, i mean that if you engage 4WL on asphalt or concrete you can cause some damage.
  4. Apr 9, 2009 at 5:40 PM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    When I have my truck in 4-Lo, it beeps like crazy. Pisses me off.
  5. Apr 9, 2009 at 5:42 PM
    ajviper7
    ajviper7 Well-Known Member
    FL Panhandle
    08 silver TRD OR 4x4 AC
    Then you don't have it engaged properly.
  6. Apr 9, 2009 at 5:46 PM
    DanGer
    If you have a manual the clutch has to be ALL the way depressed. Its easy to not depress it with how high it engages
  7. Apr 9, 2009 at 6:00 PM
    311offroad
    311offroad Stock Taco For Now
    Milledgeville, GA
    2005 TRD OffRoad SR5 4x4 Short Bed Debadged
    20% tint, Debadged, Pioneer AVIC-Z110BT, Infinity component door speakers, MagLite mod
    I sometimes have to move the switch to 4lo, bak to 4hi, then bak to 4lo again to get it to engage... same with disengaging.
    but once its in 4lo, you will know! super slow 1st gear and jerky shifts (auto tranny)
  8. Apr 9, 2009 at 6:04 PM
    DanGer
    x 56000903459i034 with a manual
  9. Apr 9, 2009 at 6:15 PM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    i have found that the more i use 4lo, the easier it engauges. ditto with the locker.
  10. Apr 9, 2009 at 9:14 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Yea i dont have 4x4 but when I first started using my locker it was sometimes hard to get it to engage. But the more I use it, the easier it engages. It engages pretty quick now.
  11. Apr 10, 2009 at 4:04 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    4lo is a different type of gearing (inside the transfer case). You'll notice the truck rpm's are much higher and your speeds are lower.
    4lo is perfect for offroad situations involving obstables you have to climb over, hill decents, hill climbs and anything that involved crawling (but does not involve needing momentum). Around here in PA - that's all we use while offroad, if 4lo.
    You have to be stopped completely to engage it. You have to put the truck in neutral before it'll go into 4lo (atleast, on my truck).
    It's the same overall function as a Jeep in 4lo.
  12. Apr 10, 2009 at 5:30 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    Especially use 4WD Lo when you have a manual transmission and a heavy load on a steep incline. If you have it in 4WD Hi and let out the clutch not just right your smell in frying but in 4WD Lo it crawls right up with no problems. Something I learned when I was young and dumb.
  13. Apr 10, 2009 at 8:32 AM
    TL697
    TL697 Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
    Technically, you can use 4LO on hard surfaces as long as you are moving in a straight line...
    The binding doesn't occur until you start turning...
    I use 4LO on boat ramps... I've used 4LO to pull out shrubs and trees... I've pulled people out of the ditch in 4LO with my truck on dry pavement...
  14. Apr 10, 2009 at 9:47 AM
    FL Forester
    FL Forester Well-Known Member
    Tallahassee, FL
    2016 4Runner
    You have to let the truck engage in 4hi before you can go to 4lo.
