4wd maintenance?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bmw2Taco, Nov 17, 2018.
  1. Nov 17, 2018 at 4:46 AM
    Bmw2Taco
    Bmw2Taco [OP] Well-Known Member
    2018 Blue 4x4 TRD Sport Premium
    New 18 DCSB 4x4 AT sport. 4k miles. How do I, for the lack of a better term, "maintain" the transfer case and components? My miles are all road/highway, so do I need to periodically switch to 4L and 4H to keep everything lubed up? What's the process? Periodic top speed and distance for each?
    First time truck owner...
  2. Nov 17, 2018 at 4:52 AM
    smikski
    smikski Well-Known Member
    2016 4x4 2.7 - 3 pedals
    skid plates , leer cap , thule roof rack , tires 1 size up
    read manual it will tell you
  3. Nov 17, 2018 at 5:01 AM
    Bmw2Taco
    I had a feeling I was going to get the ol...."RTFM"
    stealthmode likes this.
  4. Nov 17, 2018 at 5:42 AM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    10 miles per month in 4wd. If on pavement or hard ground go straight, no sharp turns. Otherwise, find some mud or sand and do some donuts.
    If the latter, post video here.
  5. Nov 17, 2018 at 6:39 AM
    BSFord
    BSFord Well-Known Member
    2018 TRD Sport 4x4
    Clazzio PVC Seat Covers Dashcam install TRD Pro Grill MESO Total Tail Stage 1 Tailgate Lock vled total interior light upgrade TRD Pro Shift knob N2 Designs Autostart w/ smart phone module
    Personally I dont buy the 10 miles per month, unless you would never use it otherwise. Driving in 4x4 on dry pavement is a big no-no (even says not to do this in the manual"
    You're fine if you only use it when you need 4x4. My opinion.
  6. Nov 17, 2018 at 6:45 AM
    smikski
    why have a manual by engineers ? what do they know
  7. Nov 17, 2018 at 7:40 AM
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    Honestly is easy enough to switch into 4wd once a month or 2. I would try to only because the actuator takes a month of sundays to engage even when new. Cant imagine how long if it seizing or stiff. Unless Im going slow or go into reverse the 4WD light just flashes forever. You need to put this thing into 4wd before things get hairy, otherwise you're screwed waiting for it to engage. And I use mine more than their recommended mileage and have only 2800 miles and find the engagement time extremely long going into 4H. 4L seems easier only cause I am stopped and can go back and forth to get it to lock in. Just think its, finicky in these things regardless
  8. Nov 17, 2018 at 7:53 AM
    Trail Limo
    Trail Limo Well-Known Member
    That manual was not written by engineers. Trust me you don't want a manual written by engineers :pccoffee:. Your head would do this:violent:. Lol
    That being said read the manual for maintenance. The people that wrote it know what they are talking about. It will give you much better information than a bunch of guys on a forum
    tcjacado likes this.
  9. Nov 17, 2018 at 7:55 AM
    Markc1024
    Markc1024 Well-Known Member
    I'll engage 4H for a bit every month or so, but just on straight roads and moderate speeds. Which ever side of the debate you're on, for those not familiar with traditional 4WD it's beneficial to get a feel for engagement/disengagement on your vehicle. As noted, you don't want to find yourself in need and not know what you're doing or with a system problem.
  10. Nov 17, 2018 at 7:56 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Absolutely no issues engaging 4WD on dry pavement when driving in a straight line for a mile or so, which is easy to do if you have a straight stretch of road near you. Those who tell you otherwise don’t understand how 4WD works.
  11. Nov 17, 2018 at 8:01 AM
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    What you don't want to do on dry pavement is have your diff locked and turn. That's how you get driveline wind up, which is bad news.
    Just driving in 4wd with open diffs is no big deal.
    (Case in point, Land Cruisers used to be full time 4WD)
  12. Nov 17, 2018 at 8:24 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    After a dry period and then getting a good dose of rain I am very mindful of slick roads. That reminders me to use 4Hi briefly on a straight road. Not scientific, but it works for me.
  13. Nov 17, 2018 at 8:31 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    There’s a big difference between a full time AWD with a center differential (land cruisers, land rovers, etc) and our 4WD system. We don’t have the center diff which means our front and rear axles don’t have the ability to spin at different speeds like those AWD vehicles and limits our use of 4WD.
    lowtiderides and Boxerocks like this.
  14. Nov 17, 2018 at 8:39 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    I have had three 4WD Tacomas (2001, 2005, 2010) and although I use 4WD a lot, not always every month...
    I also forget to do the 10 miles a month maintenance. However, I strongly agree that you should use the 4WD monthly and driving 4WD on pavement is not a problem unless you turn sharply when binding of the tires against pavement happens (the front tires combined turn more than the rear combined). Naturally, it would be better on rainy or snow days.
    If you have a dirt field, all the better and do go into L4 (low range) and also engage the rear locker if you have the Off Road TRD.
    Using these things will make it easier for the gears, and for your mind to use these things if you should really need them!
  15. Nov 17, 2018 at 9:10 AM
    TRDCal
    TRDCal Well-Known Member
    Canada
    2018 DCSB Sport MT
    Engaging the 4HI and LO periodically will also keep the actuators from seizing up on you. Change the oil in the transfer case and differentials as well to maintain your 4WD system, mileage intervals will be in the maintenance schedule.
  16. Nov 17, 2018 at 9:19 AM
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    What scenario on dry pavement with all of your wheels on the ground would result in your axles not spinning at the same speed?
  17. Nov 17, 2018 at 9:23 AM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Turning. That’s why a 4WD without a center differential binds up. The front and rear axles are traveling different distance arcs in a turn and must rotate at different speeds.
    abhamber and Boxerocks like this.
  18. Nov 17, 2018 at 9:32 AM
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    Turning is handled by the diffs on the axles themselves though. The axle itself is split by the diff so the wheels can turn at different speeds. That's why driving around with your diffs locked and turning is bad, but that should have no impact on your center driveshaft.
  19. Nov 17, 2018 at 9:35 AM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    In 4WD your axles are locked together through the transfer case. It’s functioning similar to a locked differential in the axle itself except that instead of locking the two wheels into a single rotational speed it locks the axles into a single rotational speed.
    AWD systems have have a center differential that transfers power from the transfer case to the individual axle differentials. That allows the front and rear axles to rotate at different speeds as needed. The center differential in some can be locked which then acts just like our trucks in 4WD.
  20. Nov 17, 2018 at 9:40 AM
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    That's all true *if you lock both front and rear diffs*. If your axle diffs are open, the wheels will spin at different speeds (like when you're turning) no problem. That's the whole point of a differential. All the transfer case/center diff is doing is ensuring that equal-ish power is going to both front and rear axles, and the diffs do the rest.
