4WD monthly exercise
Discussion in '3rd Gen. Tacomas (2016-2023)' started by salamihater, Mar 8, 2024.
  1. Mar 8, 2024 at 5:23 PM
    salamihater
    salamihater [OP] Well-Known Member
    MA
    Toyota recommends driving at least 10 miles a month in 4wd to keep everything lubricated and in good condition. They also state that 4wd should only be driven in conditions that allow for the wheels to slide, (sand, gravel, snow/ice) and not to make any sharp turns. I live in a densely populated area so there are sharp turns all over the place and all the roads are paved and dry a majority of the time.
    How do you fellow city folk manage to exercise your 4wd according to Toyota's recommendations? Also, they dont mention 4H or 4L or both. It doesnt feel right to me to be driving around in 4L for extended periods of time. Am I over thinking this?
    Should I just grab a coffee and take it for a spin in 4H, turn around and come back in 4L on a Saturday morning once a month and not stress about the 90 degree turns?
    9pm and Stevie17 like this.
  2. Mar 8, 2024 at 5:24 PM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Find a straight section of road. Do a mile or two at a time
  3. Mar 8, 2024 at 5:25 PM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    4h is adequate. Fairly straight road is best. Dry pavement is ok as long as no sharp turns
    musicisevil and Stevie17 like this.
  4. Mar 8, 2024 at 5:25 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    you can drive straight (or mostly).
    Also find a gravel lot or park road. If you can't find this,,, move.
  5. Mar 8, 2024 at 5:45 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    As mentioned, driving straight on dry pavement is fine, but it’s much more fun to take it outside the city or do some urban wheeling during snow storms or in construction parks.
    Use it or lose it.
    CherylJane, Stevie17 and Donniet53 like this.
  6. Mar 8, 2024 at 5:48 PM
    Donniet53
    Donniet53 Member
    2023 SR5 4x4 Blue crush
    I also on a YT video to stay under 60 miles per hour.
    CherylJane likes this.
  7. Mar 8, 2024 at 5:51 PM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    In 4hi you can go as fast as you want. I've been up to 85mph in 4hi in my Tacoma, the only thing you hurt is your mpg
  8. Mar 8, 2024 at 5:51 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Northern climates have entered the chat
    CherylJane, TACOTU3, b_r_o and 6 others like this.
  9. Mar 8, 2024 at 5:52 PM
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    Don't do turns in 4hi and 4lo on dry pavement. Just drive up a straight road in 4hi and switch it back to 2wd to turn around l..same goes with 4lo
    You can do turns on snow, ice, dirt and gravel tho no worries
  10. Mar 8, 2024 at 5:55 PM
    OpeCity
    Long Beach, CA
    If the conditions are such that 4wd is necessary, you probably shouldn’t be going faster than 60 anyway
    -former upper midwesterner
  11. Mar 8, 2024 at 5:59 PM
    Donniet53
    Donniet53 Member
    Gotcha, I was just referring to the Car care nut video.
  12. Mar 8, 2024 at 6:03 PM
    ssd2k2
    Keith
    Minnesota
    For me it's when I drive through a snow storm on the freeway and once I get out of it I forget to turn off 4hi.
    Always drive a safe speed for the conditions, just know speed doesn't hurt the 4x4 system. Binding the gears when turning is what will break parts.
    TacoManOne likes this.
  13. Mar 8, 2024 at 6:17 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Straight lines in 4X4 are theoretically OK. But I'd still keep the distances VERY short. Like back and forth in the driveway. Personally, I'd not take it out on the road in 4X4. There isn't any place where I live to drive in a straight line on pavement for 1/4 mile. And there is always the chance you get distracted, forget you're in 4X4 and pull into a business or at an intersection.
    Even doing that isn't going to cause a catastrophic failure. Everyone who has ever owned a 4X4 has had something like that happen. But the more time you spend in 4X4 on dry hard surfaces the sooner you're going to wear out expensive parts.
    I've been participating in multiple truck, SUV, and 4X4 forums for almost 20 years, I've owned 4X4's for almost 50 years. Virtually every time someone is having problems with 4X4 it can be traced back to operator error. Either they didn't use it regularly and it no longer works, or they used it improperly and parts are broken. If used the way it's supposed to be used you should NEVER have parts break. A truck with 200,000 miles on it probably doesn't have 5000 miles on the 4X4 components. If you do it right it won't break in that few miles.
    The 10 miles/month isn't carved in stone and no one said the 10 miles had to be all at the same time. The shooting club where I shoot is 1 mile down a gravel driveway. I shift into 4X4 every time I go and get in 2 miles each time. From Sept. to Jan. I'm on dirt/gravel roads on a regular basis and may get in 200 miles some months. The rest of the year far less often and I skip a month occasionally. The key is just use it regularly and you won't have issues.
    You lubricate everything in 4hi. But it's a good idea to shift into 4lo occasionally even if you don't drive it anywhere but back and forth in the driveway. You're also keeping electrical connections from corroding.
    You bought a 4x4 for a reason. Sounds like you need a road trip to the country a few times a year and get some mud on the tires.
    Pinatacoma likes this.
  14. Mar 8, 2024 at 6:23 PM
    530Taco
    530Taco Gone fishin'
    Adam
    Old Hangtown, CA
    '21 DCSB OR MT Cement
    musicisevil[QUOTED] likes this.
  15. Mar 8, 2024 at 6:27 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Y’all gotta move to California! We love exercising our four-wheel-drive in the backyard!:bananadance:
    9pm, Phlogiston and musicisevil like this.
  16. Mar 8, 2024 at 6:27 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I put it in 4Hi on a straight road after a first rain following a dry spell. That is when roads can be slick. Also, I change my Diff and Transfer Case fluid sooner than later.
  17. Mar 8, 2024 at 6:51 PM
    musicisevil
    Alaska
    2019 TRD Sport
    That’s fine. Always drive at a speed you are comfortable with and able to maintain control of the vehicle. Just do it in the right hand lane.
  18. Mar 8, 2024 at 6:59 PM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    There is a trailhead west of Maricopa AZ. 12 miles west, then 2 miles pavement north, then 8 miles on dirt roads that need high clearance at least and 4WD recommended for the sandy portions.
    AZ has hundreds of miles of sketchy dirt roads that are used as primary travel paths. I love driving the "Primitive Road ... Travel at Your Own Risk" roads.
    I was going to Imperial Sand Dunes Recreational Area (from PHX) after the yobbos are done making life unpleasant and the fee disappears after April 15 ... DM and we can play in the big sandbox!
  19. Mar 8, 2024 at 7:10 PM
    OnHartung'sRoad
    We also go into Arizona, there’s some great places there. Thanks for the invite, but we’re kind of the type that like going solo, and often find entire valleys to ourselves.
    What I really like about all that public land we have out west to explore in is that it’s free, well, at least tax wise, they’re pretty cheap for us to enjoy while exercising our four-wheel-drives!
    Phlogiston likes this.
  20. Mar 8, 2024 at 7:13 PM
    RichochetRabbit
    AMEN to public lands that stretch to the horizon. North Carolina is not as uncivilized hillbilly as some may advertise ... either privately owned or strip-malled or neighborhoods.
    I moved to PHX for a reason ... open space. And my next move will likely be west Las Vegas to be only 2 hours from DV.
    Keep wandering, friend. :cheers:
