4wd nightmare
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fantino, Sep 23, 2020.
  1. Sep 23, 2020 at 4:57 PM
    Fantino
    Fantino [OP] New Member
    New parts:
    Front diff actuator
    Transfer case assembly
    Swapped known good- 4wd ECU and 4wd switch.
    2015 Tacoma when switched to 4 wheel drive the driveshaft from transfer case engages as does the front axles, however my 4wd light continuously flashes like it hasn't engaged. When going back to 2wd the light continuously flashes and will not disengage until truck is shut off and turned back on. Have tried turning truck off and back on with switch in 4H but the light still just flashes. The only component left I suspect is somewhere in the harness?
  2. Sep 23, 2020 at 7:40 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Or the indicator switches for the transfer case and ADD.
  3. Sep 23, 2020 at 7:42 PM
    Fantino
    Transfer case came with new switches
  4. Sep 23, 2020 at 7:44 PM
    ShimStack
    Ben
    NC
    Doesn't mean it works. Techstream would be beneficial to let you know what indicator isn't indicating the proper state.
    b_r_o likes this.
  5. Sep 23, 2020 at 7:49 PM
    Fantino
    What is it under on techstream?
  6. Sep 23, 2020 at 8:11 PM
    ShimStack
    Ben
    NC
    The 4wd ECU should have the state of the dash switch and the state of all the indicators. Look for any indicators that don't match the state requested by the switch. Start there.
  7. Sep 23, 2020 at 10:35 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Take voltage readings at the 4wd ECU once it’s locked into 4wd and report back. There will be a simple answer to your woes.
    TnShooter likes this.
  8. Sep 24, 2020 at 4:30 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  9. Sep 24, 2020 at 4:32 PM
    TnShooter
    Deogee
    STOCK
