4WD Noob - First Impressions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SManZ, Feb 1, 2010.
  1. Feb 2, 2010 at 5:29 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    Only when the rear diff is locked, otherwise ATRAC functions up to approximatly 30 mph
    No throttle intervention in 4H.
  2. Feb 2, 2010 at 5:32 PM
    OutbackHack
    OutbackHack Well-Known Member
    Golden, CO
    2014 DCLB Heavy
    Going out to play now around chantilly/centreville. There's probably not enough on the ground yet, but by tomorrow the plows and traffic will have ruined it.
  3. Feb 2, 2010 at 5:46 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    My sig. has 9 modes ??? , numbered 1-9 even...
  4. Feb 2, 2010 at 9:46 PM
    Pyrite FD
    Pyrite FD Well-Known Member
    Indiana
    09 DC TRD Off Road
    didnt not know that about a-trac. seems kind of unpractical to have to unlock the rear to get more traction... Ill have to try that out and see how well it funcitons.
    and yes, i mistyped that part about 4H.
  5. Feb 2, 2010 at 9:49 PM
    Pyrite FD
    Indiana
    09 DC TRD Off Road
    how is that 9? i have bolded 7, where are the other 2 then?
  6. Feb 2, 2010 at 9:53 PM
    Pyrite FD
    Indiana
    09 DC TRD Off Road
    Actually, maybe you just dont have it in your 7 listed, but there is also rear locked in 4L, and rear locked + Atrac in 4L.
  7. Feb 3, 2010 at 3:27 AM
    SManZ
    SManZ [OP] Sold the Taco in June 2020
    Fauquier County, VA
    Current, 2020 Ford Super Duty Tremor, Previously 2010 Supercharged 4x4 Tacoma Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    Good to know we got some TW members close by! Furrfax represent!
    Pyrite, thanks for your clarifications. 4H with the goodies turned off is one mode I didn't try yet. Last night I did get use 2H Auto-LSD more and found that it actually isn't as useless as 2H. Its not anywhere near what 4H can do but I did find that VSC turns off and on by itself at the 35 mph mark like you wrote but Auto LSD stays on the entire time. I like that :)
  8. Feb 3, 2010 at 6:11 AM
    David K
    I wonder why you don't see the same thing as I do? Here is a copy and paste of the signature, as I see it under all my posts:
    1) 2WD: VSC and TRAC active.
    2) 2WD: Switch turns off 'TRAC' and 'VSC', and turns on 'AUTO LSD'. Gives maximum power to tire with traction by braking spinning tire, without cutting power.
    3) 2WD: 5 second push of switch turns off VSC, TRAC & AUTO LSD, for free spinning of tire.
    4) 4WD-Hi (H4): VSC and TRAC are both on. No engine power is cut in TRAC while in H4.
    5) 4WD-Hi: 5 second push of switch turns off VSC and TRAC. This allows spinning of tires.
    6) 4WD-Lo: VSC and TRAC are both normally off.
    7) 4WD-Lo: Push of A-TRAC button activates A-TRAC, forces power to the wheels with traction by braking the spinning wheels. NO power is cut in A-TRAC.
    8) 4WD-Lo: RR DIFF LOCK gives equal power to both back wheels. Open diff. in front.
    9) 4WD-Lo: RR DIFF LOCK and A-TRAC activated makes the front differential limited slip. 5 MPH limit.
  9. Feb 3, 2010 at 7:26 AM
    Pyrite FD
    Indiana
    09 DC TRD Off Road
    wierd. this is what I see. maybe its just me :confused:
  10. Feb 3, 2010 at 7:27 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    22 JLUR 6MT
    I see the same thing as you.
  11. Feb 3, 2010 at 8:00 AM
    David K
    That is strange??? I reduced the size so it would fit per the limit allowed for a signature... and I see it, and nobody else made a comment that they see only 7 of the nine...??? I guess I will edit it and really try and shorten it more.
    Thank you!
  12. Feb 3, 2010 at 8:02 AM
    rmd0311
    rmd0311 Well-Known Member
    Dutchess County, NY
    2010 Mag Gray TRD Sport
    OP., your new truck looks awesome... I'm so glad that whole situation got resolved and you are this happy with your new vehicle....
    The vid looks nice... I wish I could something like that, no snow to do it though. Us here in the Hudson valley in NY have seen close to no snow this year.
  13. Feb 3, 2010 at 8:09 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    I tried donuts in 4hi
    My daughter had a blast, as did I.
    I did a little 'muddin' on a local path and I left after the muck was just at the door. A few others had bigger trucks and stayed a while longer.
  14. Feb 3, 2010 at 9:07 AM
    David K
    I edited my signature somewhat... Hope you all can see the 9 modes now...
    Here is another way of explaining the drive modes, I posted in the Tech. forum.. edited today:
    Another way to word the drive mode selections:
    Normal Mode (no pressing of switches):
    2WD (H2): TRAC & VSC on. TRAC (Traction Control) uses brakes and regulates engine output to achieve LSD (Limited Slip Differential action). VSC (Vehicle Stability Control) keeps truck moving where desired, on slippery roads
    4WD (H4): TRAC* & VSC on (*engine output not regulated)
    4WD (L4): (no trac, no vsc)
    Short press of VSC OFF switch:
    2WD (H2): AUTO LSD on (no trac, no vsc)
    4WD: no change, from above
    Long press (hold 3 seconds) of VSC OFF switch (when stopped) for OPEN Differential(s):
    2WD (H2): All off (no trac, no vsc, no auto lsd)
    4WD (H4): All off (no trac, no vsc)
    4WD (L4): no change (no trac, no vsc)
    Press A-TRAC (Active Traction Control) switch:
    4WD (L4): A-TRAC on (provides the advantages of TRAC or LSD while in Low Range 4WD). Unless pressed again, A-TRAC will always come on when shifted into L4, from now on.
    Press RR DIFF LOCK switch:
    4WD (L4): Locks the rear differential. Can be used with or without A-TRAC activated. A-TRAC only active to 5 mph with the rear differential locked.
  15. Feb 3, 2010 at 12:03 PM
    #35
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Glad to see you are finally enjoying your truck, and not fighting with a dealership about it! :thumbsup:
    Last time I did donuts I had my nephew and niece in the truck, My nephew loved it, my niece...not so much!
  16. Feb 3, 2010 at 6:08 PM
    #36
    KaBaL
    KaBaL Well-Known Member
    Northern VA (NOVA)
    2017 ORDC 4x4 White
    Brand spanking new...
    Who's up for playing this weekend after the 20" of snow drops! :)
