4WD Not Working...
Discussion in '1st Gen. Tacomas (1995-2004)' started by tjg146, Nov 12, 2015.
  1. Apr 21, 2023 at 9:25 PM
    #61
    Cattywampus
    Cattywampus Splitter of CV Boots
    Mark
    Colorado
    '03 Tacoma DC TRD OR
    In addition to the position switches like you tested above, the controller receives signals from both the transfer case actuator limit switch and the ADD actuator limit switch. If the limit switch signals are faulty it can cause faults with the 4WD ECU and prevent the 4WD switch.
    The limit switches are located in the actuator itself (the 6 pin connector). Depending on the actuator position the limit switch connects certain pins to ground. I’ll see if I can find a troubleshooting table in the Tacoma FSM that indicates which pins are grounded in each state.
    NewToTheScene[QUOTED] likes this.
  2. Apr 21, 2023 at 9:56 PM
    #62
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Good point. Limit switches can be jumpered from the back of the connector.
    NewToTheScene and Cattywampus like this.
  3. Apr 21, 2023 at 10:03 PM
    #63
    Cattywampus
    Mark
    Colorado
    I wasn't able to find the transfer case actuator test procedures for the tacoma's transfer case. However, I attached one from the 4runner which has a similar pinout and might be helpful. I also found a test procedure for the A.D.D.
