4wd not working
Discussion in '1st Gen. Tacomas (1995-2004)' started by ahgalaga, Dec 23, 2016.
  1. Oct 5, 2019 at 10:22 AM
    SierraMare
    SierraMare Well-Known Member
    Ted
    Alaska
    2001 TRD OffRoad Xtracab, stepside bed, 2.7 L, 5-speed manual
    ARE cap, BFG KO2 (LT 245/75R16), Front Bilstein 5100 with OME 2881 coils, Rear HS 3-leaf progressive AAL.
    I had a similar problem with my rear diff lock. Check out this thread- https://www.tacomaworld.com/threads/e-locker-actuator-troubleshooting.613739/
    I had the same result as described in post #9- a bad ground that was fixed by doing the grey wire mod. Happy camper now with a working rear diff lock.
  2. Oct 5, 2019 at 12:47 PM
    Sogoku19
    Sogoku19 Well-Known Member
    03 Tacoma (black)
    Hey I want to slip in here as long as y’all promise not to laugh. I’ve got an 03 4wd and I didn’t know there was a button. I thought you just put it in neutral and shifted to 4wd. Is this not right?
  3. Oct 5, 2019 at 12:52 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    There's a button for the 2-4 push button transfer case and no button on the j-shift transfer case.
    Sogoku19 likes this.
