4wd not working
Discussion in '1st Gen. Tacomas (1995-2004)' started by kp7887, Jul 8, 2025 at 5:01 PM.
  1. Jul 8, 2025 at 5:01 PM
    kp7887
    kp7887 [OP] Member
    kacetin
    2004 toyota tacoma trd
    I have a 2004 tacoma push button 4wd, looking to replace the transfer case or the transfer case actuator. Which is easier and or cheaper?
  2. Jul 8, 2025 at 5:17 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Actuator 1000%
    t0p_d0g and mrlittlejohn like this.
  3. Jul 8, 2025 at 5:18 PM
    Red_03Taco
    Jerad
    Are you certain that the transfer case or actuator are your problem?
  4. Jul 8, 2025 at 6:16 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Have you done any actual troubleshooting? Check wiring first?
    t0p_d0g and TnShooter like this.
  5. Jul 8, 2025 at 7:14 PM
    foresterfields40
    foresterfields40 Well-Known Member
    ‘99 Tacoma 3.4 4x4
    Is this a serious question?
  6. Jul 8, 2025 at 7:36 PM
    kp7887
    kp7887 [OP] Member
    kacetin
    Yes, we’ve already replaced the add and the 4wd ecu don’t know what else it would be
  7. Jul 8, 2025 at 7:39 PM
    kp7887
    kp7887 [OP] Member
    kacetin
    Not sure how to check all the wiring correctly.
  8. Jul 8, 2025 at 8:13 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    1. Does the diff(ADD on this year?) or tcase/actuator attempt to function, can you hear it?
    2. Check fuses related to 4wd, 10A Gauge, 20A 4wd
    3. Do a visual inspection, are the components and wiring intact as far as you can see
    4. Can you follow a wiring diagram and check for power and grounds?
  9. Jul 8, 2025 at 8:19 PM
    kp7887
    kp7887 [OP] Member
    kacetin
    When i bought the truck I shifted into 4wd twice and the second time the 4wd light started blinking. Visually all of the hookups look perfectly fine I will check fuses, the front diff add has been replaced a month ago.
  10. Jul 8, 2025 at 8:26 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Replaced doesn't mean it works and was done correctly, worth double checking any connectors are plugged in completely.
  11. Jul 8, 2025 at 8:30 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Here's the manual page for the wiring
    kp7887[OP] likes this.
  12. Jul 8, 2025 at 8:31 PM
    kp7887
    kp7887 [OP] Member
    kacetin
    I personally replaced it myself was a pain but it was done correctly.
    Sandman614[QUOTED] likes this.
  13. Jul 8, 2025 at 8:44 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    Schematics and testing components before buying parts. Cheers!
    Sandman614 likes this.
  14. Jul 8, 2025 at 8:46 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Put it in 4H while light is blinking shift to neutral then reverse and back to drive. Do all this while idling with foot on brake.
