4wd on dry pavement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by C4rat, Apr 16, 2021.
  1. Dec 28, 2022 at 4:35 AM
    #41
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
  2. Dec 28, 2022 at 12:52 PM
    #42
    SSgt spike
    SSgt spike Well-Known Member
    Forsyth County Ga.
    2009 Tacoma TRD sport SR5 extended cab 4.0 6 speed
    Bull bar, 4" lift with rough country shocks FN TRD PRO wheels, MBRP XP SS cat back exhaust P 265-70-17 Goodyear Wrangler AT tires and 20" 240-watt LED light bar
    Your truck will be fine. It’s a Toyota they make noise . Just don’t make it a habit. When you make tight corners locked in 4x4 on dry pavement you will break something expensive.
  3. Dec 28, 2022 at 7:55 PM
    #43
    Williston
    Williston Unknown Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a couple of non-OEM nods.M mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    Re: When to use 4WD: I got caught in an ice storm in Central Maine in an '89 S10 Blazer heading north on I-95 one time somewhere near Brunswick heading to the Skowhegan area. Having 4wd kept a 4 hour trip from turning into a 10 hour trip. The road surface was glazed over. Every time I "experimented" and tried switching back to 2H, the rear end would swing right out. I finally saw the light and left it in 4H. Traffic stopped most of the time and way.
    I came up to a Maine DPW truck stopped on the median, rolled down the window, and asked him if he or anyone else would object to a U-turn on the median to reverse south and pick up Route 1 North next to us. (which basically didn't have a soul on it) "Nope!" God Bless the State of Maine. Off we went. Made it to the destination in about 5 more hours. 1:00 AM. (original ETA was 8:00 PM) My buddy was up and had the coffee and "other top-shelf selections" waiting. I elected for the "other selections".
  4. Jan 2, 2023 at 12:30 PM
    #44
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    Interesting phenomenon here in the southern BC Interior is that we have cold winters (down to the minus 20s Celsius, so a bit below 0F) but open rivers and lakes year round. This is partly because the rivers are big and partly because flow is maintained for electric power production. Anyway, what that means is it's common to have moisture from the river condense and freeze on adjacent highways, so roads can be icy in some areas even if it hasn't snowed for a few days. That means switching to and from 4WD on the highway is commonly required, especially if you are going uphill. I haven't tried switching back and forth at the 100 km/h (62 kph) maximum it says in the OM, but have at around 80 (50) and it works fine as long as you take you foot of the accelerator during the switch in either direction.
    80 (50) is about as fast as I want to be going in 4WD anyway...its use suggests that road condition is a bit suboptimal so some prudence seems warranted.
