4WD on the asphalt???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wishbone1965, May 29, 2013.
  1. May 29, 2013 at 4:55 PM
    Wishbone1965
    Wishbone1965 [OP] Well-Known Member
    Texas
    2013 SR5 4x4
    Forgive me if this is a stupid question. I have a 2013 4x4. I need to engage the 4WD for lubrication purposes. Not doing any real 4 wheeling for a month or so. Does it matter if I drive in 4 wheel on the asphalt or would it be better to take it off road? How low should I keep the speed? I know the manual says under 60 but wondering about the first few times I engage it.
    Thanks
  2. May 29, 2013 at 4:56 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Do not engage it on pavement at all if you have to just go to a field and put it in 4x4 and drive it around for a few minutes
  3. May 29, 2013 at 4:57 PM
    Larry
    Larry CARL
    CARL
    find a dirt or country gravel road and drive it for a bit there.
  4. May 29, 2013 at 4:57 PM
    Wishbone1965
    Texas
    2013 SR5 4x4
    Why does it matter if it's pavement or dirt?
  5. May 29, 2013 at 4:59 PM
    Backinblack03
    Backinblack03 Well-Known Member
    Brian
    VT
    2003 Xtra cab 4x4 2.7/5spd
    ABS sucks.
    I engage mine on the pavement ONLY under the following 2 conditions:
    1) It's a straight, flat road.
    b) It's raining.
    Not worth binding up the driveline and exploding the transfer case. You could always put the truck on jackstands and 4x4 in the air... :p
    burntkat, Inmand09 and hilux30 like this.
  6. May 29, 2013 at 5:01 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Should have got 2wd if you don't need it. :p
  7. May 29, 2013 at 5:02 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Straight is fine
    ColoradoTom likes this.
  8. May 29, 2013 at 5:03 PM
    Larry
    Larry CARL
    CARL
    but that reduces the internet nut swinging prowess. :D
  9. May 29, 2013 at 5:04 PM
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    All wheels need to be able to spin independently, which curvy asphalt won't allow.
  10. May 29, 2013 at 5:05 PM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    I've driven my last 2 Tacomas ~10 miles in 4WD every month for the last 7 years. I just engage it on a long straight road in the rain. I turn it off when I need to corner. No problems in 7 years, that should tell you something...
  11. May 29, 2013 at 5:05 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    It is best to always engage it on dirt, but if you are going in a straight line and no locker is engaged for a short distance there should be no damage. Even though the book says it is safe to engage up to 60 I would stop and engage it or at least be going very slow.
  12. May 29, 2013 at 5:05 PM
    Tacoma Mike
    Southern Maine
    Hehehehehe here we go again.
    There has been extensive discussions on this topic.
    I would suggest a little searching and do some reading and make your own conclusion.
    That's all I'll say on the subject for now..:D
  13. May 29, 2013 at 5:06 PM
    Larry
    Larry CARL
    CARL
    were you born that way or was it your "choice" :D
  14. May 29, 2013 at 5:07 PM
    OZ-T
    Peter North
    British Columbia
    Everyone is born with their sexual preference set
  15. May 29, 2013 at 5:08 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    This.
    You won't blow a transfer case, you work break down. Keep it slow and straight as possible. I've done a few tests on pavement for feel and testing new parts. I do not believe you will have any issues with the ( what 4 miles) recommended lube trip.
    burntkat likes this.
  16. May 29, 2013 at 5:08 PM
    worthywads
    That thread was locked. ;)
  17. May 29, 2013 at 5:10 PM
    Larry
    Larry CARL
    CARL
    yes. set to procreate.
  18. May 29, 2013 at 5:12 PM
    OZ-T
    Peter North
    British Columbia
    Not necessarily
  19. May 29, 2013 at 5:13 PM
    Larry
    Larry CARL
    CARL
    for survival of the species it is.
  20. May 29, 2013 at 5:16 PM
    Razgriz
    Razgriz wtf am i reading
    San Jose, CA
    2013 White TRD 4x4
    :stayontopic:
