4wd on wet asphalt?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Climberclimb, Jan 3, 2024.
  1. Jan 3, 2024 at 1:56 PM
    Climberclimb
    Climberclimb [OP] Well-Known Member
    Stacey
    British Columbia
    2020 TRD Sport premium
    Stock!
    Hi everyone,
    As title states, my wife drove about 50 km on wet pavement in 4 hi. She forgot to put it back into 2hi. What damage could have occurred and any way to check it over? Thanks in advance! ☹️
  2. Jan 3, 2024 at 2:02 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    That alone probably did no damage. Just about everyone has done something similar at times. I know I have. If done on a regular basis over time it will lead to premature parts wearing out. You rarely see a catastrophic failure, but if done on dry pavement and sharp turns are made then it puts everything under more stress
  3. Jan 3, 2024 at 2:05 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    "Part out"
  4. Jan 3, 2024 at 2:05 PM
    Dubiousveracity
    Dubiousveracity Well-Known Member
    2018 TRDOR DCSB MT
    none
    Like 99.9% chance no damage unless she was driving 50km weaving through a parking lot.
    Mostly straight (not turning tight from street to street) there just isn't enough different in front and rear axle speed to build up a significant amount of strain.
  5. Jan 3, 2024 at 2:05 PM
    Climberclimb
    Stacey
    British Columbia
    Stock!
    Thanks Marshall, and others! Yeah,in the time since I bought it this is the first time it’s happened. Thanks for reassuring me! Cheers
    StayinStock and TacoSR523 like this.
  6. Jan 3, 2024 at 2:07 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If she was out on the highway it's probably fine. If it was engaged driving in/out of parking spots in a parking lot she may have heard some binding or noise
  7. Jan 3, 2024 at 2:14 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    This is your chance to get some really nice wheels and tires.
  8. Jan 3, 2024 at 2:26 PM
    fiftysix
    fiftysix Mell-Known Wember
    Midwest
    23 TRD OR, 03 Rust Bucket
    The tires are now cooked and need replacement. Lucky for you I have a set of 5 Goodyear wrangler takeoffs that you can buy for a great deal
  9. Jan 3, 2024 at 2:28 PM
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
    Torspd and SR-71A like this.
  10. Jan 3, 2024 at 2:39 PM
    TacoTuesday1
    SD CA
    I mean. It’ll bind turning. I’m really not sure what would break. Snap a chain in the center diff? The chain is strong and you’d probably know if you did.
    plus wet is not the worst. There’s still some ability to slip versus completely dry on abrasive asphalt depending on what the roads are like where you live.
    I wonder how “AWD” models function. If they too have a locked center diff with a chain. Or something else more fluid for that like a Torsen.
    ie 4runner limited, manual FJ cruiser, etc
    Climberclimb[OP] likes this.
  11. Jan 3, 2024 at 5:02 PM
    Climberclimb
    Stacey
    British Columbia
    Stock!
    Thanks everyone, for info and the chuckles!!! I have read others posts asking about the same thing and I have said in my head it would probably be fine. I guess I just wanted to hear the same. Tacoma World is the best! Cheers
  12. Jan 3, 2024 at 5:10 PM
    TacomaAddict23
    TacomaAddict23 There's no cure for dumb
    2023 Lunar Rock DCSB
    Ditch Lights 4wp Sliders Bed side molle panels Taco garage DMM mount More to come
    It’s fine. Just do a 4WD burnout and spin em till they pop!
    Torspd and ToyoTaco25 like this.
  13. Jan 3, 2024 at 5:18 PM
    drvn
    drvn Well-Known Member
    2017 SR5, 2020 TRD Pro, 2022 TRD Pro
    Wet pavement? None
    Nonamesleft4u likes this.
  14. Jan 3, 2024 at 6:23 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    This isn't a problem with Ridgelines...
  15. Jan 3, 2024 at 6:30 PM
    Pinatacoma
    Pinatacoma Well-Known Member
    Vancouver Island, BC
    2020 ACOR
    If I'm pulling out into heavy traffic from gravel or wet, I'll engage 4-HI to "launch", then once accelerated turn it back off again.
    Especially if the truck was empty or lightly loaded, the back end has plenty of slip on wet pavement to avoid damage.
    Torspd and Climberclimb[OP] like this.
  16. Jan 3, 2024 at 7:58 PM
    lr172
    lr172 Well-Known Member
    ‘11 DCLB 4.0 Auto
    They have a interface that can slip instead of a chain or gears. Think torque converter in place of a clutch.
  17. Jan 4, 2024 at 6:26 AM
    Hayden334
    Hayden334 Well-Known Member
    Hayden
    Cullman, Alabama
    2010 Tacoma DCSB TRD OR
    2" spacer lift, 285/70 R17's and a Softopper.
    As everyone else has said. I wouldn't worry about it.
    At least once a month I drive mine to work and back (10 Miles / 16 Kilometers) in 4 hi just to keep every thing functioning.
  18. Jan 4, 2024 at 6:35 AM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    Yep. Same.
    The manual says to exercise the 4x4 system for 10 miles at least every month.
    If I can't get that done in the dirt, I pick a straight paved road in the rain to accomplish it.
    Have done so since 2017. No problems have been revealed yet.
    Hayden334[QUOTED] likes this.
  19. Jan 4, 2024 at 6:38 AM
    Archimedes
    Archimedes Demanufacturer
    Outside the stupid part of Vermont
    23 DCSB TRD OR MGM
    Full-on degenerate heavy metal banjo music
    So, in reply to your proposition:
    I give you this reponse:
    :devil: (sorry for stealing others, it's all I gots at the moment...)
  20. Jan 4, 2024 at 6:41 AM
    Squirt
    Ben
    :fistbump::rofl:
