4WD operation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thezigmiester69, Jul 29, 2023.
  1. Jul 29, 2023 at 9:58 AM
    thezigmiester69
    thezigmiester69 [OP] New Member
    Hello, I am a new member (but not new to Tacoma World). I have been battling the blinking 4x4 dash light for a while now & haven't completely solved the issue. All the threads I've read are great & I learned a lot. Let me know what you think about this situation. The system will engage 4wd high & 4wd low if I move the selector switch in position prior to turning the ignition on. It will not do so if I select either option while the engine is running. I know the 4wd ECM resets each time the ignition is turned on. With the ignition on & in 2wd the 4wd light blinks constantly. My thinking is that the 4wd ECM must be bad. I know the actuators are good because they work just fine. Any new ideas out there ? I don't want to spend the amount of money for a new or (hopefully good used ) 4wd ECM.
  2. Jul 29, 2023 at 10:11 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Does the light continue to blink when rolling in 2WD then moving the switch to 4HI? 4HI to 4LOW you want to be stopped and in Neutral.
  3. Jul 29, 2023 at 10:30 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
  4. Jul 29, 2023 at 10:31 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    TnShooter and 303tacoma like this.
  5. Jul 29, 2023 at 11:00 AM
    thezigmiester69
    Well like I said, everything works fine if I move the selector switch prior to turning the ignition on, that alone tells me the selector switch & actuators are operating as they should & there are no shorts or grounding issues. I've done all the diagnostics that are posted, with positive results. I do PC builds & have seen circuit boards go bad for no apparent reason without warning all the time. That 4x4 ECM is just a circuit board in a plastic case. To answer TA2016 If I move the selector switch to 4 high turn the truck on, I am in 4 high and the light stays solid. If while driving I switch back to 2wd the light starts blinking again & I'm in 2wd. Again my 4wd works but only if I select 4wd (high or low) prior to starting the truck which is when the 4wd ECM resets itself. If there was an issue with the limit switches etc. I don't think I would have 4wd in any instance.
  6. Jul 29, 2023 at 11:01 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    So your 4wd light is always flashing in 2H though?
  7. Jul 29, 2023 at 11:02 AM
    thezigmiester69
    Yes always flashing in 2wd
  8. Jul 29, 2023 at 11:03 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    So check your limit switch voltages in 2H, I bet you will find one is not where it belongs.
  9. Jul 29, 2023 at 11:05 AM
    thezigmiester69
    OK, I will double check that when I get a chance and let you know, Thanks
    Dm93 likes this.
  10. Jul 30, 2023 at 12:56 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    My suspicion is you have a high resistance connection and with battery voltage only the ECM is not seeing enough voltage to make up the logic but while the alternator is on it’s enough to overcome the voltage drop.
    not saying the board might not be bad but I’ve never seen one go bad and your symptoms are similar to many others and the PCB was not the solution.
    Edit: I can’t spell suspicion :oops:
    GilbertOz likes this.
