4WD POP noise
Discussion in 'New Members' started by Dank Donkeh Luvver, Oct 20, 2020.
  1. Oct 20, 2020 at 10:20 AM
    Dank Donkeh Luvver
    Dank Donkeh Luvver [OP] Well-Known Member
    Eric
    Maryland
    2020 TRD OR White 6MT
    OVTune/Coyoza, Eibach Pro Lift, Mobtown Sliders/Skid, Softopper, Martin Offroad Rack
    I made an oopsie today while sitting in a parking lot - I went to turn up the AC and put the truck in 4HI instead. Oops, switched back to 2HI and turned the AC up and forgot about it. Once my order came out, I went to back up (reverse + turn out of my spot) and felt some resistance. Realized that the truck was still in 4wd for some reason so I pulled back into the spot and tried again. Felt the resistance again and gave it a bit more gas and heard a loud POP, then the truck backed up normally. Pulled onto the highway and everything felt fine, flipped it into 4HI quick on a straight stretch and it seemed to engage and disengage just fine. Drove it the rest of the way home in 2HI with no issues.
    Did I fuck something up? Anything I should crawl under the truck and check out?
  2. Oct 20, 2020 at 12:32 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    I highly doubt any damage was done.
    Pop was the sound of torque bind being released. It wouldn't hurt to look for leaks or tears in CV boots.
  3. Oct 20, 2020 at 12:42 PM
    Bigdaddy4760
    Maner
    Poolville Texas
    Welcome to TW
    :hattip: :cheers:
  4. Oct 20, 2020 at 12:45 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
  5. Oct 20, 2020 at 2:33 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    StayinStock likes this.
  6. Oct 20, 2020 at 2:37 PM
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    It happens. Most likely no issues. Just remember to let it disengage before turns like that on dry pavement.
    Black DOG Lila and StayinStock like this.
  7. Oct 22, 2020 at 3:55 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome
  8. Nov 11, 2020 at 12:11 PM
    aldoj.v
    aldoj.v Member
    2020 quicksand trd off road
    same exact thing happened to me as well
  9. Nov 11, 2020 at 12:23 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    That's one of those things you try not to do, but something similar happens to all of us sooner or later. I've forgotten to switch out of 4X4 before turning back onto a paved road in the past and felt resistance. Damage from stuff like this is cumulative. If it happens occasionally you'll probably never have a problem. But if you make a habit out of driving in 4X4 on pavement it will bite you in the butt sooner than it should. Unfortunately most people don't keep one long enough for it to show up. It is the next guy who gets the truck that usually pays for the damage.
  10. Nov 11, 2020 at 12:36 PM
    Konagrn
    Konagrn Well-Known Member
    Las Vegas, NV
    2019 Tacoma off road manual
    1.5" Eibach springs, 1.5" Icon add a leaf, Bilstein 5100 shocks, 1" rear blocks.
    I did the exact same thing thinking I was turning on the AC. Now I put electrical tape over the 4x4 knob.
