4wd prob
Discussion in '1st Gen. Tacomas (1995-2004)' started by viperfella, Jun 20, 2010.
  1. Jun 20, 2010 at 6:09 PM
    viperfella
    viperfella [OP] Well-Known Member
    Bubba
    North carolina
    2000 tacoma trd v6
    15'' mickey tompson bullet hole rims 31.10.50 mickey tompson baja tires
    I have problems whenever I'm in 4 hi and get in a bind it makes a noise that sounds like a gear grinding or something also it only happens when I'm in reverse.
  2. Jun 20, 2010 at 10:12 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    What are you descibing when you say "get in a bind"? Are you on asphalt or concrete road surfaces?
  3. Jun 20, 2010 at 10:14 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    You shouldn't run 4x4 on concrete especially round bends.
  4. Jun 21, 2010 at 5:32 AM
    viperfella
    Bubba
    North carolina
    2000 tacoma trd v6
    no im not running it on pavement. for example last night i was playing around in sand and got my ass end buried down i locked it in 4 hi and put it in reverse and gave it some gas and all it did was struggle to go and then it makes a gear grinding noise
  5. Jun 21, 2010 at 6:42 AM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Did it fully engage before you gave it much gas?
  6. Jun 21, 2010 at 9:37 AM
    viperfella
    Bubba
    North carolina
    2000 tacoma trd v6
    yes it fully engaged it only does this in reverse i can go forward with no problem or if i put it in 4 lo i can back up. it has me stumped
  7. Jun 21, 2010 at 10:07 AM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    is it "whining" or grinding?
  8. Jun 21, 2010 at 11:26 AM
    96er
    96er Sport Rally'er
    MA
    '96 Tacoma XCab 4x4 SR5
    You can run it in a straight line at lower speeds, but I agree that turning on dry pavement in 4wd is a big no-no.
    Monthly, I engage my 4wd, even for 200-300 feet just to get the gears wet with gear oil.
  9. Jun 21, 2010 at 12:46 PM
    Jason'sLawnCare
    me to now :notsure: it sounds like a t case issue though if you can reverse in everything but 4hi.
  10. Jun 22, 2010 at 9:22 AM
    viperfella
    Bubba
    North carolina
    2000 tacoma trd v6
    yea i thought i messed up whenever i first herd it but i put it in 4 lo and it struggled but it eventually came out of my rut
  11. Jun 23, 2010 at 9:37 AM
    YotaDude01
    YotaDude01 Kentucky Boy
    KY
    01' TRD off-road
    yeah they say to engage your 4 wheel drive once a month to keep everything lubed up and in good shape. but as far as the rattle goes im not sure. sometimes in my 01 if im on a hill taking off and i let the rpms get really low (5 spd manual) it will make a rattle sound.. but its just the motor bogging. but yours is a auto so im not sure. maybe its low on fluid or something.
  12. Jun 23, 2010 at 11:15 AM
    96er
    96er Sport Rally'er
    MA
    Its amazing how far 4wd/awd has come. Our Tacoma's really have the simplest T-case design. My truck is practically unusable in 4wd on dry surfaces yet these computer controlled awd/full time 4wd vehicles have no problem, don't bind up, still get decent mileage, etc.
  13. Jun 23, 2010 at 12:16 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Comparing the 4wd systems in our trucks to AWD systems in, say a Highlander, kinda seems like comparing apples to oranges. The two types of systems are so different, I don't see how they can be compared.
    AWD systems utilize fluid coupling (similar to the way an automatic transmission works), a Tacoma's 4wd system is a direct drive system after the tranny where there is no slippage except between the tire and the ground.
    When 4wd is engaged in Tacoma's, high traction situations like pavement are very hard on the system and a good way to break something.
