4wd problem did the garage do it
Discussion in '1st Gen. Tacomas (1995-2004)' started by celtic69, Aug 9, 2019.
  1. Aug 9, 2019 at 4:14 PM
    celtic69
    celtic69 [OP] New Member
    2004 black tacoma 4wd
    I took my to the shop to have new clutch put in when I got the truck back the 4wd shift level was install backwards and I had no 4wd drive I brought back right away they fix the shift levelm but no 4wd they charge me $1000 plus to fix it. Could they have damage it? Work fine before
  2. Aug 9, 2019 at 4:16 PM
    eon_blue
    Azusa, CA
    Is it the manual J-shift lever or the shift lever with the 4wd button on it? If it's the button one I wonder if they didn't reconnect the wire
    Been awhile since I had mine taken apart but *I think* there's a wire connection there that you have to unplug to take the lever off completely...can't imagine they would just leave that unplugged though
  3. Aug 9, 2019 at 4:17 PM
    eon_blue
    Azusa, CA
    It should definitely be on them to fix it...that's some BS they want to charge $1000 to do it. Why are they charging that much? Do they claim to know what's wrong with it?
  4. Aug 9, 2019 at 4:33 PM
    celtic69
    the truck does not have a button you just shift level- They replaced the front differential actuator($609.97part) and the transfer case switch ($95part)
    I was wondering if the shift level being in backwards would constant current to the transfer case Switch?
  5. Aug 9, 2019 at 9:22 PM
    02hilux
    Planet: EARTH
    How can the shift leverage get install backward? The 2 rear bolt pattern are wider then the 2 front?? Unless when they install it, the leverage didn't go into the shift rail position
  6. Aug 9, 2019 at 9:24 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    That’s a very simple t case
    I guarantee they didn’t re install something correctly
  7. Aug 10, 2019 at 3:21 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I have installed the transfer case lever backwards a time or two it is quite easy to do.
    Unless things changed in the newer trucks
    Seems a case of being taken advantage of though
