4wd problem please help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Yfz 450, Jan 30, 2015.
  1. Jan 30, 2015 at 5:23 PM
    Yfz 450
    Yfz 450 [OP] Well-Known Member
    Rockland ny
    tacoma 4x4
    Yes I bought this truck this past October and put maybe 1500 miles on it since. I bought it with 138,000 so I have no idea when they were last done if ever. I am going to change all the fluids anyway being this is what I have to get to work in bad weather I have a county job that has no snow days so up keep on this truck is very important to me. I just like to get a lot of input before I dive into a project. I was also talking to my father about it and he brought seething up I never even thought of maybe it could have been a hub.
  2. Jan 30, 2015 at 6:01 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    Locking hubs?
  3. Jan 30, 2015 at 6:08 PM
    Yfz 450
    Rockland ny
    tacoma 4x4
    They are the stock auto ones
  4. Jan 30, 2015 at 8:20 PM
    tomtom
    The Desert SW
    2012 FJ
    Not sure it'd be a hub but wouldn't rule it out. You have the ADD which means the hubs and the CVs are spinning all the time. I'd expect to feel something wrong with the hub whether you're in 4WD or 2WD. As I said earlier, wouldn't rule it out but I'd move it down the list of suspects. I'd go after the easy ones first like the diff and transfer case fluids. Sounds like they should be done anyways.
  5. Jan 31, 2015 at 6:26 AM
    Yfz 450
    Rockland ny
    tacoma 4x4
    That is going to be this weekends project. Thank you for all your input. I might have a lot of overtime this weekend though with the snow we are supposed to be getting here in ny so I might have to load the back of the truck this weekend if I can't get to it
  6. Jan 31, 2015 at 10:49 AM
    Yfz 450
    Rockland ny
    tacoma 4x4
    I was thinking I'm not 100 percent sure how it works but as you said if the cv's are always spinning while driving wouldn't the differential be in motion aswell while in 2wd. Might be a stupid question I'm am just unsure how it works
  7. Jan 31, 2015 at 11:18 AM
    crainholio
    crainholio Well-Known Member
    I'd really find a way to check fluid levels and top off if needed on the front diff and transfer case in a hurry if it was me.
  8. Jan 31, 2015 at 12:11 PM
    Yfz 450
    Rockland ny
    tacoma 4x4
    I am hoping tomorrow I will be able to. I am working a double shift today started 7 thismorning get out 11:30 tonight. It's like everything always happens all at once the day before I started having the issues with the truck my clutch master cylinder went out on my commuter hyundai accent. So that's in my garage taken apart because my local store had to order it, then this happens with the truck then I get slammed with overtime this weekend when I was planning to get everything fixed. What is a good recommended oil to replace it with?
  9. Feb 1, 2015 at 7:50 AM
    crainholio
    I don't recall what the owner's manual specifies for viscosity so you'll want to check, but I use Mobil-1 75W-90 in the front diff and transfer case. Rear diff called for heavier viscosity if I recall right, I went with Lucas and change it every 3 years.
  10. Feb 1, 2015 at 8:04 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    In 2wd with ADD, both CVs are always spinning. The pass side CV is completely disconnected from the differential. The driver side CV is permanently connected to the differential but only spins both side gears and the spiders. The side gears spin in opposite directions and the carrier, R+P gears and drive shaft do not spin. They may rotate a bit in sympathy with sloshing oil but they are not driven.
  11. Feb 1, 2015 at 10:31 AM
    Yfz 450
    Rockland ny
    tacoma 4x4
    Update: I just changed the fluid in the transfercase and the front diff. Transfer case looked like it was brand new golden color. The front diff on the other hand was black and felt thin. The drain plug had a buildup on it that I can only discribe as a magnetic clay. It had the consistency of clay and covered the whole area of the plug maybe 1/16" thick. I'm sure that is not a good sign. I refilled both with 75/90 and took it for a ride. I don't know if my mind is playing tricks on me or not but I think it may have been a little quieter and been a little smoother. I guess all I can hope is for the best now and hope it holds up
  12. Feb 1, 2015 at 11:10 AM
    tomtom
    The Desert SW
    2012 FJ
    Here's hoping that was all that was needed.
  13. Feb 2, 2015 at 11:14 AM
    Yfz 450
    Rockland ny
    tacoma 4x4
    Final update: today it was put to the test I did my 40 mile commute but the roads were completely snow covered except for maybe the last 10 miles and I put it back in to 2wd. My top speed in 4wd this time was probably 45 mph and there were absolutely no issues for the 30 miles I was in it. So thank you to everyone's input, advice and knowledge and I lucked out
