4wd problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jumorgan, Aug 8, 2015.
  1. Aug 8, 2015 at 12:42 PM
    jumorgan
    jumorgan [OP] Member
    2010 metallic gray tacoma
    Just got a 2010 tacoma access cab 4x4 5spd try to put it in 4lo and the light just blinks and won't stop beeping, put it in 4hi it engages but when you try to drive it's like you're engaging the parking brake it gets slower and slower and acts like it's under stress and will make the clutch start burning, any idea what could be causing this? Thanks
  2. Aug 8, 2015 at 12:47 PM
    bubbabud
    bubbabud Well-Known Member
    Bob
    Tonopah AZ
    13 tacoma TRD Off road.ARE shell no rust anywhere period.
    2 in spacer lift front 2, in AAL rear [tundra leaf] , flip up tow mirrors, ARE shell electric brake controller and cooper ATP 265/r70x16 tires on stock TRD wheels
    Sounds to me like some one swapped gears in one of the differentials and they are a miss matched ratio.
    jmaack and tcBob like this.
  3. Aug 8, 2015 at 12:54 PM
    NMroamer
    NMroamer Well-Known Member
    Fred
    Albuquerque
    2015 TRD OR
    It is possible the previous owner did not use the four wheel drive much. It is not the way you are supposed to do it but it works when it is hard to do.
    Stop completely put in neutral and shift into 4 hi. rev the engine a little then put it in gear. You should be completely stopped for 4 lo anyhow. Had an 2008 that was hard to do when I first got it. that helped. If it still blinks when you start out vary your speed.
    Reread your post. Bubbabud makes sense.
  4. Aug 8, 2015 at 1:01 PM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    I agree with Bubbabud if your tires are all the same size and properly inflated.
  5. Aug 8, 2015 at 1:46 PM
    jumorgan
    Been messing with it as long as your running it fines but if you're only going 10-15 or slower it starts acting like your pulling the emergency brake and still won't go into low, stopped and took it out of 4hi went to pull off and it clanked pretty hard and went back to 2wd
  6. Aug 8, 2015 at 1:50 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    what kind of surface are you driving on?? PAVEMENT?
  7. Aug 8, 2015 at 1:53 PM
    jumorgan
    Pasture
  8. Aug 8, 2015 at 1:57 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    too much tension between the front and rear tires--???? try level surface-back up-see if that helps.
  9. Aug 8, 2015 at 2:02 PM
    jumorgan
    I have I've messed with it in the pasture on gravel and in the drive way
  10. Aug 8, 2015 at 2:34 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    bump--lets see if anyone else can HELP
  11. Aug 8, 2015 at 2:46 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    You can't engage 4lo unless you're stopped
  12. Aug 8, 2015 at 3:03 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    My brother bought an old 4 runner that did this and it was mismatched gears.
    Put it up on jack stands and engage 4wd if the wheels spin you got your answer.
  13. Aug 8, 2015 at 3:31 PM
    jumorgan
    Tried everything by manual this ain't my first time around a 4wd still doing the same thing
  14. Aug 8, 2015 at 7:45 PM
    bubbabud
    Bob
    Tonopah AZ
    Go back to basic's if its bogging engine down as you describe and made a big bang when you took it out of 4x4 hi its because the drive train is binding and the cause of the binding is because the axle's are trying turn 2 different speeds this caused by either miss matched tires or mismatched axles I'm still putting my money on axle swap in the past. I would bet that previous owner broke some thing and put a junk yard transplant just to get it on the road or to sell it. I have been wrong in the past will be in the future but you described the classic sign's of miss matched gears.
    As for 4 low it wont engage if there is that much bind on the drive train. So check gear ratios in front and rear if they are the same then I'm blowing smoke and if not then you have found the problem.
  15. Aug 9, 2015 at 1:29 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    any update?
  16. Aug 9, 2015 at 3:59 PM
    jumorgan
    I'm going to take it back where I bought it Monday cause it came with a year warranty and have them send it to toyota in town and see what happens hopefully cause I've tried everything finally got it to go into 4lo and it seemed to be fine then but still got the same issue in 4hi
  17. Aug 9, 2015 at 4:41 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    EXCELLENT! keep us posted--let us know what you find out(for the fix)
  18. Aug 12, 2015 at 9:55 AM
    jumorgan
    Played with it in the backyard for a while started workin took it in and they said everything was aight so I guess it just hadn't been used in a while is all I can figure dangtest thing ever
  19. Aug 12, 2015 at 2:44 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    as you can see in my avatar--had a 91--the only time I had difficulty was when the road was not slippery enough.
  20. Aug 12, 2015 at 3:06 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    When my truck hasn't been in 4wd for a long time sometimes it takes a long time to engage. Once I hadn't used it for about a year (was traveling and the truck sat) and it took like 10 miles of driving on a snowy road for it to engage. The more regularly I use 4wd the easier it is to shift in and out.
