4WD Problems
Discussion in 'Technical Chat' started by Tom/Daisy, Aug 6, 2022.
  1. Aug 6, 2022 at 7:50 AM
    Tom/Daisy
    Tom/Daisy [OP] Member
    2007 Silver Tacom
    none
    I have a 2007 Tacoma with 4WD problems. I am locked in 4WD and the flashing indicator lite on the dash indicates 4Lo. I not so sure this is correct because when I drive it feels like 4H? I'm reasonably sure the problem is one (or both) of the two 4WD actuators. The Transfer Case actuator or the Rear Differential Actuator. Of the two which one is the most likely culprit, or should I just replace both? Until I replace them is there a quick fix to get out of 4WD?
    Thanks!
    Tom
  2. Aug 6, 2022 at 7:55 AM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Forgive me for possibly insulting your familiarity with the system,… but you’re in neutral when trying to get out of 4low right?
    if it’s a bad actuator, try tapping it lightly while it’s trying to engage/disengage. That’ll usually work for awhile until it’s replaced. Also, check the electrical connection. Good luck.
    Dm93 likes this.
  3. Aug 6, 2022 at 9:56 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Agreed, you must be in neutral with an automatic trans or clutch fully depressed with a manual trans and under 3 mph to shift into and out of 4lo.
    If that's not your problem have you looked under the truck at the transfer case actuator and the ADD on the front diff for any damage or broken or loose wires?
    You can check limit switch voltages at the 4wd ECU to determine which switch(s) is out of range, see the thread below for more info.
    https://www.tacomaworld.com/threads/4wd-system-operation-help-thread.742420/
  4. Aug 7, 2022 at 6:19 AM
    Tom/Daisy
    2007 Silver Tacom
    none
    Thanks, and yes, I was in neutral.
  5. Aug 7, 2022 at 6:52 AM
    Tom/Daisy
    2007 Silver Tacom
    none
    No particular reason! It was just a question as I really haven't had a chance to test either but from what I've read I'm leaning toward the Transfer Case actuator. Once I've tested them, I will know for sure. Thanks for your response and any other advice I would really appreciate.
