4WD question & jack question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2007tacoOldLineSt, Oct 28, 2010.
  1. Oct 28, 2010 at 7:13 AM
    2007tacoOldLineSt
    2007tacoOldLineSt [OP] Well-Known Member
    Rather than clutter up the forum I figured I would try and post these two questions together...
    1 ) I engaged my 4WD today ( 4WD HI ) and noticed that when I crank the wheels all the way to one side the wheels lock and the truck won't roll. I was turning into my parking spot behind my house which requires me to turn the wheels as far as possible in one direction. I would assume this is normal, but figured I would bounce it off some more knowledgeable folks.
    2 ) Is the stock jack sh*tty or is it me? The first time I tried to rotate my tires I could barely get the front end high enough to get the tire off. I saw some decent looking jacks at Lowes, any thoughts or recommendations?
    Thanks...
  2. Oct 28, 2010 at 7:19 AM
    davidpick
    davidpick NWXPDTN
    David
    Snohomish, WA
    2004 Xcab 4x4 TRD
    as far as your second question, keep in mind that you get what you pay for. buy the best jack you can feasibly and responsibly afford. check out sears -- i didn't have much to spend on my jack and stands (definitely make sure you get a set of stands too!), but i got a 3.5 ton floor jack with a 21-inch lift and two 3-ton jackstands for $100 (on sale) at sears about 2-3 months ago... sears always has something on sale...
  3. Oct 28, 2010 at 7:22 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    dont use 4wd on pavement!! read the instructions in the front visor
  4. Oct 28, 2010 at 7:22 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    I'll let someone else chime in on your first issue. I've never had a problem with the factory jack. I've been able to get the tires off the ground enough to get them off without an issue. I wouldn't leave it supporting the truck though (ie back end on jack stand, front on the jack). I'd use it to jack it up enough to put the stands and and that's it. Keep in mind this is an emergency jack. The floor jacks you can buy, say at Sears, will be much easier to use and are built for holding up the vehicle long enough to work on it.
  5. Oct 28, 2010 at 7:28 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 Dbl Cab LB 4x4 TRD
    Toytec CO's, IRONMAN rear leaf pack, All pro front bumper, Body Armor rear bumper, BA steps MB TKO's w/285/75/16 Terra Grapplers, Bakflip tonneau cover, autopage remote start alarm, Ultragauge
    x2..
  6. Oct 28, 2010 at 7:32 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    x50, you are putting a lot of strain on your front end on dry pavement at full lock....
  7. Oct 28, 2010 at 7:49 AM
    Brunes
    Brunes abides.
    Rotorhead
    1) Some other folks have covered. Too much grip means the tires can't slip to move at different speeds...and thens tuff breaks.
    2) For tire rotations- I wouldn't use the roadside jack. Get a solid set of stands/chocks/garage jack. That little jack is a trade off- Not big so you can take it everywhere without too much issue...but not not big so it won't let you do everything a normal jack would.
  8. Oct 28, 2010 at 7:58 AM
    2007tacoOldLineSt
    Awesome information...thanks guys. I bought my taco used...no card in the visor!
    I only drove about 200-300' in 4WD, and I have only done it once. Glad I noticed the lockup and asked here.
    With this new information, just how soft should the surface be to engage the part-time 4WD? And would that hard turn lock on a soft surface as well? I guess it would be safe to stick to 4WD unless you get stuck? Or is there another rule of thumb to follow?
    I have only used the 4WD twice. Once in some soft mud ( got stuck in 2WD ) at a jobsite, and once playing around at a site where some new homes are being built ( combination mud and loose dirt ).
    Thanks again...
  9. Oct 28, 2010 at 8:00 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Basically Line #1 on the card...
    Off pavement or if the pavement is very wet or icy is when you can use 4WD... This is beacuse the front and rear driveshafts are 'locked' together in 4WD.... Since they need to rotate at different speeds while turning (front tires rotate more than back tires), you want to be on a soft or slippery surface so they can, when in 4WD. Otherwise, turning will be difficult and a strain on parts.
    AWD ('All Wheel Drive' or full time four wheel drive) vehicles have a center differential that allows the front and rear driveshaft to rotate at different speeds and can be driven on dry pavement.
  10. Oct 28, 2010 at 9:05 AM
    2007tacoOldLineSt
    Thanks again.
    Hopefully my 200-300' low speed 4WD adventure on pavement didn't do any serious damage. I doubt it, but you never know I guess.
  11. Oct 28, 2010 at 9:07 AM
    Pugga
    Massachusetts
    You're more than likely fine, just don't do it again! :smack:
  12. Oct 28, 2010 at 10:01 AM
    m_taker1
    m_taker1 Well-Known Member
    Mark
    Pittsburgh, Pa
    Bug deflecter, vent shades, Airaid Intake, Pop 'n lock, replaced chrome bumper with black bumper, replaced chrome grille surround with a black grille surround, blacked out logo in the front, debadged, center console lock, grom audio mp3/ipod,weathertech digital liners
    i have (2) 3 ton floor jacks, i got one at pep boys and one at sears. the one at sears was like $59 on sale, just keepy an eye out, habor freights are about the same price also.
  13. Oct 28, 2010 at 11:16 AM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    The stock jack is just fine. I can put it on the frame and get the front tires off the ground no problem, I don't have the sway bar on (allows the one tire have more droop) and they are a true 33" tires. I just use the jack to lift and always use jack stands.
  14. Oct 28, 2010 at 11:24 AM
    Loudpedal
    Loudpedal Mind = Blown
    Blair
    Not really New, not really Mexico
    02 SR5-Hole 4x4
    Andres Devil Horns, Goodyear Duratracs, Accidental Tailgate Delete (x2), Billy 5100s, OME 881 coils, Wheeler's 5-leafs, BAMF Sliders with kickouts, Box Rocket Fab Bedrack.
    So everybody pretty much covered it, but check out David K's threads on 4 wheel drive information. this guy knows stuff :spy:
  15. Oct 29, 2010 at 4:03 AM
    Wattapunk
    Uncle K
    TX
  16. Oct 29, 2010 at 4:11 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If you're in 4WD and make tight turns like that ...you could blow out your CV joints real quick.
