4WD Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BarkSlayer, Jan 5, 2014.
  1. Jan 8, 2014 at 1:49 PM
    #61
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    So much misinformation in this thread. Why people choose to argue there is no bind in 4x4, when Toyota themselves has explained that it happens in the manual, is beyond me. No, all the tires don't have to spin the same speed, but the averaged speed of the front tires will always equal the averaged speed of the rear tires(ie front and rear pinions are spinning the same speed always), unless, like I've said before, there is a center diff between the 2 drive shafts.
  2. Jan 8, 2014 at 1:51 PM
    #62
    03is300ztk
    03is300ztk Well-Known Member
    Zach
    Somewhere in the hills NC
    07 Tacoma 4X4
    Grillcraft, with front and rear bumper/bed in the works.
    My audi has an awesome center diff!!
  3. Jan 8, 2014 at 2:16 PM
    #63
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Your kidding right?
    Sounds like you've never actually made sharp turns on dry pavement with your part-time 4WD engaged. Believe me, your going to bind up and quite possibly break something. Read the links below for more information...
  4. Jan 8, 2014 at 4:05 PM
    #64
    JaRobTaco
    JaRobTaco Well-Known Member
    '08 DC LB 4x4 4.0L Sport
    Not going to argue. If you don't want to use it don't. How many front ends have you replaced because of this? Ask your local Toyota master tech how many he has even heard of. I Know Savannah's master tech Mike, just grinned and shook his head when I asked him. I do not hesitate to use it.
  5. Jan 8, 2014 at 4:11 PM
    #65
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    Hell to the NO on using 4x4 on dry pavement and especially NO when on dry pavement and turning
  6. Jan 8, 2014 at 4:59 PM
    #66
    junkman
    junkman Well-Known Member
    Erik
    Louisville
    '13 SR5 4x4 5 speed Access Cab
    Let's see. Toyota provided instructions, or random guy on the internet. Who do I trust?
    hmm.....
  7. Jan 8, 2014 at 5:02 PM
    #67
    03is300ztk
    Zach
    07 Tacoma 4X4
    Well the instructions provided earlier do not say to "not" use 4x4 on dry pavement. It states that it "can" bind on dry pavement.
    Pretty sure he is saying it won't break just using it on dry pavement.
  8. Jan 8, 2014 at 5:10 PM
    #68
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    ...It won't break, but do I wanna play that roulette game?!? Hell nah
  9. Jan 8, 2014 at 5:10 PM
    #69
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    Who the hell uses 4x4 on pavement anyways?
  10. Jan 8, 2014 at 5:13 PM
    #70
    03is300ztk
    Zach
    07 Tacoma 4X4
    So if won't break what's the problem? If you know how your truck acts and feels when it starts to bind back off a hair and adjust your steering.
    No one here is suggesting put it in 4 hi and forget about it. What's being "discussed (lol)" is that touching dry pavement in 4 wheel drive is going grenade the truck. As it was plainly put above it won't.
  11. Jan 8, 2014 at 5:16 PM
    #71
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    no it won't but why even do it? If OP wants to put 4x4 and leave it on 4x4 for his daily commute or whatever than good for him. I'm not going to do it.
  12. Jan 8, 2014 at 5:17 PM
    #72
    03is300ztk
    Zach
    07 Tacoma 4X4
    No one is suggesting that he or I or even you should do it so why are so hung up on that one scenario that no one is even discussing. Except for you?
  13. Jan 8, 2014 at 5:24 PM
    #73
    kirkofwimbo
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    I don't see why people can't just be sensible about the whole deal. There is no 100% one way or the other. We all know what happens to metals under stress, they either bend or break. It is 100% true that 4x4 with no center diff will cause binding and stress on the drive train when turning. Use your own judgement, just don't come complainin to TW when you blow a diff or CV autocrossing your truck in 4 wheel drive. Rant over. :)
  14. Jan 8, 2014 at 5:25 PM
    #74
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    Did you read the OP? :confused:
  15. Jan 8, 2014 at 5:25 PM
    #75
    03is300ztk
    Zach
    07 Tacoma 4X4
    Word 6
    Reading comprehension fail. That's ok though
  16. Jan 8, 2014 at 5:26 PM
    #76
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    WTF this thread
  17. Jan 8, 2014 at 5:39 PM
    #77
    junkman
    Erik
    Louisville
    Yeah, if you are on snow, ice or even wet pavement, you are probably ok. My responses were to JaRobTaco saying there is no binding on dry pavement. Explicitly "That is the sole purpose of the open diff, so you can turn with no damage. The surface makes no difference."
  18. Jan 8, 2014 at 5:51 PM
    #78
    Canazes9
    Canazes9 Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
    You are binding in 4wd on dry pavement.
    You are also OK, other than some minor tire damage and VERY minor accelerated wear to mechanical systems. This is one of the silliest threads on TW, comes up every so often. Truly comical to read all the little hand wringers that think their truck is going to explode because they ran a few miles on dry pavement w/ the 4wd system engaged - best not to risk it!
    David
  19. Jan 8, 2014 at 5:53 PM
    #79
    OZ-T
    Peter North
    British Columbia
    FWIW , crank the wheel hard on snow and you'll get binding too
  20. Jan 8, 2014 at 5:55 PM
    #80
    Canazes9
    David
    Texas
    hard pack dirt, rocky hillsides, slickrock at MOAB...
    still the trucks manage to survive....
    David
