4wd required monthly maintenance
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Josephray70, Jul 9, 2024.
  1. Jul 9, 2024 at 6:56 AM
    xp0nex
    xp0nex Taco Noob
    2022 MGM TRD Off-Road DCSB 4x4
    Where I live, there is a straight road with a couple small roundabouts that stretch about 7 miles. Whenever I take that road, I keep telling myself I'd put it into 4HI but I always forget
  2. Jul 9, 2024 at 6:59 AM
    nevertoomanytacos
    nevertoomanytacos Taco Fan
    3rd Gen
    Was moving a trailer the other day, from asphalt to grass, in 4hi. The truck let me know when my turn radius on asphalt was getting a bit too tight. Truck slowed down during the turn w/o me reducing throttle input. This told me I needed to increase turn radius and apply a bit less throttle. No issues and once I got fully onto the grass, the 4WD traction was nice to have...
  3. Jul 9, 2024 at 7:51 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Those Facebook groups are full of a bunch of idiots, I've come to notice.
    Throw it in 4wd on pavement, just don't make any sharp turns. Find the straightest stretch of road around you and exercise it there every now and then and you should be good.
    As others have said, you can go as fast as you want (not that it's necessarily recommended to go crazy fast in 4wd...), it's just the engagement of 4wd you want to be under the specified speed in the manual.
    02Duck, BillF1564 and Josephray70[OP] like this.
  4. Jul 9, 2024 at 8:04 AM
    Amocat15
    Amocat15 Well-Known Member
    Bucks County, PA
    2021 DCSB TRD OR
    My wife needed to drive the truck to work for a week once while I was away, and she must have accidentally put it into 4hi without realizing while turning knobs to try to turn the headlights on in the dark. She didn't know it was in 4wd and drove it like that all week on dry pavement. When I got home she said "something's wrong with your truck... it bucks and shakes when I pull it into a parking spot. It has been doing that all week..." :mad: It was fine. Never had any issue with it after that. If my wife couldn't break it I'm sure driving it a few miles on straight roads is once a month fine haha!
  5. Jul 9, 2024 at 8:09 AM
    Josephray70
    Josephray70 [OP] Well-Known Member
    Joseph
    Grand Rapids, MI
    2017 Toyota Tacoma limited
    Bilstein 6112/5100 at 2” (6/8 circlip, 3/8” top spacer, sway bar drop bracket, YotaWerx Black Hawk 2.0 tune, Borla Pro XS exhaust, Freedom Off-Road UCA’s, Alphrex Luxx Series smoked taillights, Westin bull bar, 265/65r18 Cooper Rugged Trek tires, 18x9 Anthem Off-Road wheels -12 offset, 4.5 backspace. Rock Sliders that I fabricated.
    Yeah, But did you originally think that it was fine? I can’t imagine how you must’ve felt when you found out! :annoyed:
    Jakerou likes this.
  6. Jul 9, 2024 at 8:14 AM
    Amocat15
    Bucks County, PA
    2021 DCSB TRD OR
    Ha! Yeah I was a little concerned but the tires were fine, everything worked and engaged as designed. A few years later I changed the transfer case and diff fluid and the fluid looked fine. I just figured it was a robust system and could take the beating it took for a week!
  7. Jul 9, 2024 at 8:17 AM
    Josephray70
    Joseph
    Grand Rapids, MI
    Wow! very impressive.
  8. Jul 9, 2024 at 8:30 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    :facepalm::gossip: Didn’t you notice that most of the posts in here about grenaded differentials were from guys blaming their :angrygirl: ‘s while driving their trucks in 4wd? I don’t buy it though.
  9. Jul 9, 2024 at 8:37 AM
    mrzip
    mrzip Well-Known Member
    USA
    2023 Off Road, 2010 Off Road
    I have always driven on a straight road for about a mile.
  10. Jul 9, 2024 at 8:42 AM
    Josephray70
    Joseph
    Grand Rapids, MI
    Be a good idea to educate the wives then!
  11. Jul 9, 2024 at 8:44 AM
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    The CV boots have nothing to do with it.
    But yea, a mild bend in the road won't grenade your front diff.
    If the truck starts slowing down and bucking during a turn you'll know you're messing up.
  12. Jul 9, 2024 at 8:45 AM
    OnHartung'sRoad
    I do know one thing, the 4wd maintenance interval is a very good excuse to get out to play more often!:mudding:
  13. Jul 9, 2024 at 8:58 AM
    M85
    M85 Well-Known Member
    Colorado
    2019 SR ACLB
    Did you have the driveshaft U joints greased recently? After greasing them, they will fling grease on everything for a while. I can't remember if it hits the exhaust, but it probably does. Makes a mess no matter how well I try to wipe out excess grease with a rag.
  14. Jul 9, 2024 at 9:01 AM
    Josephray70
    Joseph
    Grand Rapids, MI
    I just greased my Zirk fittings two days ago! On the front shaft. That’s the only one that had fittings. You sure knocked that diagnosis out of the park! Thank you
  15. Jul 9, 2024 at 9:20 AM
    #35
    M85
    Colorado
    2019 SR ACLB
    I usually floss the U joint with a rag after greasing it, but it's still hard to get all the extra grease out. I'm glad there's a simple explanation.
  16. Jul 9, 2024 at 9:22 AM
    #36
    Josephray70
    Joseph
    Grand Rapids, MI
    Yeah, I don’t know why I didn’t think of that. Back you joint is right next to the exhaust. I had to remove the heat shield to get to it better. this makes perfect sense.
  17. Jul 9, 2024 at 9:28 AM
    #37
    Clearwater Bill
    Billy
    Largo Florida
    That someone would even consider choosing a FB page over the Owner's Manual.........
  18. Jul 9, 2024 at 9:30 AM
    #38
    Sand_In_My_Taco
    Sand_In_My_Taco Well-Known Member
    NOR*CAL
    2025 1794 Tundra TRD-OR
    This was your drivetrain binding. If you push it things can break.
  19. Jul 9, 2024 at 10:22 AM
    #39
    nevertoomanytacos
    3rd Gen
    Agree 100%. That is why I backed off on the turn radius and power...
  20. Jul 9, 2024 at 11:33 AM
    #40
    BumfukKansas
    BumfukKansas Well-Known Member
    Out here Tucker - the big brown dog - and I often go for rides at the end of the day to just, well, see what's out there.
    Sunny, rain, snow, whatever.
    There're places out in these parts where I can go straight for quite a few miles on pavement and sometimes, depending on the direction of course, even into the next county.
    If I take the gravel roads, which I nearly always do, I can drive straight as a stick for 10 miles and be in another state.
    But then living out here means I exercise my 4x bits and pieces fairly often.
    As always, another interesting thread...at least for a simple guy like me...here on Tacoma World.
    Happy Motorin' to all.
    Josephray70[OP] likes this.
