4WD Requirements
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2021SR5V64WD, Sep 10, 2021.
  1. Sep 10, 2021 at 10:17 AM
    2021SR5V64WD
    2021SR5V64WD [OP] Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    So in general, what is yall's thoughts on invoking 4WD. To be in compliance
    with the recommended 10 miles a month is simply going on a gravel/dirt
    road with slight inclines enough? Even if not really needed will invoking 4WD
    on such an area harm it ? I'm talking about hard-pack & small stretches of
    loose gravel.
    I have access to a few places with some slight hilly spots where I go over and
    back into and invoke slants but nothing fantastic.
  2. Sep 10, 2021 at 10:21 AM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    If I'm not going to be on a trail for a while, I'll just turn on 4wd on a one mile straight stretch in my neighborhood a few times a month.
  3. Sep 10, 2021 at 10:24 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Also, the 2Lo Mod (2LM) makes this even easier.
  4. Sep 10, 2021 at 10:24 AM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
  5. Sep 10, 2021 at 11:05 AM
    TRD__Chris
    TRD__Chris Well-Known Member
    STL
    2016 Sport
    I have a long stretch of road in my neighborhood and I TRY and remember to engage 4WD once a month. Sometimes I forget, but I don't lose any sleep over it.
    I would bet that the majority of 4x4 Tacoma owners, especially the ones who are not on TW, probably never engage the 4WD as stated in the manual
    Lt. Dangle, Thunder Fist and oconnor like this.
  6. Sep 10, 2021 at 11:24 AM
    su.b.rat
    su.b.rat broken truck
    use it on rainy days on straight stretches of highway. turn it off before curves & turns. the use it or lose it idea applies to the actuator as well, so it also needs regular exercise, don't be afraid to turn it off & on regularly.
    VXEric, Speedfreak and shakerhood like this.
  7. Sep 10, 2021 at 12:09 PM
    2021SR5V64WD
    I know of 2 guys on my street with 2017's neither of them have ever used their 4WD.
  8. Sep 10, 2021 at 12:18 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That would be a fun experiment to monitor.
    IMHO, the owners manual recommendation is pretty sensible, esp considering the actuator issues that have come up around here. Not rampant, but enough to think that some easy PM makes a ton of sense.
    blu92in99 and oconnor like this.
  9. Sep 10, 2021 at 12:23 PM
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    You’re in Phoenix if I recall. There are generally dirt roads and trails within 30-45 mins of most places out there, to the point that when I was working out there a couple of years ago I had to put A/T tires on my work truck since I always seemed to be on dirt roads. Find an area near you and go explore! :thumbsup:
  10. Sep 10, 2021 at 12:38 PM
    Jackie Moon
    Jackie Moon Well-Known Member
    CO
    2021 DCSB OR 6MT
    As others have said, just hop on a stretch of the ol 1mi grid and click it over, then back after a mile or two before turning off and heading home. I'd be surprised if mild curves on the road were anything to worry about, there's a differential in the front after all! Just don't take sharp city-street turns on dry pavement, or ya know, try to squeeze into a tight parking spot. Subaru techs and tire shop folks always told me to replace all 4 tires at once on my Impreza due to rotational speed differences being CATASTROPHIC for the drivetrain. My old boss once quipped back with "do you think they care about that in the outback?"
    Thanks for the reminder though, I need to do this today since I've had no chance to actually use my 4WD since buying it earlier this summer!
    I'm also prepared to be shat on for suggesting it's not a big deal to turn the wheel a little bit on dry pavement in 4WD. Watch that old WWII-era GM educational video about how differentials work, and your mind will be at ease.
  11. Sep 10, 2021 at 12:44 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Sorry, but it has nothing to do with the diffs. Its the locked T case with the front axle following a different turn radius than the rear axle, which can bind the driveline.
    In a part-time 4WD system, like ours, different tire diameters can bind the driveline also. A lot of different things can cause a different diameter, like inflation pressures.
    It is all minor like you said though. Driving on a dry, straight section of road is fine. The 2LM is better. Loose surfaces are the best.
    Note that all tires scrub, even on dry pavement. If they didn't we wouldn't have tire wear to start with. :D
  12. Sep 10, 2021 at 12:51 PM
    Jackie Moon
    CO
    2021 DCSB OR 6MT
    No apology necessary! I just don't think anyone should be losing sleep over a few gentle curves while keeping their 4WD system exercised between "good" opportunities. There's no way to keep all those variables perfectly balanced anyway, and TW often implies these trucks are made out of glass, and that just ain't true. We're all just trying to live in the real world, ya know?
    Thunder Fist and tonered[QUOTED] like this.
  13. Sep 10, 2021 at 12:54 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Right on!
    The Tacos are much more stout than we think.
    willie2 and Jackie Moon[QUOTED] like this.
  14. Sep 10, 2021 at 12:59 PM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    I have an excuse to tear through a gravel road when I go to work.
    Thunder Fist likes this.
  15. Sep 10, 2021 at 1:11 PM
    MAD777
    MAD777 Well-Known Member
    White Mountains, NH
    2021 Tacoma SR5 4x4 Double Cab 6' bed
    I have a 500' dirt driveway on a 20% slope uphill to my house in the snowy White Mountains of NH. Without 4wd, I'm not getting home!
    :eek:
  16. Sep 10, 2021 at 2:01 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Could you rub in your good lives just a bit more? :D
  17. Sep 10, 2021 at 2:08 PM
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    I like to engage the rear diff lock every so often also.
  18. Sep 10, 2021 at 2:23 PM
    MAD777
    White Mountains, NH
    Why does this sound kinky? :censored:
  19. Sep 10, 2021 at 9:14 PM
    slowtacotruck
    17 offroad
    stuff
    I like to have a good time
  20. Sep 10, 2021 at 9:36 PM
    2021SR5V64WD
    You're easy but you're not cheap right ?..
