4wd sharp turn on pavement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by zhaoz, Mar 13, 2009.
  1. Mar 13, 2009 at 6:37 PM
    zhaoz
    zhaoz [OP] Member
    2009 DC SB OR 4x4 silver
    I did something stupid.
    I am new to the truck world and 4wd. Today it was raining very hard here in austin, texas. When I was driving my 09 tocoma 4x4, I decided to try the 4wd out.
    I read the manual before and know it's ok to switch between 2Hi and 4Hi "on the fly" as long as at speed below 62 mph. During driving on wet pavement I switched a few times, I didn't really feel anything bad I even drive in 4Hi on highway at 65mph for about 15 minutes. However, when I was making sharp turns and parking at a parking lot in 4Hi, in at least 3 occasions, I felt the steering is really hard and the truck slided sometimes. Now I know I shouldn't drive my truck that way and part time 4wd is not designed for pavement. Too bad the manual doesn't say that.
    Anyway, what the worst I should expect to happen? Is there anything that I can check for the damage that may already be there?
    :mad:
  2. Mar 13, 2009 at 6:39 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    nothing bad happens, just dont do it often. Thats just your truck pushing your front tires sideways since the front is "locked" into 4wd.
    Marc70 and WSW3 like this.
  3. Mar 13, 2009 at 6:44 PM
    zhaoz
    zhaoz [OP] Member
    After driving I read a little bit about 4wd and realized what was wrong.
    Plain Jane Taco and kimo like this.
  4. Mar 13, 2009 at 6:50 PM
    RobK
    RobK Well-Known Member
    WI
    07 4x4 DC SR5 w/Tow
    TRD offroad/racing Intake, pioneer bluetooth headunit, wetsuit seat covers, weathertech floorliners, Bully side step bars, tailgate security mod, rear aux halogen lights, BHLM, Upper and Lower Grillcraft Grills, Relocated Horns, Mag-lite mounts, pop lock, truxedo tonneau, PUTCO window visors, spidertraxspacers f&r, , bilstein 5100s set @ 0 with stock coils in front and TSB AAL in rear w/ 5100s .
    Definitely, do not use 4wd on dry pavement, unless you plan on driving in a perfectly straight line. If your tires aren't allowed to give a little, be it on gravel, dirt, snow, etc., the drive shaft will experience a torque caused by the front and rear axles rotating at slightly different speeds. If the drive shaft were strong enough, and your tires didn't slip on the road, and you decided to take a turn going 65mph, your drive shaft could build up enough spring force from being twisted, that the truck would flip itself to release the torque. In a real world situation, you would probably just break a u joint or another part of the drive line if the tires weren't allowed to slip. This is why they advise you not to drive 4wd on dry pavement.
    CMD-KY, Tankman, Marc70 and 2 others like this.
  5. Mar 13, 2009 at 7:05 PM
    bmkshort
    bmkshort Active Member
    southeast virginia
    09 d-cab 4x4 offroad
    Good explanation!!!!!!!!!!!!!!!!
    Marc70 likes this.
  6. Mar 13, 2009 at 7:07 PM
    TacoTurd
    TacoTurd Defying Alliances since 2007
    Central Texas
    07 PreRunner TRD Sport
    TRD Exhaust, TRD CAI, Bull Bar, PIAA lights, Passport, Bed Mat, UWS Toolbox, Hood Struts, Rear TSB, TRD/Okole Seat Covers, Hellwig Rear Sway Bar, Burned Carpet, Nasty Dent in Roof
    Patient: Dr! Dr! It hurts when I do this.
    Doctor: Don't do that.
    blefferd, Bebop and Torspd like this.
  7. Mar 13, 2009 at 7:11 PM
    RobK
    WI
    07 4x4 DC SR5 w/Tow
    I didn't go to college for nuthin'
  8. Mar 13, 2009 at 7:27 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX/ Lawrence, KS
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights
    haha precisely :)
  9. Mar 13, 2009 at 7:32 PM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2009 DC V6 TRDsport
    5100's all around - fronts at 1.75", 265/70/17 Bridgestone Revo 2, HID headlights and fog lights, factory skid plate, ss exhaust tip, tube steps, Access roll-up tonneau cover, Redline hood struts, 6 D-rings, seat MagLite, LED dome, fumoto oil drain, DTRL, fog light anytime, Kenwood/Clarion speakers, Pop-N-Lock 5300, LED bed lights and a few other things...
    I've never turned going that fast but do turn in 4wd and feel the 'push'. Sometimes you can't avoid it.
    If theres snow on the ground, I will use 4hi to pull out of a driveway or something. I have to turn onto the road, which is clear and I feel the push. Once I straighten out, I drop back to 2wd.
    I don't think there is any other way to do this and can't imagine i'm going to twist a drive shaft doing this...right? I don't do it often but sometimes you have to and it is always at a crawling speed.
  10. Mar 13, 2009 at 7:39 PM
    zhaoz
    zhaoz [OP] Member
    Thanks for all your inputs...I've learned the lesson. I did drive at 65 mph for about 20 min and make several 90 degree turns at about 10 mph and park in the parking lot for a few times on the wet pavement.
    I actually do not feel anything wrong right now, but some parts on my truck may need replacement/repair sooner than they suppose to be. Is that the situation I am in right now?
  11. Mar 13, 2009 at 8:18 PM
    RobK
    WI
    07 4x4 DC SR5 w/Tow
    At crawling spd you should be fine. I have had trucks on dry pavement in4wd and if the tires do not give and u are going slow, the drive line will bind up and stop the truck. U will most likely do no damage at crwling speeds
  12. Mar 13, 2009 at 8:54 PM
    zhaoz
    zhaoz [OP] Member
    Maybe in my case, the tires actually gave because of the water/moisture on the pavement. I felt bumps a few times at some turns but the truck continued to move slowly. I also felt the steering heavier.
    It was the first time I tried a 4wd, there was actually nothing scary enough to make me think it was not normal, I had no idea on what it should be. After the driving, I was thinking 4wd is rough.:eek:
  13. Mar 13, 2009 at 9:57 PM
    RobK
    WI
    07 4x4 DC SR5 w/Tow
    Just try to use it for offroad and snow. And remember u will have understeer aka front tires will push or plow when turning
  14. Mar 13, 2009 at 10:25 PM
    zmtnbik
    zmtnbik FMLYHM
    4x4 Trd Off-road
    Donahoe (Icon) C/O, TC UCA's, Dakar leafs, BilStein 5125's, 285/70/17 BFG MT KM2's, Raceline Renegade 17x9's, u-bolt flip kit, debadged, TRD CAI, TRD exhaust, URD MAF controller, 20% front window tint, 3M clear bra on bumper, cam locks in all storage compartments, fog light mod, Alpine X100 deck, Co
    Locked is a little misleading, as nothing is locked, but rather engaged. Not to mention there is no locker in the front.
    Post #4 described it best http://www.tacomaworld.com/forum/2nd-gen-tacomas/30209-4wd-sharp-turn-pavement.html#post464071
    It's just the binding of the front and rear, with no slip in the transfer case, which AWD vehicles have, hence the reason they do not bind like part time 4x4
  15. Mar 14, 2009 at 4:41 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I drive mine at 65mph when it rains just to keep the 4WD system running and lubricated (so to speak). But as soon as I get on the exit ramp, I'm back into 2WD. Going straight is one thing but making turns is a bad thing on pavement.
    Have you engaged/disengaged 4WD since? If you're able to get back into 4WD without any problems - then I'd say, your truck is OK. I'm sure you didn't mess something up.
    Making tight turns in 4WD is NOT good anytime or anywhere. CV joints don't like that.
    Anytime you find the truck bucking, hesitating, or acting weird while in 4WD - don't push the issue. Back off....straighten the wheel out, go in reverse, take it out of 4WD whatever. Don't ever force it againest its will!
    Marc70 likes this.
  16. Mar 14, 2009 at 8:31 AM
    RobK
    WI
    07 4x4 DC SR5 w/Tow
    AWD drive vehicles have a center differential between the front and rear to allow for the two axles to rotate at different speeds. true 4wd does not have this, as mentioned above. check out this link for further explanation.
    http://auto.howstuffworks.com/differential1.htm
    Marc70 likes this.
  17. Mar 14, 2009 at 2:07 PM
    zhaoz
    zhaoz [OP] Member
    Thanks man. Yes I still be able to engage/disengage 4WD. In 2WD I don't feel anything wrong. The ride is still smooth without abnormal noises as far as I can tell. Acceleration and shift of gear feel normal too.
    I call my dealer today. He suggests me to drop the truck to him for a inspection. Too bad I am too busy so I have to wait to next Friday or so to have time to do that. I will keep normal driving in 2WD until then. I hope nothing serious will happen.
    I will keep you guys informed.
    The last question, if there is already something damage, let's say the CV joints, or some part in the drive-line, what typical signs should show up? noise? vibration? being unable to turn? being unable to engage/disengage 4wd?
    Sorry about the stupid questions, this is my first truck and my first 4wd, I am trying to learn.
    Do you guys think it will be safe to drive in 2wd until I have time to have it inspected?
  18. Mar 14, 2009 at 2:31 PM
    dpd327
    dpd327 Member
    Jim
    Everett, Washington
    2009 TRD Sport Double Cab SB 4X4 w/TRD CAT/BK
    Goodyear Wranglers, De-badged, Aviation Radio added (VHF and Marine band)
    zhaoz,
    You can drive the truck in 4 wheel high you just can't go crankin the steering all over the damn place! I routinely pull my 1994 up into 4 Hi on dry pavement just to get the oil moving about especially during Summer months.
  19. Mar 16, 2009 at 8:55 PM
    zhaoz
    zhaoz [OP] Member
    My service manager arranged a technician to inspect the vehicle. He told me that the technician test-drove the truck and visually inspect the bottom of truck and didn't find any problem; he also read the computer for error codes and didn't find any. Basicly, he thinks my truck doesn't appear to have any problem.
    I hope he is correct but anyway I have learned "no turn on pavement in 4wd" and it's time to move on.
    Thanks again for all your inputs.
  20. Aug 17, 2009 at 8:28 AM
    tig1
    tig1 Well-Known Member
    Paul
    Saint John,New Brunswick,Canada
    2009 tacoma
    n fabs,window visor tonneau ,bilstein 5100's all round.245/75R16Toyo A/T II
    Hi! Tig1 calling--so the manual says to run in four wheel drive for 16 miles
    to lube up the parts.but I don't have that kind of area to drive in.so running it on pavement in a straight line is ok? does it have to be that far? what about 4wd in low?:confused:
