4wd steep grades
Discussion in 'Off-Roading & Trails' started by [eric], May 17, 2009.
  1. May 17, 2009 at 8:30 PM
    [eric]
    [eric] [OP] Well-Known Member
    Eric
    Bend, OR
    2005 Tacoma TRD OFF Road
    what is the steepest grade you guys have taken the tacoma out on? on a narrow 4wd drive road I came across a big hill. about 25 degrees average. the steepest parts was about 30 degrees and the uphill climb is about maybe a bit more then a mile.
    i was about to throw it in 4lo when i noticed other trucks and jeeps parked at the bottom and decided i should probably do the same.
  2. May 18, 2009 at 12:01 AM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    It really depends on how much traction is available. Moab Utah has slickrock terrain, its like sand paper, you could drive a honda civic up a 45* climb there. It also depends on if it's the kind of climb that will allow you to maintain momentum; if there is a turn or a step you'll have to slow to negotiate it and you'll have to depend on traction and no momentum. Likewise, a taco on a sand dune without any momentum isn't getting up a 15* climb.
    Back to traction: a V6 Taco in 4lo1 could climb a wall if there was enough traction. It'd be pretty tough to flip a taco over vertically, BUT if you bounce it and get sideways it will roll if too steep. I've side-hilled some stuff at about 30* no problem.
  3. May 18, 2009 at 12:30 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I don't know how steep they were, but i've had my rear end get pretty light going down a few hills. One was a little off camber and when my driver's front tire dropped off a 6" high rock ledge, the passenger rear(most uphill tire) lifted off the ground for a second. It was about as sketchy as I'd ever like to get.
