4wd stuck in snow
Discussion in 'Off-Roading & Trails' started by [eric], Mar 2, 2009.
  1. Mar 2, 2009 at 3:07 PM
    [eric]
    [eric] [OP] Well-Known Member
    Eric
    Bend, OR
    2005 Tacoma TRD OFF Road
    I got my tacoma pretty stuck in the snow this weekend. I was doing some backcountry snowboarding at past Marble, CO and parked my car at the entrance to what i think is Scofield pass. In the morning the snow was pretty firm, i didnt think about it softening up through out the day.
    instead of backing the truck up, i thought i could turn into scofield entrance and circle myself around. there was this parking lot right there. I kinda wish i took pics just now trying to explain all this in words.
    well to get the point, my truck sunk...bad. i have 05 tacoma with 32" BFG AT's. the more i tried to power out, the deeper my truck sunk. rocking it back and forth did nothing. by now i was stuck up the the bottom of the driver door.
    my question is when i am in 4wd why was only my driver side tire spinning? even in 4lo the other three tires did not move at all.
    at the end, it took 6 snowmobilers , a lot of shoveling, and a huge truck to pull me out. the force of the it actually bent my hitch a little.
  2. Mar 2, 2009 at 3:10 PM
    NicksRig
    NicksRig Well-Known Member
    Kenora, Ontario
    07 Tacoma DC TRD Sport
    Blacked out Skid plate, block heater, bug deflector, blacked out headlights, tinted fronts, OME 3" lift, Toytec AAL, Revenge-Fab Sliders, K&N Air Filter
    Do you have the sport? Did you try 4low? Air down the tires?
  3. Mar 2, 2009 at 3:27 PM
    [eric]
    Eric
    Bend, OR
    no sport, just the trd offroad. i did try 4LO. do difference. I did think to let some air out of the tires. I dont think it would have done anything, but i have also never tried that at all.
    over 50% of all were buried in the snow. it was not light fluffy, but was a little bit wet and packed in to ice.
    i thought with 4wd all the tires would be spinning regardless of traction. like the extra resistance when making slow sharp turns in 4wd. i am pretty sure i dont have traction control.
  4. Mar 2, 2009 at 3:37 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    with 4x4 and the locker engaged 3 wheels should spin. just 4x4 and no rear locker = 2 wheels spinning
  5. Mar 2, 2009 at 5:19 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    It sounds like maybe you might have broken 4x4. In 4hi or 4lo when stuck in snow (or wherever the wheels are slipping) you should have 1 front tire spinning and 1 rear tire spinning. Sinch you have the TRD OR you should have put it in 4lo and engaged the locker, then you would have had 3 wheels moving, 2 rears and 1 front.
    In snow and soft stuff, the second you feel you are getting stuck you need to change the circumstances getting you stuck, whether that means speeding up to get momentum or slowing down so the tires get traction; put it in 4, hit the locker, aidown the tires to 10-15PSI, change something. If you just keep on trucking at the same speed etc that got you stuck all you are doing is digging deeper and packing the snow under your rig into cement.
    If only 1 tire was spinning, you either didn't properly engage the 4x4 or it's broken. Also, all 4 tires will only spin if you have a locker in the front and rear, which you don't (you should have a rear though, it's the only reason to get TRD OR...) (it the button that says "RR DIFF LOCK" or something like that, and you need to be n 4lo to use it)
  6. Mar 2, 2009 at 8:58 PM
    [eric]
    Eric
    Bend, OR
    my girlfriend who was standing on the outside the whole time just tells me that everytime she looked there was two tires spinning, but it was diagonal tires, not two on the same side. like the driver front and the passenger rear or the passenger front and the driver rear. she said they were trading off. one diagonal then the other.
    does that make sense, is that what should have happened. i would think it would be the front axles spinning or the rear.
    i did try 4low but i did not hit the rr locker button.
    if my 4wd was broken or not properly engaged, then i would think the driver side front tire would never be spinning.
  7. Mar 2, 2009 at 9:07 PM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    It sounds like you high centered yourself on the snow... Ask LonghornTaco all about that. As for the locker, that's the whole point of the Off-road package, use it!
  8. Mar 2, 2009 at 9:13 PM
    jwscoot
    jwscoot Well-Known Member
    Mississauga, ON
    98 Tacoma v6 4x4
    Bilstein 5100 shocks all the way around, add a leaf in the rear
    I'm amazed people that have the locker have no idea what it's for.... if I saw some random button in my truck that I had no idea what it was for I think I'd want to find out what it was all about....
    esp that button!
  9. Mar 2, 2009 at 9:14 PM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Hehe...
    When it happened to me, I don't think I ever engaged 4wd until after I was stuck. Didn't do me much good. Had to be pushed out by another truck...
  10. Mar 2, 2009 at 9:24 PM
    [eric]
    Eric
    Bend, OR
    i just got the truck a few months ago. any tips would be great. thanks
  11. Mar 2, 2009 at 9:25 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    Sounds like it was working, the tire with the least resistance on each axle will spin.
    Forgot to add, you need to be in 4Lo for the Diff Lock to work
    Hit the Diff Lock next time and both tires on the rear will have power regardless of one having more traction or not.
    Another lesson you should take home from this is don't wait til your leaving to turn your truck around, I always park it with an easy exit in mind, you never know if conditions are gonna change or if you need to leave in a hurry due to an emergency
  12. Mar 2, 2009 at 9:45 PM
    jwscoot
    Mississauga, ON
    98 Tacoma v6 4x4
    what he said!
    RR locker, Locks the rear axle so that both wheels are delievered power so you'll get 3x4 (3 wheels get power(2 rear and 1 front)) as opposed to 2x4 (2 wheels(1 per axle)) in 4wd....
    a normal 4x4 with open differentials will send power to the 2 wheels (one front and one rear) with the least ammount of traction. (thats what was happening to your truck without the diff locked)
  13. Mar 2, 2009 at 10:08 PM
    darkturtleninja
    darkturtleninja 9th level dungeon master
    Illinois
    95 2.7 3rz turd
    cold air intake, body lift, suspension lift.
    so not to take the attention off of anybody else but.... how should my drive train act in my 95 with locking hubs in the front???? i havent had any problems yet... i was chewing through 13" inches of snow like it wasnt even there...
    so do both of my front tires spin or what.... i know only one of my back tires spins....
  14. Mar 2, 2009 at 10:49 PM
    jwscoot
    Mississauga, ON
    98 Tacoma v6 4x4
    if you have the trd.. with the locker engaged in low the 2 rear wheels will spin and one of the front wheels will spin.
    you'll need to add a front locker such as the arb to make all 4 wheels spins together.
  15. Mar 2, 2009 at 11:38 PM
    nvdeserted
    Reno, NV
    That's good... well the fact that 1 front and 1 rear were spining, that means your 4x4 is working perfectly.
    Get out your manual to learn about the locker. On my 09 it needs to be in 4lo and at 0-5 mph I can hit the RR DIFF LOCK button and it engages the locker until I hit the button again to disengauge it. There should be some kind of indicator that lights up in your gauges, probably near the one that indicates you're in 4x4; if it's flashing/beeping it hasn't yet engaged. Read up on when to use it, BUT if nothing else try it when you're stuck!
  16. Mar 3, 2009 at 3:39 AM
    darkturtleninja
    Illinois
    95 2.7 3rz turd
    naw man its non trd its only a 95 4x4 the first year the tacoma came out... manual shift transfercase.... the rear is non locking... i was just wondering how the front acted with the lockouts...
  17. Mar 3, 2009 at 5:28 PM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    ^ Locking hubs do only that, lock the hubs. The differential is still open so only 1 wheel spin unless you have a locker put in.
  18. Mar 3, 2009 at 5:59 PM
    nvdeserted
    Reno, NV
    Right, locking hubs just "connect" the front wheels to power, same thing as "push button 4x4" the button just locks the hubs for you basically. A locking differential is what makes both wheels spin at the same rate constantly... I'm pretty sure no U.S. vehicle comes stock with a front locker, at least anything street legal.
    Locking hubs and locking differential are completely different things.
  19. Mar 3, 2009 at 6:18 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    So, i'm with all the other guys here..... use the RR diff lock! Without it, your 4x4 is only a 2x4 as one front and one rear tire will spin with the differential open. Therefor, It would have given you 50% more traction by having both rear wheels locked together and could have possibly gotten you out(if you didn't bury it to the frame before you engaged it)!
    Here is a pic of my Taco stuck in the snow at 1am when 4wheeling with some friends. It took an hour and a half to get both our trucks out(my buddy that tried to pull me out got stuck trying to just get to me) but we were mostly prepared with multiple tow straps, a come-a-long, and shovels. I now own a 9000lb Warn multi-mount winch so recovery will be much quicker from now on.
  20. Mar 4, 2009 at 12:08 AM
    darkturtleninja
    Illinois
    95 2.7 3rz turd
    damn bro... that looks like alot of frickin snow!!! how much accumulation did you have there???
    my sig was my taco in the 13 inches i was talking about... i had no problems getting around... although i did get hung up once.. and that was in a "snow wake" that a city truck had made with a plow.... i just backed up a lil and gave her hell and got through with no problem...
