4wd stuck on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomarty, Feb 1, 2010.
  1. Feb 1, 2010 at 4:40 PM
    tacomarty
    tacomarty [OP] Member
    new-brunswick canada
    05 reg cab 4wd lifted
    toyo open country,3'' revtech lift, procomp 1079 alloy
    hello! not sure if anyone can help me.For the first time today, when putting my truck on 4wd while runnin(around 20mph), the 4wd light would start flashing and truck woud stay in 4 hi even with switch turned off. after turnint truck off for a while,it will unlock itself and light would shut off. any suggestion anyone? thanks in advance..
  2. Feb 1, 2010 at 4:42 PM
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2016 F150 Lariat 4x4
    5100s (2.5" front), OEM Raptor wheels, 315/70/17 BFGs, Undercover, tint, Weathertechs.
    I think if the truck still senses a load on the transfer case, it won't shift out of 4WD. Did you try taking your foot off the gas and coasting? That always makes it quicker for mine. If that doesn't help, it may be your actuator or sensor?
  3. Feb 1, 2010 at 4:48 PM
    tacomarty
    yup, i have tried this without succes.
  4. Feb 1, 2010 at 9:43 PM
    hammerdog
    hammerdog Well-Known Member
    My 08 Tacoma did the same thing last month during freezing cold weather. I fixed it by leaving it in the driveway running for about 30 minutes. Once it warmed up on the asphalt, it shifted back into 2WD without any problem.
  5. Feb 2, 2010 at 7:36 AM
    09sportowner
    09sportowner Well-Known Member
    Texas
    09 Sport
    Can I guys imagine the amount of problems you'll have later on if you're having problems with a new ride. Sure glad I got a prerunner!!!
  6. Feb 2, 2010 at 8:44 AM
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    was it the first time in 4 wheel drive? it smooths out the more you use it i have found out.
    no problems with my 4x4 and glad i had it cause i would have been stuck a bounch with a prerunner in the past couple of snow storms:D
  7. Feb 2, 2010 at 9:15 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    No problems here in Canukistan. -35ºC, never had an issue with it sticking ever.
    Sure glad I didn't get a PreRunner!
  8. Feb 2, 2010 at 9:27 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Whats the milage on the truck and when was the last time 4wd was used? Plus when was the last time oil was replaced in transfer case in front diff.
    If 4wd is not used for long time it tends to stick a little. Usually finding straight gravel road and driving truck while turning 4h on and then off will get things moving again. If problem persists you can always unbolt 4wd switch and either grease up or replace.
  9. Feb 2, 2010 at 12:53 PM
    tacomarty
    i use my 4wd all the time, as we have lots of snow around here..altough, i got to work this morning and everything was back to normal, tried it several time, and everything's fine. was about -35 celcius last night so u prbly right hammerdog.
  10. Feb 3, 2010 at 5:33 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    -6ºC and super foggy all round.
    Pretty much a set up for Silent Hill.
  11. Mar 28, 2010 at 4:51 PM
    tacomarty
    here we go...my truck started acting again last night, could not get it in 4wd at all..temperatur was below freezing point...today in warmer weather, worked just fine.
  12. Mar 28, 2010 at 4:57 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    This might be a semantics thing- but
    Order of Events:
    Turn Knob
    Light Flashes
    Turn Knob Back
    Light keeps flashing
    Am I getting that right??
  13. Mar 28, 2010 at 5:04 PM
    tacomarty
    yup! that's right
  14. Mar 28, 2010 at 5:12 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Well...If the light never went solid-Then 4Hi was never engaged....That's the first issue.
    Figure that out and then go from there....
  15. Mar 28, 2010 at 5:19 PM
    tacomarty
    i know..that's a new problem.originally it wouldn't dissengage, last night, it didnt want to engage at all
  16. Nov 27, 2012 at 5:51 PM
    SGT Taco
    SGT Taco It all fun and games till its not.
    Scott
    Spring Hill TN.
    R.I.P. 2007 TRD, Land Rover Disco II, F250.
    Wife rolled it 3x mod...
    FYI: was doing some wheeling today and when I tried to switch out of 4lo it just beeped at me... tried everything I could think of, ended up driving it all the way home in 4lo.
    Also, I could not get it out of park without pushing in the little button, the gear selector indicator on the dash was not showing anything, and my turn signals were not working.
    As it turns out the IG1 fuse under the dash(#32) blew. It is for the Back-up lights, air conditioning system, passenger airbag manual on-off switch, and SHIFT LOCK SYSTEM.
    What happened is I must have shorted out the back-up light circuit at the already broken trailer harness when I dragged it on a nice drop-off.
    I hope this helps someone out of a jam... Driving home in 4LO for 10 miles sucked!
  17. Nov 27, 2012 at 5:58 PM
    bamma
    bamma Well-Known Member
    Spokane, WA
    Current: 2016 Land Cruiser, 2023 Tundra TRD Pro, 1988 FJ62 and 2020 4Runner Limited
    Back the truck up.
  18. Nov 27, 2012 at 6:00 PM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    What size fuse is it? For people's further knowledge.
  19. Nov 27, 2012 at 9:00 PM
    SGT Taco
    Scott
    Spring Hill TN.
    It's a 10A fuse...there are a couple spare fuses in the engine compartment fuse box, or else you can always pull a fuse from a circuit that you don't quite need to get home like the #29 PWR OUTLET, #35 WSR (wiper/washer), or any of the power window fuses (#30, #33, #34, #36) make sure if you put a fuse of a different rating you go up in amperage not down but by no more than 50% for fast blow fuses to reduce the chance of damage to the electrical system and make sure to replace any and all fuses to there originals rating.
  20. Nov 27, 2012 at 9:05 PM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    Fuckin truth.
    My buddies 4hi got stuck and we freaked out trying to get it to unfuck itself (2 hours from anything resembling a town).
    Sure enough, some random forum online said that a stuck 4wd will disengage if put in reverse. (thank god for Verizon and smartphones)
