4wd System Operation & Help Thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dm93, Oct 27, 2021.
  1. Aug 20, 2022 at 9:51 AM
    #181
    Dm93
    Dm93 [OP] Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Have you tested the 4wd detection switch (should have continuity through it when the little ball on the end of the switch is pushed in).
    You could also still be a tooth or 2 off on the gear.
  2. Aug 20, 2022 at 10:04 AM
    #182
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yea unfortunately everything is going to fully electronic, todays generation just want to push a button or flip a switch and have everything happen for them instead of pulling a lever.
    Although I don't really see too many issues with fully electronic 4wd systems, much better than the early vacuum ADD systems that many manufacturers used and Ford still uses.
    Many of the problems that happen to electronic systems are from lack of use and on Toyota's from the vent lines cracking or falling off the actuators.
  3. Aug 20, 2022 at 1:00 PM
    #183
    06RegCab1
    06RegCab1 Well-Known Member
    Wyatt
    Maui Hawaii
    2006 Regular Cab, 2.7 5 speed mt, 4x4
    Raptor lined basalt gray CBI off road moab 2.0 bumper steel CBI off road ifs skid steel Home made high clearance rear bumper McNeil racing +2" fiber glass fenders Cali Raised LED fog's (flood, amber) Arb air locker, 5.29’s Alpharex headlights 17" Stealth Custom Series Ray 10 35x12.50r17 MTZ’s King 2.5" extended travel coil-overs 650lbs springs AccuTune valving Total Chaos UCA's King 2.5" RR rear shocks Icon RXT Leafs Down south motorsports extended brake lines MagnaFlow Catalytic Converter MBRP Cat Back Exhaust 2.5" axle dumped LCE Heavy Flywheel URD ST shifter AJT design 5spd shift knob Sundown Audio SA 6.5 sub Audio control 4 channel Skyhigh car audio 6.5’s and 1” tweeters Lots of second skin sound deadoner
    I haven’t tested that individually yet, I’ll go ahead and give that a run once the truck cools down. Having the truck as my only daily makes things so much more annoying trying to figure things out
  4. Aug 20, 2022 at 1:44 PM
    #184
    06RegCab1
    Wyatt
    Maui Hawaii
    Switch is good. I feel like I’m getting closer, so that leaves actuator timing? In my mind that makes me think to get the timing right, I could shift it by hand to 4x4 and use the switch to tell me when In the proper position from a continuity test? Or am I over thinking something
  5. Aug 20, 2022 at 2:03 PM
    #185
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I've yet to have one apart but reading about others doing it it seems alot of trial and error is involved, you want the contacts of the drive gear plate to line up with the contact plate as shown depending on the position the transfer case is in.Transfer Case Actuator.jpg
  6. Aug 20, 2022 at 3:11 PM
    #186
    06RegCab1
    Wyatt
    Maui Hawaii
    I got 4 hi back!!! 4 low isn’t working but I’m taking this as a win. 4x4 sensor had an internal wire brake near the plug, I just so happen to have a spare at my disposal and got it quickly twisted together and boom I have a 4x4
    Snow Doctor and Dm93[OP] like this.
  7. Aug 20, 2022 at 3:27 PM
    #187
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Nice, sounds like we're almost there.:thumbsup:
    06RegCab1[QUOTED] likes this.
  8. Aug 20, 2022 at 4:19 PM
    #188
    06RegCab1
    Wyatt
    Maui Hawaii
    So, now all it is is 4low will flash and beep but not engaging
  9. Aug 20, 2022 at 4:23 PM
    #189
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Are you fully depressing the clutch when trying to engage 4lo?
  10. Aug 20, 2022 at 4:24 PM
    #190
    06RegCab1
    Wyatt
    Maui Hawaii
    Yes, dead stop, neutral no rolling foot to the floor, just beeps
  11. Aug 20, 2022 at 4:27 PM
    #191
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Need to make sure it's getting a clutch signal, the beeping typically indicates conditions aren't correct for a shift.
    SR-71A and 06RegCab1[QUOTED] like this.
  12. Aug 20, 2022 at 4:33 PM
    #192
    06RegCab1
    Wyatt
    Maui Hawaii
    I lied. I’m just dumb lol. Floor Matt got in the way
    Dm93[QUOTED][OP] likes this.
  13. Aug 20, 2022 at 4:40 PM
    #193
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    So is it all working correctly now?:fingerscrossed:
  14. Aug 20, 2022 at 4:43 PM
    #194
    06RegCab1
    Wyatt
    Maui Hawaii
    Yes, thank you all so much for the help. I feel like I finally got my truck back, best part is I just came back from a deployment so I get a full year with the truck and can actually use it again, torquey lil bastard on 5.29’s in 4 low
  15. Aug 20, 2022 at 4:49 PM
    #195
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Nice glad you kept at it, got it fixed, and came back to tell us, so many people ask a question, get some answers, and never come back with an update.:thumbsup:
  16. Sep 28, 2022 at 9:04 AM
    #196
    N919HJ
    N919HJ Well-Known Member
    Ohio
    2007 Double Cab TRD OR
    First of all, thanks for all of you taking the time to share what you know about this system. I would be paying someone thousands to figure this out without you guys. My truck is a 2007 V6 DC OR with 110k. I have both lights blinking constantly. When this first started the blinking was intermittent. When the lights weren’t blinking the four-wheel-drive would work perfectly. Then the next day the lights would blink and the four-wheel-drive will not work obviously. I found the deteriorated vent line and cut off the bad part. No Joy. I replaced the whole thing, still nothing. I pinned out the 4WD ECU and this is what I got.
    This telling me that I have a bad transfer case actuator. Or a corroded TL1. This would make sense because if I select 4WD I get nothing, no clicks behind the dash, no actuators moving, nothing, just blinking lights meaning the system is locked. Right? Your thoughts would be greatly appreciated before I start throwing parts at it. Thanks
    GilbertOz, jepagan1991 and Dm93[OP] like this.
  17. Sep 28, 2022 at 9:10 AM
    #197
    N919HJ
    Ohio
    I just recently read in the manual that you should actuate the four-wheel-drive system for 10 miles once a month. I thought I good for doing it every couple of months for a couple of miles. Guess not…
  18. Sep 28, 2022 at 9:20 AM
    #198
    6 gearT444E
    Deep South
    Herculiner Hootus
    These readings were taken in 2wd?
    id do two things. Remove L4 switch and ohm it out, the seal can fail for them and cause oil to get into the switch electrical assembly. Repeat voltage checks again. If you most likely the transfer case actuator has a gummed up contact. You can remove the cover and clean it up and reinstall and try and take the readings again.
  19. Sep 28, 2022 at 9:39 AM
    #199
    N919HJ
    Ohio
    Both, the switch position was in 2H for the 2H column and 4H for the 4H column. I hope that makes sense. I’ll pull the 4L switch tomorrow and report back. What readings should I get back for a good switch.
  20. Sep 28, 2022 at 9:45 AM
    #200
    6 gearT444E
    Deep South
    Herculiner Hootus
    gotcha, yeah I see now. I guess what I was asking was did the truck actually go into 4wd for that second scenario? The 4L switch should be open circuit across it and then if you push the detent ball in it will be a closed circuit, exercise it several times to make sure you get consistent results. And check for oil in the connector end.
