4wd System Operation & Help Thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dm93, Oct 27, 2021.
  1. Oct 11, 2022 at 12:58 PM
    #221
    Dm93
    Dm93 [OP] Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Backprobe the White/Black wire (Pin4) at the actuators with them plugged in and the key on and see what you get, I'm suspecting to see 12v there since all your limit switch signals are stuck at 12v which would indicate an open ground to the actuators.
  2. Oct 11, 2022 at 1:09 PM
    #222
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Sure makes sense with everything stuck at 12v
  3. Oct 11, 2022 at 1:33 PM
    #223
    N919HJ
    N919HJ Well-Known Member
    Ohio
    2007 Double Cab TRD OR
    The TC actuator switches both read 0 on the blk/wht wires. The ADD up front reads 12 volts on the blk/wht wire and pin 4 reads .02. I also plugged in the new ADD to see what would happen and got no change. Would I need to unplug the battery and the 4WD ecu and then plug in the new ADD, then plug back in the 4WD ecu, then hook up the battery? In ordered to get everything to reset.
  4. Oct 11, 2022 at 1:39 PM
    #224
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I said Black/White, I meant White/Black (brain fart:annoyed:)
    So you have 0v on the ground (White/Black) of the actuators with them plugged in but all your limit switch readings at the ECU are 12V?
  5. Oct 11, 2022 at 1:41 PM
    #225
    N919HJ
    Ohio
    I made a mistake, pin 4 at the tc actuator in 0, pin 4 at the ADD reads 12.
  6. Oct 11, 2022 at 2:03 PM
    #226
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Ok so if that's correct your missing the ground at the ADD, you can supply it with a bypass ground temporarily and see if things work properly.
  7. Oct 11, 2022 at 2:23 PM
    #227
    N919HJ
    Ohio
    How would I do that? It should read 0, correct?
  8. Oct 11, 2022 at 2:37 PM
    #228
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yes the White/Black wire (Pin4) at both actuators should be ground (0v), you can run a wire from a know good ground to your backprobe at pin 4 if the actuator and see if things work with it connected.
    jepagan1991 likes this.
  9. Oct 11, 2022 at 2:45 PM
    #229
    N919HJ
    Ohio
    Thank you, I’ll give that a try tomorrow. I’m definitely not pulling ADD till I know more.
    Dm93[OP] likes this.
  10. Oct 24, 2022 at 3:11 PM
    #230
    N919HJ
    Ohio
    The dealership is telling me that my check engine light is causing my 4WD not to work. I have a check engine light on because my charcoal canister is bad. Just needs replaced. The tech said when he cleared the code the 4WD worked fine. Hmmmmm, I don’t know if I buy that. Anyone think it sounds a little fishy?
  11. Oct 24, 2022 at 3:55 PM
    #231
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    No a CEL will not affect the 4wd system, it does share some grounds with other things that could cause a CEL though.
    SR-71A and TnShooter like this.
  12. Oct 24, 2022 at 4:07 PM
    #232
    N919HJ
    Ohio
    That’s what I thought. They said when they cleared the codes the 4WD works fine. We’ll see tomorrow when I pick it up.
  13. Oct 24, 2022 at 4:42 PM
    #233
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Weird, the 4wd is in no way connected to the engine management system other than sharing a couple grounds and the vehicle speed signal.
    N919HJ[QUOTED] likes this.
  14. Oct 24, 2022 at 5:43 PM
    #234
    6 gearT444E
    Deep South
    Herculiner Hootus
    fishy at best. He obviously doesn’t understand how the 2nd gen system functions
    GilbertOz, SR-71A and TnShooter like this.
  15. Oct 24, 2022 at 5:49 PM
    #235
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Isn’t that the truth.
    A scan tool and the 4WD system have nothing to do with each other on a 2nd gen.
    If it were a 3rd, maybe. Since they actually incorporated fault codes for the 4WD System.
    6 gearT444E[QUOTED] likes this.
  16. Oct 25, 2022 at 10:18 AM
    #236
    N919HJ
    Ohio
    Welp, I when to get my truck this morning and low and behold the 4WD light was still flashing. Pretty heated, I went back in to tell the service rep my 4WD was not working even though he said it was when I called this morning to double check. He went and got a scan tool from the shop and brought it to the truck. After hooking it up and clearing all the codes the truck went in to 4WD just as it should. As soon as he unplugged to tool and the ecu started throwing codes and the flashing started again. I watched the whole thing happen. The codes are in this the picture below.
    Basically all the codes for the vapor canister replacement. I have one on the way. They wanted a grand to do it and politely said no thank you. I’ll report back when I get it installed. Can I clear the ecu by disconnecting the battery or do I need a scan tool to “really” clear the ecu? Hope this helps someone in the future.
  17. Oct 25, 2022 at 10:29 AM
    #237
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Ah I know exactly what's going on now, with most scan tools connected pins 4 (Chassis Ground) and 5 (Sensor Ground) of the DLC are shorted together which will temporarily "fix" a bad sensor ground while a scan tool is connected.
    Remember we were chasing a bad ground last time you posted, I'd be willing to bet finding the problem and fixing that ground will fix your EVAP code(s) too as that is on the same ground tree.
    6 gearT444E and TnShooter like this.
  18. Oct 25, 2022 at 10:30 AM
    #238
    TnShooter
    Deogee
    STOCK
    You say “ As soon as he unplugged the tool, it started throwing codes.”
    Is this literally as in “just as the scan tool was unplugged”?
    Or shortly after the scan tool was unplugged?
    I’ve never heard of an Evap code to cause the 4wd to not engage.
    I think there may be more to the problem.
    6 gearT444E likes this.
  19. Oct 25, 2022 at 10:32 AM
    #239
    SR-71A
    Zack
    Southern Maine
    That pic is too small to read. Did you ever find the ground issue we were cashing a few weeks back? I bet thats your issue.
  20. Oct 25, 2022 at 10:33 AM
    #240
    SR-71A
    Zack
    Southern Maine
    Dang @Dm93 beat me to it, with a better explanation too :D
