4wd System Operation & Help Thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dm93, Oct 27, 2021.
  1. Oct 29, 2022 at 10:41 AM
    #261
    6 gearT444E
    Deep South
    Herculiner Hootus
    this is true not meant for permanent. But looking at the loads on that circuit the canister pump only runs with the truck off and the rest only operate while switching 4wd in and out. Not much load that I see to cause harm.
    Dm93[QUOTED][OP] likes this.
  2. Oct 29, 2022 at 10:45 AM
    #262
    Dm93
    Dm93 [OP] Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I'm also really curious where exactly that ground goes bad because it seems to be a relatively common issue and I haven't gotten that far with anyone to find the exact spot yet. If I knew exactly where and how it fails it would give another data point to this whole thread.
  3. Oct 29, 2022 at 10:47 AM
    #263
    6 gearT444E
    Deep South
    Herculiner Hootus
    yeah I’m not sure. But if it was me I’d take that grounding point and get rid of it and solder a big fat 12 gauge cable to the existing ground cables and then run it straight to the battery.
  4. Oct 29, 2022 at 10:58 AM
    #264
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The ground point itself isn't the problem but with grounds like those in a corrosive environment like in the salt belt (not sure if he lives in an area like that or not) the wires tend to corrode internally and will look intact but in fact be corroded in two. I've also seen many times where the individual wires will break off from vibration (99-06 GM trucks were notorious for this).
    On a side note I'm onto some new tests to help diagnose the P035x coil circuit codes that also seem to be relatively common.
    6 gearT444E[QUOTED] likes this.
  5. Oct 29, 2022 at 11:06 AM
    #265
    6 gearT444E
    Deep South
    Herculiner Hootus
    the real issue is the use of dissimilar metals because I believe that point is on the cylinder head or block area, that will accelerate it. I would cut back the ground harness to good fresh copper then run it directly to the battery or chassis.
    N919HJ likes this.
  6. Oct 29, 2022 at 11:24 AM
    #266
    N919HJ
    N919HJ Well-Known Member
    Ohio
    2007 Double Cab TRD OR
    I’m in central Ohio, the corrosion is awful. I just took EE off and sanded everything down. An aircraft mechanic checked EE and said it was a good ground but did mention that doesn’t mean the wires are intact. When back probing 18 should I have the key on? Do I set the multimeter to vdc and touch one probe to 18 and the other to a ground? What should I see?
  7. Oct 29, 2022 at 11:28 AM
    #267
    N919HJ
    Ohio
    I can get a cheap scan tool on Amazon for $20. Might be the ticket.
  8. Oct 29, 2022 at 11:34 AM
    #268
    6 gearT444E
    Deep South
    Herculiner Hootus
    yes. Should be almost 0VDC. If you are reading a potential that means the voltage is not getting grounded properly from the EE ground point.
  9. Oct 29, 2022 at 11:38 AM
    #269
    N919HJ
    Ohio
    I’m reading zero volts with the key on.
    6 gearT444E likes this.
  10. Oct 29, 2022 at 12:01 PM
    #270
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Ok what about on pins 7 and 19 of the same connector?
  11. Oct 29, 2022 at 12:11 PM
    #271
    N919HJ
    Ohio
    Pin 7 is bouncing around .01 and 19 is empty. Key on
  12. Oct 29, 2022 at 12:22 PM
    #272
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    19 should be populated, are you sure your on the right location?
    PA pins 18 and 19 should be the 2 White/Black wires on the top connector where my finger is.
    SR-71A likes this.
  13. Oct 29, 2022 at 12:24 PM
    #273
    N919HJ
    Ohio
    Nope, I didn’t realize the picture was upside down. I’ll be back.
  14. Oct 29, 2022 at 12:29 PM
    #274
    N919HJ
    Ohio
    Pin 18 is 12.5
    pin 19 is 12.5
    Pin 7 is 12.5
    SR-71A and Dm93[OP] like this.
  15. Oct 29, 2022 at 12:36 PM
    #275
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Nice, that confirms the wire is broken somewhere between Pin 18 and ground point EE.
    You have 2 options, you can continue to look where the wire is broken or you can cut the wire at Pin 18 splice a wire to it and run it from Pin 18 to an interior ground stud.
  16. Oct 29, 2022 at 12:38 PM
    #276
    N919HJ
    Ohio
    That’s great news! I’ll give it a try. Thank you very much!
  17. Oct 29, 2022 at 12:41 PM
    #277
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Let us know how it goes, I'm still curious where exactly that wire is broken but I understand if you don't want to chase it anymore.
  18. Oct 29, 2022 at 1:05 PM
    #278
    N919HJ
    Ohio
    It works!!!!!!!!!!!:amen::bowdown: DM me your PayPal. I’ll buy you your favorite 6 pack. Cruise control too!
  19. Oct 29, 2022 at 1:09 PM
    #279
    N919HJ
    Ohio
    I really don’t want to open up the wiring harness. It will probably cause more damage than good. I willing to bet when they did the frame swap something didn’t get put back where it was suppose to. But that was 5 years ago.
  20. Oct 29, 2022 at 1:14 PM
    #280
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Nah I'm good, I'll definitely remember this for the future for quicker testing.
    Question though in the picture it looks like you are on pin 19, it's hard to tell.
    The pins are numbered from the top.
    22
    21
    19
    18
    17
    16
    15
    14
    13
    12
