4wd System Operation & Help Thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dm93, Oct 27, 2021.
  1. Dec 17, 2022 at 4:30 PM
    #341
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    @Dm93 will be along shortly.
    If your front drive shaft is spinning (transfer case locked in 4H) then you have a bad 4WD position switch OR the ground for the switch is bad.
    Did you check the ground wire for the switches on the Transfer case?
    TacoZim likes this.
  2. Dec 17, 2022 at 4:40 PM
    #342
    B.Root
    B.Root IG: root_overland
    Bryan
    Dry Ridge, Ky
    2012 Tacoma TX Pro
    What was the other event that made you start testing the other electrical things like the 4wd system?
    TacoZim[QUOTED] likes this.
  3. Dec 17, 2022 at 4:49 PM
    #343
    TnShooter
    Deogee
    STOCK
    I’ll also note, that your TL2 never seems to be pulled to GND.
    Are you sure the transfer case in in 4WD?
    While parked. Go grab the front driveshaft and turn it.
    If it turns, it is NOT locked in 4WD.
    If it doesn’t turn, it’s in 4WD and for some reason your 4WD position switch isn’t reporting it. Bad switch or Ground.
    TacoZim likes this.
  4. Dec 17, 2022 at 5:08 PM
    #344
    TacoZim
    TacoZim Well-Known Member
    Bay Area, CA
    2008 DCLB
    I had my buddy pull the truck forward and peeped under and the front drive shaft rotated.
    Have not crawled under and checked either actuator yet. Figured I’d start at the ECU.
    Lemme preface by saying I’m kind of retarded.
    I may or may not have pulled a silly goose and was in a rush and swapped battery leads when jump starting the truck off my other car. Leads were swapped on my car and placed correctly on the truck. Noticed the issue before actually starting up either car and corrected it.
    Had a few gremlins that came from that. Went through both fuse boxes and replaced fuses that blew. 4WD fuse was fine when inspected. Upon first start up after this issue, 4WD light and 4Lo were not flashing. It wasn’t until I flipped the switch and the truck tried to go to 4H that it told me Nope.
    Truck runs fine and everything else works as of now besides the obvious 4WD system.
    As mentioned above, haven’t tried spinning the driveshaft by hand, but did note that it rotated while driving forward. When the front was jacked up, front wheels spun opposite of each other.
    B.Root[QUOTED] likes this.
  5. Dec 17, 2022 at 5:13 PM
    #345
    Dm93
    Dm93 [OP] Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    So your limit switch voltages are correct when the switch is in 2H but you still have flashing lights or they only flash when you tey to put it in 4wd?
  6. Dec 17, 2022 at 5:14 PM
    #346
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I'll have to take a closer look later, I'm not home at the moment to sit down and study.
  7. Dec 17, 2022 at 5:14 PM
    #347
    TacoZim
    Bay Area, CA
    2008 DCLB
    It is flashing lights no matter what I do. It truly is angry with me.
  8. Dec 17, 2022 at 5:21 PM
    #348
    B.Root
    Bryan
    Dry Ridge, Ky
    2012 Tacoma TX Pro
    We all have done stupid shit before when being in a rush but the 2nd mistake I believe was trying to put in 4wd when in park on and incline. I have never tried putting in 4wd in park so I’m kinda wondering if it forced itself into 4wd and maybe out of sync on your transfer case actuator. I’d check your front drive shaft and see if it is locked in or maybe take a drive down the road at low speed and try switching from 2-4H.
  9. Dec 17, 2022 at 5:25 PM
    #349
    TacoZim
    Bay Area, CA
    2008 DCLB
    This is exactly what I think is up. I think the TC actuator is the issue and I think it’s like in between positions with the limit switches being all fucky. I tried pulling off driveway and did the back and forth for about 10 minutes while going through all the positions on the cab switch and I think since the lights flash continuously, the ECU is in the failsafe mode and not allowing shit to happen.
  10. Dec 17, 2022 at 5:28 PM
    #350
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Not sure if I posted this before but here are some "Quick Training Guides" for 4WD operation and diagnosis.
    I have one more but it says the file is too large.
    Dm93[OP] and TacoZim like this.
  11. Dec 17, 2022 at 5:47 PM
    #351
    Travel John
    Travel John Active Member
    Puget Sound
    07 DCSB 4x4 Off Road
    OME 886 w/ Dakar & Nitros, ARB Bull Bar, All Pro Sliders w/ Kick-Outs, "grey wire" mod, ABS Kill Switch, CB Install, Rino Rack Awning, James Baroud RTT
    Happy Saturday! What an amazing mass of knowledge, thanks OP!
    I would sincerely appreciate some thoughts/guidance on next steps for troubleshooting. I have a '07 V6 4WD. When I put it into 4WD I am met with both the 4H and 4L lights flashing. I performed the voltage test (thanks again for the knowledge!), with details below. When shifting from 2H to 4H, TL1 does not gain voltage and both DL2 and ADD maintain their voltage. I can also hear the Transfer Case actuator making an actuation noise when shifting from 2H to 4H.
    I attached an excel with the specific readings. Really appreciate any insights.
  12. Dec 17, 2022 at 8:03 PM
    #352
    TnShooter
    Deogee
    STOCK
    TL1 doesn’t actually gain voltage.
    TL1 TL2 TL3 are all 12v when NOT grounded.
    The system is a pull to ground type.
    So, when’s ever TL1, TL2 or TL3 are connected to ground (through the actuator) the voltage is pulled to 0v.
    Your TL1 wire is being pulled to ground.
    Either by corrosion in the actuator motor, or a short on the TL1 wire.
    Dm93[OP] likes this.
  13. Dec 17, 2022 at 8:16 PM
    #353
    Travel John
    Puget Sound
    Thanks @TnShooter, so would be next step be to check the continuity of the TL1 wire, and if no short, replace the Transfer Case actuator motor assembly?
    I appreciate the guidance.
  14. Dec 17, 2022 at 8:25 PM
    #354
    TnShooter
    Deogee
    STOCK
    I would unplug the connector and check TL1 wire for 12v. (Key on)
    If it has 12v, the problem is in the actuator.
    If it has less than 12v (such as 1.1v you posted) than the TL1 wire is shorted.
    winkel and Travel John[QUOTED] like this.
  15. Dec 17, 2022 at 8:33 PM
    #355
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Sorry for the delay, I've been out all day. I see @TnShooter has been helping out:thumbsup:
    Yea it definitely sounds like you have a broken ground wire between EE and Connector PA Pin 18, still haven't had anyone nail down where it breaks but it seems to be a relatively common problem.
    TnShooter likes this.
  16. Dec 17, 2022 at 8:44 PM
    #356
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    That's very interesting, so mechanically the system is in 4H but electrically it appears to be in 2H. I don't see how that could be possible, are you sure you were probing the right terminals?
    Shifting the 4wd system while in park shouldn't hurt anything, typically if things aren't lined up it just flashes the 4wd light until it's able to complete the shift.
    TnShooter and TacoZim[QUOTED] like this.
  17. Dec 17, 2022 at 8:49 PM
    #357
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    If the key wasn't turned on during the mixup I wouldn't think it would have done anything to the 4wd ECU as that is only powered up with the key on.
    Definitely seems like it's fully in 4wd then, I think I'd double check the voltages with the switch in 2wd and see what they are one or more of them have to be out of whack.
  18. Dec 17, 2022 at 8:50 PM
    #358
    TacoZim
    Bay Area, CA
    2008 DCLB
    Yeah I had that printout with which terminal is which as well as which color they were and I was saying them out like a schizo.
    The only thing I can think of is the ECU noticed something wrong half way to the 4H position and that’s why the limit switches aren’t reading right in 4H/4Lo in the TC actuator. So mechanically it’s operating like it’s in 4wd, but it’s only half locked in if that makes sense? That’s the only thing I can think of. My next option is either backprobe the position switches at the TC or take apart the TC followed by the front diff actuator until I find the issue.
  19. Dec 17, 2022 at 8:52 PM
    #359
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I have those posted in the top post.
  20. Dec 17, 2022 at 8:59 PM
    #360
    TacoZim
    Bay Area, CA
    2008 DCLB
    If the TL1 was probed wrong in 2H and was actually 12v. Would that make more sense as to what’s wrong? Then it’d be showing open at each limit switch in all 3 positions.
