4wd System Operation & Help Thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dm93, Oct 27, 2021.
  1. May 13, 2023 at 7:27 AM
    #581
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Hey guys i have the dreaded blinking 4w/4lo every once in a while.
    I can get it to locked into 4 wheel,but disengaging back into 2 wheel is a little difficult.
    i hear the click behind glove box locking into 4 wheel, but when i turn switch to 2 wheel it sounds like a buzzing over and over and it wont go back into 2 wheel, until i drive forward/reverse, eventually itll go into 2 wheel.
    The buzzing continues as it tries to switch from 4W to 2W.
    Is there a relay behind the glove box?
    I havent had a chance to pull in apart, plus wiring isnt my forte.
    Maybe my switch is bad?
    Any thoughts?
  2. May 13, 2023 at 8:49 AM
    #582
    Dm93
    Dm93 [OP] Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    The relays are built into the 4wd ECU (location in the first post of this thread), the fact one of them is buzzing when shifting to 2wd kind of suggests to me there may be a cracked solder joint on the circuit board.
    You may want to pull the 4wd ECU out, take the cover off of it, and examine the circuit board for burned spots or cracks in solder joints.
  3. May 13, 2023 at 9:35 AM
    #583
    303tacoma
    Rebecca
    Ok i can handle that, thanks for the suggestion and advice!
    Ill get back when i get to it,and update.
    Thanks again
    TnShooter and Dm93[QUOTED][OP] like this.
  4. May 17, 2023 at 5:32 AM
    #584
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Just want to highlight / clarify that point right there. You really should be moving down the road in a mostly straight line for the 2Hi <> 4Hi switch. Thats the best way to reduce any driveline bind and let the actuators do their job moving the components inside the t-case and ADD. Im not saying that is your problem, "buzzing" sounds are certainly abnormal, but every little bit helps if you're in a pinch
    Into / out of 4Lo is where you need to be under 2mph or else the truck will beep at you.
    303tacoma[QUOTED] likes this.
  5. May 17, 2023 at 1:08 PM
    #585
    303tacoma
    Rebecca
    Yes i guess im horrible at explaining
    Always in motion
    My problem is going back into 2w
    In motion
    Just wouldnt release until forward/ backward.
    It 4 wheel season here and i have to try and figure this out, but time isnt on my side.
  6. May 17, 2023 at 4:22 PM
    #586
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Like I said since you have a relay buzzing sound only when going from 4wd to 2wd and not when going from 2wd to 4wd I'd want to examine the circuit board of the 4wd ECU for cracked solder joints or damaged components, if nothing is found there then there's some other checks we can do.
  7. May 17, 2023 at 5:46 PM
    #587
    303tacoma
    Rebecca
    Thanks i appreciate it!
    Hopefully i can dig into it this weekend.
    Dm93[QUOTED][OP] likes this.
  8. May 21, 2023 at 11:05 AM
    #588
    303tacoma
    Rebecca
    Ok so i pulled the ECU but im not sure how to check the board it almost look like it slides in the casing. I tried pulling
    t slightly but no give,
    There are no seams in the casing to pop it open.:burp:
    image.jpg image.jpg image.jpg i
  9. May 21, 2023 at 12:02 PM
    #589
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Usually there's a screw or plastic clips that hold those types of modules together.
  10. May 21, 2023 at 12:38 PM
    #590
    303tacoma
    Rebecca
    If there are i dont see them. It looks like it slides in on 2 slot type runners.
    The only removable part is the cover around the plugs.
  11. May 21, 2023 at 12:59 PM
    #591
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I'm not 100% sure, most of those type modules come apart pretty easy.
    I don't have time to go pull mine apart and see at the moment.
  12. May 21, 2023 at 1:28 PM
    #592
    303tacoma
    Rebecca
    Thats cool
    i plugged it back in for the time being.
  13. May 21, 2023 at 4:41 PM
    #593
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Just took mine apart, the board just slides in. A bit of a tight fit but it does come out relatively easy.
    SR-71A and 303tacoma[QUOTED] like this.
  14. May 21, 2023 at 6:15 PM
    #594
    303tacoma
    Rebecca
    Awesome
    Thats what i thought it looked like, i tried pulling on it, i didnt move.
    I didnt want to jack it up.
    I guess ill pull a little harder
    Ill let you know what i find
    Thanks again
  15. May 21, 2023 at 6:35 PM
    #595
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yea it takes a bit of wiggling but it does come out.
  16. May 30, 2023 at 10:00 AM
    #596
    303tacoma
    Rebecca
    Ok finally got back to this.
    It seems im gonna move slowly on this, anyway got the board out.
    I see nothing out of order (not that i know much about circuit boards) buuut no burn marks or loose solder that i see. I inspected the plugs going into board..
    I also pulled my switch that looks fine too.
    When you have a chance lmk what you think i should check next..
    Like i said no rush
  17. May 31, 2023 at 6:00 PM
    #597
    Jyakel1
    Jyakel1 Member
    Jon
    2015 Toyota Tacoma TRD Sport 4x4
    3" icon stage 2 suspension lift C4 fabrications overland bumper w/12k lb openroad winch Vision wheels Alpharex LED headlights Tuwa pro bed rack
    Just ran into a 4hi/4lo issue.
    Just replaced the transfer case actuator motor/housing, and 3 months ago replaced the ADD.
    Tested it out after install, 4hi engaged/disengaged like it's supposed to... when I clicked to 4lo i got the dredded flashing. Can hear the ecu clicking on acc and battery power, but it would not disengage 4wd.
    Only thing I can think now is an electrical issue
    I'll have to get under tomorrow and manually switch it to 2wd for the time being from the transfer case, but definitely need to get this fixed.
    Any help is appreciated where to start.
  18. May 31, 2023 at 6:58 PM
    #598
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Srry I forgot about your post yesterday, your symptoms are difinitely unique.
    I'm trying to think of how/what to test.
    I think I would want to put a test light across both the ADD and Transfer Case motor circuits and see what I get when the buzzing occurs.
  19. May 31, 2023 at 7:01 PM
    #599
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I'm thinking either the Transfer Case Actuator is out of time or we have a circuit problem.
    You could start with the limit switch voltage checks outlined in the first post or checking the Actuator timing.
  20. May 31, 2023 at 7:40 PM
    #600
    303tacoma
    Rebecca
    No biggie:)
    Ok
    First off i guess i need a test light :D
    Should i buy a multimeter while im at it?
    Im pretty good at mechanical stuff when it explained.
    Electrical is a whole new ball game.
    If you can walk me through this id appreciate it.
    Is that something i test at the ecu plugs?
    Thanks again
