4wd System Operation & Help Thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dm93, Oct 27, 2021.
  1. Jul 15, 2023 at 7:04 AM
    #621
    Dm93
    Dm93 [OP] Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Check it for power at connector PD Pin 6 (Green/White), if nothing there then go to PB Pin 8 (Green/White or Blue/White).
  2. Jul 15, 2023 at 7:17 AM
    #622
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Shouldn't matter, on a properly functioning system you should be able to go straight from 2H to 4L and back with no issues.
    303tacoma[QUOTED] likes this.
  3. Jul 15, 2023 at 7:21 AM
    #623
    tearls
    tearls Member
    Tim
    07 Silver Tacoma TRD
    Went to unplug my neutral safety switch and now the car won’t start, very difficult to unplug. I’m thinking it was corroded on the inside and not pushing all the way down. Going to replace this
    6 gearT444E and Dm93[QUOTED][OP] like this.
  4. Jul 15, 2023 at 7:22 AM
    #624
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yea it's in a crappy spot and even more crappy to remove because it tends to corrode tight to the shaft.
  5. Jul 15, 2023 at 9:33 AM
    #625
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Hmmm i thought you couldnt go from 2h to 4lo, that you had to be in 4high before shift to 4lo
    Now ill have to try :D
  6. Jul 15, 2023 at 9:40 AM
    #626
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    It tends to be easier to get into 4L from 4H because that part is already in gear but if everything lines up it will go right from 2H to 4L no problem.
  7. Jul 29, 2023 at 9:19 AM
    #627
    BenSkiv
    BenSkiv Well-Known Member
    Ben
    Maine
    2019 Tacoma TRD-off-road DCLB
    I just backprobed my ecu and when cold, it checked out, pretty well. Then went for a drive and tested again and values changed. 4wd in 4hi, which should be 0v is 12v, DL1 which should be 12v is 0v, DL2 should be 0v is 12v, and ADD should be 0v is also 12v. When cold it did struggle to shift into 4 for a bit, and values changed, but once it shifted they became correct. My question now is, where does this lead me? Where should I begin to look next? Thanks in advance!
  8. Jul 29, 2023 at 10:29 AM
    #628
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    It sounds like either the Transfer Case Actuator is failing when it gets hot or one of the motor wire (TM1 or TM2) is going open circuit when it gets hot.
    If you have backprobes you can backprobe TM1 (Pin 2 Green) and TM2 (Pin 1 Blue) at the Transfer Case Actuator connector, put a test light across them, and see if the light lights while you have someone operate the 4wd.
  9. Jul 29, 2023 at 10:35 AM
    #629
    BenSkiv
    Ben
    Maine
    Just ordered a test light, I’ll try that next weekend. I’m assuming I backprobe 1 and 2 and run the test light across both pins? Or do I individually backprobe and test the pins?
    Dm93[QUOTED][OP] likes this.
  10. Jul 29, 2023 at 10:36 AM
    #630
    6 gearT444E
    Deep South
    Herculiner Hootus
    backprobe each to ground.
  11. Jul 29, 2023 at 10:39 AM
    #631
    BenSkiv
    Ben
    Maine
    They should be 12 as well, correct?
  12. Jul 29, 2023 at 10:44 AM
    #632
    6 gearT444E
    Deep South
    Herculiner Hootus
    depends on where the motor is, check the first post in thread with the spreadsheet
  13. Jul 29, 2023 at 10:47 AM
    #633
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I'd put it across them first, if it lights and the actuator doesn't move you know your wiring is good and the actuator is bad.
    If it doesn't light then do the same check on TM1 (F13 Pin 2 (Green)) and TM2 (F13 Pin 1 (Blue))at the 4wd ECU
  14. Jul 29, 2023 at 10:57 AM
    #634
    BenSkiv
    Ben
    Maine
    I quickly backprobed both pins while having someone flip the switch. Pin 1 I saw 0.9 and pin 2 hit 12v for a second. I’ll double check everything when I get the test light in and go from there
  15. Jul 30, 2023 at 5:38 PM
    #635
    chukarman
    chukarman Member
    Brian
    2014 TRD Tacoma
    wow there is a wealth of knowledgable techs and do it yourselfers. Need help also...
    Background on my truck i bought it used 3 years ago never really engaged perfectly but always eventually engaged until last offroad trip. then it wouldnt go back to 2wd. Had no light to go into 4 hi and would sometimes engage in 4 lo only. now it wont go to anything. I suspected the switch and one of the tabs is broke not making contact< but im not sure if I caused it or not. Here are the readings before i removed the 4x4 select switch
    Dm93[OP] likes this.
  16. Jul 30, 2023 at 5:38 PM
    #636
    chukarman
    chukarman Member
    Brian
    2014 TRD Tacoma
    here are my results
  17. Jul 30, 2023 at 5:39 PM
    #637
    chukarman
    chukarman Member
    Brian
    2014 TRD Tacoma
  18. Jul 30, 2023 at 8:38 PM
    #638
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    ADD being at 0v but DL1 & DL2 being correct suggests the ADD is staying locked in for some reason or there's a problem with the ADD switch or circuit.
    Did you check if the front axle is indeed locked in?
  19. Jul 31, 2023 at 6:57 AM
    #639
    chukarman
    chukarman Member
    Brian
    2014 TRD Tacoma
    I could spin the front drive shaft freely by hand. I never had the ADD apart. So far I ordered a new selector switch due to the cracked housing. Had the t-case actuator out, cleaned and lube and bench test motor.
    Last night while applying pressure to switch and engage everything worked. 4-hi, 4,lo and back. Once the switch gets here later this week, I’ll retest everything again to see if something wrong with ADD.
  20. Jul 31, 2023 at 7:01 AM
    #640
    chukarman
    chukarman Member
    Brian
    2014 TRD Tacoma
    Before all this I could not always get the 4x4 Hi light to come on.
