4wd System Operation & Help Thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dm93, Oct 27, 2021.
  1. Sep 19, 2023 at 7:31 PM
    #661
    Mikey808
    Mikey808 Active Member
    Michael
    2008 Toyota Tacoma 4x4
    I’m confusing myself because I’m thinking I’m just testing one of the harnesses but according to my harness colors. Id be using both harness to get all wires tested for the chart test.
  2. Sep 19, 2023 at 7:34 PM
    #662
    Mikey808
    Michael
    Ok thanks for that clarification. Here is a revised test for 2-4 and LO. Readings are good which means switch is working properly
  3. Sep 19, 2023 at 7:40 PM
    #663
    Dm93
    Dm93 [OP] Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Ok in that case it looks like the problem is going to be in the Transfer Case Actuator, so you are indeed seeing 0.13v on TL2 and TL3 with the switch in 4H?
  4. Sep 19, 2023 at 7:51 PM
    #664
    Mikey808
    Michael
    In 4H I am now getting: .02V on TL2
    13.37V on TL3
  5. Sep 19, 2023 at 7:56 PM
    #665
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    That's interesting, did any of the others change?
  6. Sep 19, 2023 at 7:57 PM
    #666
    Mikey808
    Michael
    I stand corrected I just probed TL2 at 13.4V.
    I am sorry. I’m trying not to force the pin in there so much. But this time I was frustrated so I pushed it ins little harder. And it read 13.4V
  7. Sep 19, 2023 at 8:00 PM
    #667
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    No problem, so it looks like the Transfer Case Actuator is not moving.
    Have you looked at the actuator to see if the vent hose is attached?
  8. Sep 19, 2023 at 8:26 PM
    #668
    Mikey808
    Michael
    So now I went to prob TL1,TL2, and TL3 on 4LO I was reading .03 V for all three….I thought that was odd so I went back to 4H to see if I would get the same readings when previously tested which was 13V for TL1, TL2, and TL3. But now there are reading .03V TL1 and TL2. And TL3 is 12.48V.
  9. Sep 19, 2023 at 8:40 PM
    #669
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Something isn't right there, have you crawled under the truck and checked out the Transfer Case Actuator?
  10. Sep 19, 2023 at 8:47 PM
    #670
    Mikey808
    Michael
    Checked tcase actuator. End of line is a little but no tears or rips. Held it by hand to see if actuator would move. Turned truck on, switched to 4H. I felt and head actuator move. Checked 4H light, still blinking no beeping. Switched to 4LO, no movement in actuator light still flashing. Put it into 2WD drive. Shut truck off. Turned truck
    Back on, switch to 4H no movement in actuator light still flashing. Seems the actuator is intermittent, and will only ave movement when switching from 2H to 4H.
  11. Sep 19, 2023 at 8:48 PM
    #671
    Mikey808
    Michael
    Little brittle**** @Dm93
  12. Sep 19, 2023 at 8:53 PM
    #672
    Mikey808
    Michael
    Vent hose
  13. Sep 19, 2023 at 8:53 PM
    #673
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I think the next step is to open the actuator and check the contacts inside based on the inconsistent voltages your seeing on TL1 2 & 3 just take care to not pull the main gear out without noting the position of it so you don't lose the timing.
  14. Sep 19, 2023 at 8:55 PM
    #674
    Mikey808
    Michael
    Will pull out tomorrow. Any advice or tips tricks to pull out without pulling main gear.?
  15. Sep 19, 2023 at 8:55 PM
    #675
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yea they all kinda look like that on the end.
    Hopefully those bolts come out, they look pretty rusty.
  16. Sep 19, 2023 at 8:57 PM
    #676
    Mikey808
    Michael
    Perks of living in HI. Lol
  17. Sep 19, 2023 at 9:00 PM
    #677
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I haven't had to take one apart yet but all I can say is when removing the cover try to keep the gear in place.
  18. Sep 20, 2023 at 7:08 PM
    #678
    Mikey808
    Michael
    Update on contact points of transfer case actuator.
  19. Sep 20, 2023 at 7:14 PM
    #679
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Might need to clean that up a bit, hard to tell if the contact track is worn down or if that's corrosion.
  20. Sep 20, 2023 at 9:37 PM
    #680
    Mikey808
    Michael
    It’s some kind of grease. I figured that’s how it supposed to be. Cleaned every thing and put it back. Turned struck on and it switched to 4 hi and locked in. Went to 4LO and it flashed and beeped. Went back to 4H and nothing. Could definitely hear actuator working. But now just flashing again no beeping. Could the timing be off?
