4wd System Operation & Help Thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dm93, Oct 27, 2021.
  1. May 7, 2024 at 11:38 AM
    #801
    beto_sn
    beto_sn Well-Known Member
    Alverto
    I will do the readings with both add and tc motor disconnected give me a few
  2. May 7, 2024 at 11:53 AM
    #802
    beto_sn
    Alverto
    New readings
    add and tc motor connectors off
  3. May 7, 2024 at 12:34 PM
    #803
    beto_sn
    Alverto
    If i cycle key on off i can get it to get out of 2hi/4hi but light will blink. Have confirmed add locking up/unlocking
  4. May 7, 2024 at 1:05 PM
    #804
    Dm93
    Dm93 [OP] Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    It really looks like you have an issue in the Transfer Case Actuator as well as something going on with the wires going to the ADD Actuator or something goofy is going on inside the 4wd ECU with the voltages being out of whack.
    I think unplug the actuators and 4wd ECU and check resistance between the limit switch circuits and ground so we can rule out shorted wires.
    Also maybe pop the ECU apart and see if there's anything that looks suspicious in there.
    TnShooter likes this.
  5. May 7, 2024 at 1:15 PM
    #805
    beto_sn
    Alverto
    I need to go buy a better multi meter i was using a test light with v reading
  6. May 7, 2024 at 1:18 PM
    #806
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Ah that's why we may be seeing skewed voltages, that makes sense.
    The test lights with voltmeters draw a fair bit of current, they don't work well to test sense circuits.
  7. May 7, 2024 at 2:09 PM
    #807
    beto_sn
    Alverto
    Gotcha, also my battery could be running a little low, which is why volts are lil higher when truck is on and i test.
    now idk what to do im at a loss.
  8. May 7, 2024 at 2:32 PM
    #808
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The battery is fully charged at 12.6v
    With the truck running it will be 13-13.5v (supplied by the alternator)
  9. May 7, 2024 at 2:44 PM
    #809
    beto_sn
    Alverto
    Ahhh ok nvm then. Could it be tc actuator?
  10. May 7, 2024 at 2:52 PM
    #810
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    It looks like a problem with the Transfer Case Actuator but we need to get a proper meter to test with, I believe the test light meter is pulling the voltages down and skewing the results.
    Was the vent hose secure on the actuators?
    winkel and TnShooter like this.
  11. May 7, 2024 at 3:07 PM
    #811
    beto_sn
    Alverto
    Yes vent hose was good, well the actuator it has on now is a cheap actuator i got online. The original one was caked and the contact points were completely gone. (Vacuum line was broken at the end so water and gunk got in it. I tried cleaning and soldering but the solder wouldn't stick. I only bought the cheap one so i wouldn't pay 1k+ on one and not be that. I basically built a Frankenstein using the switch sensors, and the gear from the oem. It goes in and out of 4hi/2hi like i mentioned above after cycling key. but the light wont stop blinking. I will pick up a multimeter today at home depot and give it another try tomorrow if i get a chance.
  12. May 8, 2024 at 9:21 AM
    #812
    beto_sn
    Alverto
    So i realized when truck is in 2wd the front driveshaft is hard to turn, does turn independently from rear, but the rear does move a bit if i twist it. Im thinking my problem is inside the transfer
  13. May 8, 2024 at 6:51 PM
    #813
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You would need to jack a front wheel off the ground to see what's engaged.
  14. May 8, 2024 at 6:57 PM
    #814
    beto_sn
    Alverto
    I had it on a lift, front drive shaft would spin with the rear but i was able to stop it with my hand it was like the tc was in 4wd :confused:
  15. May 8, 2024 at 7:03 PM
    #815
    TnShooter
    Deogee
    STOCK
    In 2WD, you can spin the front driveshaft by hand freely with ALL 4 wheels on the ground.
    It should spin pretty easy. That's what I do when I grease front driveshaft. Reach up and turn it.
    Nothing else should turn. Not the front wheels and not the rear driveshaft.
  16. May 8, 2024 at 7:09 PM
    #816
    beto_sn
    Alverto
    Somes def up in my transfer case or my 2hi is not engaging all the way? Im able to spin it but it takes more muscle then usual (front tires dont spin) and if im in 4hi i cant spin it without spinning the rear one.
  17. May 10, 2024 at 8:19 PM
    #817
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    That's interesting, have you checked the transfer case fluid?
    Did you get a proper multimeter?
  18. May 22, 2024 at 7:26 AM
    #818
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    Has anyone when they replaced the ADD with a new one opened it up and soldered the motor connection before installing? Seems like a way of getting a head of one of the failure points..
  19. Jun 7, 2024 at 2:51 PM
    #819
    beensokio
    beensokio New Member
    Can somone please post a readable version of the wiring diagram so I find the corresponding junctions / harnesses etc. My 4v4 fails after the transfer case locks the front drive shaft. The ECU does not give 12v to the front ADD motor.
  20. Jun 7, 2024 at 3:02 PM
    #820
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    What year is your truck?
    I can grab it and post it when I get home.
    winkel likes this.
