4wd system won't engage???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ToyoComp, Apr 21, 2012.
  1. Apr 21, 2012 at 5:11 AM
    ToyoComp
    ToyoComp [OP] Addicted Mod'r
    Tampa, FL
    07 4x4 TRD Off Road DC
    Sway-A-Way Race Runner 2.5 coil over (3" lift) & Icon 2.5 rear shocks on RXT springs, Total Chaos UCA, ToyTec differential drop, Tom Woods Driveshaft, SpiderTrax spacers, 8128 Pro Comp wheels, Toyo Open Country RT 285/70/17, DT Long Tube headers, URD MAF, TRD CAI & exhaust, Line-X coated Famous Fabrication front bumper, Demello Sliders and rear bumper, Wet Okole covers, Rigid LED spot, driving & fog, bed mat, debadged & EBC Stage 4 rotors and pads
    I have an '07 TRD that won't engage into 4wd high when I rotate the knob. The dashboard icon continues to blink and it will beep if I try to put it in 4wd low. I took it to Toyota of Tampa Bay and three hours later was told that the service technician couldn't figure it out and would need to consult their tech service line - that's been two weeks and I have no faith in these yahoo's. Has anyone else encountered this issue and what was the fix? Thanks.
  2. Apr 21, 2012 at 5:22 AM
    Junebug55210
    Junebug55210 2011 TRD Sport 4x4
    Kyle
    Gainesville, FL
    11 DC TRD Sport 4.0
    Cat back magnaflow, toolbox, camo seat covers
    I dont know if it helps any but my truck only likes to go into 4hi while idling in drive. To get into lo i let the 4hi engage first then stop and put truck in neutral then turn to 4lo and it will engage. If im stopped and try to put the truck in 4hi though it doesnt want to engage.
  3. Apr 21, 2012 at 5:31 AM
    ToyoComp
    Tampa, FL
    Thanks for the suggestion. I should have also said that it's a 6 speed manual.
  4. Apr 21, 2012 at 6:01 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Mine will do the same thing but only for a few mins.. I'm leaning towards the front diff having original oil at 87,000 miles or the ADD is acting up.
    (5speed auto)
  5. Apr 21, 2012 at 6:06 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Clutch switch bad/malladjusted? It has to be all the way to the floor some times even a after market mat will be enough to not let it engage.
  6. Apr 21, 2012 at 6:16 AM
    badger
    badger Well-Known Member
    07 SR5
    If the service tech couldn't get it to engage, I'm guessing something really is wrong. Before the Tcase will engage it needs a signal from the ADD to the 4wd ECU, so it could be anything in that loop.
  7. Apr 21, 2012 at 6:23 AM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    There is an actuator that can go bad. Mine recently had the same issue. Here is what the dealer history said:
    *TRANSMISSIONS ~|~CUSTOMER STATES WHILE DISENGUAGING FOUR WHEEL DRIVE THE LIGHT BLINKS, XFER CASE DISENGAUGES HOWEVER ELECTRICALLY DOESN'T DISENGAUGE ~|~FOUND DIFF LOCK ACTUATOR LOCKED UP ~|~REMOVED AND REPLACED ACTUATOR TO CORRECT Parts Name Part # QTY ACTUATOR ASSY, DIFFE 4140035031 1
  8. Apr 21, 2012 at 6:48 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    My 06 did what you described @ 16k.
    Nothing would make it engage.
    I finally lost 4Lo too.
    The truck was under warranty & the tech used the service line & replaced the front diff actuator.
    There are other threads on this if you read to help diagnosis.
    The part was like $350 but Toyota paid for it.
    Do you have a warranty or out of pocket?
  9. Apr 21, 2012 at 12:22 PM
    ToyoComp
    Tampa, FL
    I'm past warranty and this is really frustrating first because the dumbass tech said he didn't know what it was and second, they still haven't got back to me regarding what their so called service tech line (specialist?) thinks. The actuator makes sense as I am having no other electrical issues. Although it's an '07, I only have 24,000 miles on the truck and the 4wd system has never been abused. Sure does make me miss the days of manual hubs and a 4wd shifter. Thanks guys for your comments.
  10. Apr 21, 2012 at 12:31 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    FYI for those telling you different .. you can switch it into 4hi while moving (up to 60mph in fact) and in gear (clutch doesn't have to be in). Not for 4hi. Ask the tech if he tried a different actuator. Maybe that's not it.
  11. Apr 21, 2012 at 2:29 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Try turning the switch, turning the truck off, then back on. I generally have troubles getting mine to switch out. If all else fails it will work every time if I turn the truck off, it will immediately click back over when the key is on.
    Generally though, if I have troubles, I'll usually tap the gas a little bit, which jives the drivetrain enough and releases enough stress that it will click out.
  12. Apr 21, 2012 at 2:40 PM
    ANGUS
    ANGUS Well-Known Member
    Beckley, WV
    06 SR5 4cyl
    3in rough country, front adj bilstiens 5100s, volant cold-air intake, magnaflow exhaust, optima yellowtop, 4.56 motive gears rear, 4.56 nitro gear front with v6 front diff carrier, brute force fab front bumper, 6k hid, 1.25" wheel spacers, 15% window tint, cab lights, color matched bushwackers, trd hood
    I've had problems in the past. I searched for a service manual and I think there is a thread on here somewhere that posts one. I used it to diagnose myself. The dealer also couldn't figure it out. The 4x4 ecu is located under the dash behind the glovebox beside the ac vent up high. U can start there to make sure its receiving and sending signals correctly
  13. May 4, 2012 at 11:40 PM
    GoatFiddyone
    GoatFiddyone Well-Known Member
    Altamonte Springs, FL
    '17 DCLB TRD OR
    Since new mine has never gone to 4 lo. It sits there and flashes at me and beeps until I turn it back to 4 hi. I don't think there is anything wrong, I just might be doing something wrong.
  14. May 4, 2012 at 11:49 PM
    magnetic11
    magnetic11 Well-Known Member
    "some nuke plant"
    11 trd sport
    Fab fours front and rear bumpers, B.A.M.F. weld on rock sliders, softopper, removed mud flaps and D-Badged everything. Icon 2.5 Extended Travel coil-overs, Total Chaos upppers, 2.0 Icon extended travel shocks with the resi's and Dekar Leaf packs.
    i have a buddy that bought an 05 brand new and the first time we went off road his 4wheel drive wouldnt work and it wound up being the actuator. of course it was still under the factory warrenty.
  15. May 4, 2012 at 11:50 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Do you put it in N then switch to 4LO ?
  16. May 5, 2012 at 12:20 AM
    GoatFiddyone
    '17 DCLB TRD OR
    Sure did. I even tried it in every single gear and it didn't do anything. I haven't tried turning the truck off while the switch in engaged to 4 lo though.
  17. May 5, 2012 at 12:22 AM
    GoatFiddyone
    '17 DCLB TRD OR
    I'm kind of bummed I never did anything about it. Mine is a little over a year old and I'm about to hit 50,000 miles.
  18. May 5, 2012 at 12:33 AM
    GoatFiddyone
    '17 DCLB TRD OR
    It goes into high just fine. When I try and select low it just beeps and flashes.
    tacom02 likes this.
  19. May 5, 2012 at 12:37 AM
    GoatFiddyone
    '17 DCLB TRD OR
    Thanks! I'll report back with my findings tomorrow.
  20. Nov 28, 2019 at 10:01 PM
    tacom02
    tacom02 guy with a truck
    Vance
    Colorado
    08 TRD Off-Road 4x4 4.0L manual
    3" Super lift 285/75R17 Toyo Open Country 17x9 Rims some lights in the bumper
    Have you figured it out? I'm having the same issue with my manual and it is making mad.... lately the truck hasn't even been shifting out of 4hi to 2 and the diff hasn't been locking as well..... I bought a Tacoma to avoid these issue...
