4WD vs. Chains
Discussion in 'Off-Roading & Trails' started by trdchic, Dec 18, 2010.
  1. Dec 18, 2010 at 9:09 AM
    trdchic
    trdchic [OP] Well-Known Member
    Erie CO
    07, TRD Sport, 4x4, SR5, V6, Access Cab
    I still can't decide if I should get 4WD or a Prerunner. I am trying to think of scenarios where I would need 4WD. What is the comparison between chains and 4WD? I would go up to the mountain to snowboard...thats probably it...not go off roading in snow or anything like that.
  2. Dec 18, 2010 at 9:21 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    If you are going to the be in the snow several times a year, I would go with the 4X4. I went with the Prerunner because I didn't think I would ever have it in the snow, well twice in the last couple of years I had to turn back trailing due to snow:(
    If I was to do it again I would go 4X.
    My .02 :notsure:
  3. Dec 18, 2010 at 9:32 AM
    jandrews
    '09 FourDubDee TRD OR
    GET. 4. W. D.
  4. Dec 18, 2010 at 9:35 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    4WD = Confidence, Safety, Good Insurance.
  5. Dec 18, 2010 at 9:37 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    apples and oranges my friend, 4wd is for your safety as well, and is on at the push of a button. chains means stopping to chain up and chain down...
  6. Dec 18, 2010 at 9:40 AM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    4x4! So worth it.
  7. Dec 18, 2010 at 10:27 AM
    98fourbangertaco
    98fourbangertaco Well-Known Member
    Taylorsville, NC
    98 toyota tacoma, 4wd, SR5, 2.7L, 5-speed
    daystar 2.5in suspension lift kit, detroit truetrac in rear, custom transfer case skidplate, deckplate mod, green high-performance drop in filter, Huskyliner floor mats, 31x10.50 wild country radial mtx tires, yakima roof rack, load warrior basket, stubbs welding rock sliders, arb front bumper with warn 9,000lb winch and procomp black series 100w offroad lights, trail-gear rear bumper, borla exhaust, blacked out factory wheels, shovel mounted on roof rack, de-mudflaped
    just go ahead and get the 4x4 or u will regret it later for sure
  8. Dec 18, 2010 at 10:32 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    If your asking, then that probably means you may need it. Go for it . 4WD ftmfw!
  9. Dec 18, 2010 at 10:38 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
  10. Dec 18, 2010 at 11:27 AM
    98fourbangertaco
    Taylorsville, NC
    yea im not one for 2wd trucks
  11. Dec 18, 2010 at 11:34 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Aside from what eveyone else has said..... I'd get the 4WD.
    However, If money is an issue and you don't or can't afford the extra cost of the 4WD, then atleast get the Prerunner TRD Offroad (with the locker).
  12. Dec 18, 2010 at 11:51 AM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    4WD so worth it even if used only a couple times a year!
  13. Dec 18, 2010 at 11:55 AM
    jandrews
    If money is enough of an issue having to choose between 4x4 and 4x2, person probably shouldn't be buying a new truck.
  14. Dec 18, 2010 at 2:29 PM
    98fourbangertaco
    Taylorsville, NC
  15. Dec 18, 2010 at 2:36 PM
    08WhiteTRD
    08WhiteTRD Well-Known Member
    Ben
    Rocklin, NorCal
    2008 White 4x4 TRD Sport
    Fox Suspension 2.5 Front and 2.0 Rear, All-Pro Skids, BAMF LCA Skid, Leer 100R, Scangauge II, WeatherTech Floorliners, WeatherTech window visors, Satoshi grill with HomerTaco mesh, Sockmonkey Tailgate Decal, BHLM, Center Console lock, ImMrYo Rear-view bracket, Rally Armor mud flaps, Crawford Eco-Block, USA-Spec PA-15
    4x4. Although I don't use it that often, when I do use it I am happy to have it. It is better to have the option that to just be stuck.
  16. Dec 18, 2010 at 2:37 PM
    joesilvertac08
    joesilvertac08 Well-Known Member
    Joey
    Newark, DE
    08 Toyota Tacoma DC SR5 4x4 TRDSports
    ARB front bumper, Safari Snorkel, Allpro kickout sliders, ArmorTech OffRoad Skid plates, TRD CAi, Toytec coilover front w/ 5100 Bilstein shocks, Bilstein 5100 rear shocks,Firestone airbags, Skyjacker AAL, 285/70R17 Cooper Discoverer STT LT, Magellan, Cobra 29LTD classic CB radio w/ 3' FireStick antenna.
    4x4, don't know when you need it, then you got it :D!!!
  17. Dec 18, 2010 at 2:41 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    2wd are not real trucks :crapstorm: :infantry:
  18. Dec 18, 2010 at 3:04 PM
    dlthunder
    dlthunder Well-Known Member
    Dan
    Reno, NV
    Sold my Taco
    TRD Skid Plate Rear Seat 11inch DVD Toyota Bed Mat Pace Edwards Full Metal Jackrabbit Nerf Bars Tailgate Electric Dynolock D-ring Bedbolts
    There is nothing I hate more than chaining up on the side of interstate 80, in a snow storm, in the dark watching people in 4WD pass me. That said I only did it once in a friends car because I always have owned 4WD.
  19. Dec 18, 2010 at 5:19 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    4wd. Bring chains in the mountains as a precaution.
  20. Dec 21, 2010 at 10:15 AM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    I have 4wd and chains. its a sick combo. when NO ONE else can make it. I can.
