4WD vs. Locker
Discussion in 'Off-Roading & Trails' started by trdchic, Dec 18, 2010.
  1. Dec 18, 2010 at 9:15 AM
    trdchic
    trdchic [OP] Well-Known Member
    Erie CO
    07, TRD Sport, 4x4, SR5, V6, Access Cab
    When would 4WD be required? What about the locker? Trying to decide if I need 4WD or a Prerunner... this is difficult!
  2. Dec 18, 2010 at 9:18 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    4wd OR....top shit!
  3. Dec 18, 2010 at 9:33 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    It shouldn't be difficult... WHAT do you like to do??? Do you ever leave the highway and explore the backcountry? Do you ever go into snow or onto the beach (Baja or Pismo) or into the desert?
    The weight of a pickup is over the front axle (unless loaded in the bed)... yet the drive tires are over the back empty bed... This has traction issues written all over!
    Combine Part A & B & C below:
    Part A)
    You need traction to move ahead.
    Traction occurs with contact between the tire and the earth.
    Weight over the tire as well as good tire tread improves traction.
    Part B)
    2WD (Off Road PreRunner) puts torque to back tires only. Open differential means if one tire has more traction, the torque will go to the OTHER tire with less traction (spins).
    A Rear Locker divides the torque equally between both back tires... both will rotate at the same speed.
    Part C)
    4WD puts torque to front tires and back tires. If '09 or newer, TRAC in H4 (high range) will limit the slip and divide the torque.
    An Off Road 4WD also has TRAC in H4... but, in addition gives you A-TRAC in L4 (low range) and a locking rear differential.
    So, will you ever be off road and want the ability to keep on moving in any condition?
  4. Dec 18, 2010 at 9:42 AM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    :D This sums it up nicely.
  5. Dec 18, 2010 at 11:41 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I saw your other post...
    If you can afford to get a 4WD, then GET THE 4WD.
    If you have any thoughts of needing 4WD, then chances are...you'll need it and regret not getting it.
  6. Dec 18, 2010 at 11:44 AM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    4WD FTW
  7. Dec 18, 2010 at 11:59 AM
    Dibblit
    Dibblit Eh?
    Paul
    Fort McMurray
    11 Tacoma
    OME suspension ARB OBA ARB locker
    4X4 is the way to go
  8. Dec 18, 2010 at 12:01 PM
    crf69
    Ohio
    ummm yeah
    with a locker in rear....even better with front locker!
  9. Dec 22, 2010 at 9:15 AM
    trdchic
    Erie CO
    I GOT MY TRUCK!!!!!!!!!!! (its 4WD)
  10. Dec 22, 2010 at 9:21 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    Congrats!!!
  11. Dec 22, 2010 at 9:32 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Nice trdchic, you'll be happy with it!!!!!
    Anyone know if you can add ATRAC to an 08 model? Basically this would add limited slip diff to the front right? I have the TRD off road model.
  12. Dec 22, 2010 at 9:53 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    The short answer is no, you can't.
    The slightly longer answer is: theoretically possible but no one knows how and it's less time, hassle and expense to add an ARB to the front.
  13. Dec 22, 2010 at 9:58 AM
    David K
    Congratulations!:D
  14. Dec 22, 2010 at 10:02 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    ^^^ what he said.... you would have to change major components of ABS - ARB a very good option - I have both and very rarely choose ATRAC over ARB! :)
    Oh yeah, Call Chase at East Coast Gear Supply - best warranty in the biz - 5 years!!! www.eastcoastgearsupply.com. Of all the suppliers I know and have dealt with, regardless of product, he is the best.
  15. Dec 22, 2010 at 10:04 AM
    David K
    A-TRAC is way more than limited slip... and it is front and rear, not just front.
    Your Off Road with the rear locker will get you most everywhere... I had an '05 and '01 Off Road. The A-TRAC is just new technology that makes the truck drive as if it had lockers on the front and rear... It requires the hydraulic brake booster, rotation sensors, and electronics that makes 'adding' it like an after-market product pretty much out of the question. Just look forward to having it when you are ready for a new truck.
  16. Dec 22, 2010 at 10:24 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Thanks guys, appreciate it!
  17. Dec 22, 2010 at 10:30 AM
    HBMurphy
    Paul
    So California Coast
    None
    Regarding my comments about East Coast Gear Supply:
    I don't do it 'cause he looks good.
    I don't do it 'cause he's done anything for me that he wouldn't do for any other customer.
    And I know a couple of his customers that have not been good to him - and he still will help those guys and stand behind that warranty and the products he sells.
    I have spent years as a VP of an supplier of auto and truck parts and have been exposed to many guys in this 'supply chain' (as they call it) and he is by far the best supplier I have dealt with. I've dealt with many Class 8 (tractors) and all the big 3 (and Nissan) manufactures, dealers, after market, etc. so in my book his efforts have earned him my highest respect!
    Oh yeah, I don't get a anything for my bloviating about him and wouldn't expect it. I know there are some folks on here that blather on about one supplier or another while they get sharp discounts or freebies (not knocking them - it just influences peoples decisions - that's not the case with me and ECGS).
    :end rant:
  18. Dec 22, 2010 at 1:18 PM
    HBMurphy
    Paul
    So California Coast
    None
  19. Dec 22, 2010 at 1:27 PM
    HBMurphy
    Paul
    So California Coast
    None
  20. Dec 22, 2010 at 1:31 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Congrats! Pics?
