4wd won’t engage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rickytacoma01, Apr 25, 2020.
  1. Apr 25, 2020 at 9:56 AM
    rickytacoma01
    rickytacoma01 [OP] New Member
    I have a 2008 Tacoma 4wd standard 6 speed V6 4.0.
    Can’t get the 4 wheel to engage when I flip the switch, the light just blinks.
    When I try 4 low, flashes and beeps.
    I can get it to engage once in a blue moon while I’m driving but other than that it just doesn’t want to do it.
    I replaced the front actuator and transmission speed sensor. All fuses are good. Vacuum lines seem okay. Switch seems to be working, as I hear a noise every time I flip it.
    The front actuator isn’t working anymore, which again is a brand new part.
    I tried disconnecting the battery and reconnecting.
    Been troubleshooting this for months. What am I missing? Losing my mind here lol
    Bikinaz likes this.
  2. Apr 25, 2020 at 10:03 AM
    Bikinaz
    Bikinaz It wasn't me!
    Hey You!
    Phoenix, AZ
    2014 Regular Cab 4x4 5MT
    Pelfreybuilt Skids. ModCo wheels. Sliders. Cruise Control. Intermittent Wipers. Fog Lights.
    I don't know if this will help, but I had the same problem until I started smashing the clutch pedal as far as I could into the floorboard. Seems to work for me.
    Oh and welcome to TW.
  3. Apr 25, 2020 at 10:07 AM
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Is 4-hi not engaging?
    As another guy said, 4-lo requires the clutch to be ALL the way in.
  4. Apr 25, 2020 at 12:48 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Have you looked at the Transfer case actuator?
    The tend to get corrosion on the electric motor terminals.
    Sometimes you can repair them, other times it too damaged to be repaired.
  5. Apr 25, 2020 at 1:16 PM
    avw4x4
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    If neither 4-hi or lo are working it’s likely a dead actuator. Not sure what would cause only 1 range.
    Put the truck on jack stands and pop it into 4wd. If the front driveshaft spins but the front wheels don’t it’s the ADD actuator, if the front driveshaft doesn’t spin it’s the T-Case actuator.
    winkel likes this.
