4wd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Secondchildhood, Oct 25, 2009.
  1. Oct 25, 2009 at 7:33 AM
    Secondchildhood
    Secondchildhood [OP] Member
    2010 Tacoma
    I have a 2010 Tacoma. I have never driven a 4wd where you hit a switch to get into 4 WD High. . The book says that you must be driving to go into 4WD High. (Yet to get into 4WD Low it says you must be stopped in neutral.)
    My question: If I come out of my house and discover an 8 inch overnight snowfall do I have to attempt to drive the truck before putting it into 4WD High, or can I start the truck and just push the switch?
  2. Oct 25, 2009 at 7:36 AM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    I just put the my truck in Neutral and then flip the switch on for 4H. You'll be fine not driving and then switching it on.
  3. Oct 25, 2009 at 8:43 AM
    mpgnc64
    mpgnc64 Well-Known Member
    Mike and Denise
    Western NC
    06 4x4 Access cab 4cyl 5spd, 2000 Prerunner
    Tool box, Thule rack, rod holders, 5100s at 1.75 and the TSB
    I turn mine on stopped, sometimes it blinks sometimes it goes right in.
  4. Oct 25, 2009 at 9:18 AM
    Terrier
    Terrier Well-Known Member
    2008 SR5 Access Cab 4x4 2.7
    Mine also blinks sometimes and goes right in sometimes; however, more often it blinks rather than going right in if I am stopped. I wish it was like the old fashioned manual locking hub type with the floor shifter that I knew went in as soon as I shifted the 4x4 shifter.
    P.S. On the other hand, the more I think about it, I don't think mine goes into 4wd high until I put it in gear and let out the clutch, if I am at a complete stop. If I do it this way, I am very careful to make sure not to spin my tires when I take off. I don't do it that way very often. I am usually in gear and moving when I put it in 4 high.
  5. Oct 25, 2009 at 10:28 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Its not a waste of time, what these other guys are saying is that you don't have to be moving to push the button, it all depends on whether or not the gears are lined up. moving makes the gears line up faster. and the manual stating that you must be moving is for that reason. all you need is to take your foot off the brake and move about a foot. In other words, you can engage 4h whether you are moving or not, just sometimes you may need to roll forward a bit to get it to engage. but the 4L you must stop.
  6. Oct 25, 2009 at 10:42 AM
    Coreyjon
    Coreyjon Northern Alliance: Airlift Div
    Upstate, Ny
    08 DCab 4X4 SR5 TRD Sport
    iPod Adapter, Bilstein 5100's @ 1.75" front, Wheelers 3-leaf 1.5" + overload rear (2"), custom carrier bearing drop spacers.
    If you took apart the system the way it is designed teeth on a gear have to line up, when stopped, if you engage 4Hi the light blinks telling you it has sent the shift motor the signal, is trying to engage the gear, but the gear has not be fully engaged - the light goes steady when the gear is engaged. not sure if this is based on actual gear position, or feedback from the motor shaft position (shaft encoder, or hall effect sensor for the gear). Either way the manual says it is safe to engage 4Hi safely while moving and at a fairly high rate of speed. It hurts nothing to attempt to engage it while stopped if the situation you are in dictates that action. 4Lo is different, the way the gearing works if you were able to actually engage 4Lo while in motion, that would be bad juju and you would quickly find the weak link in your drive train. However sometimes when you click into 4 lo while stopped the light may blink, sometimes it may be necessary to "rock" the truck a smidgen forward or backward to let the teeth engage each other.
  7. Oct 25, 2009 at 1:57 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    So, whats best in this scenario... Say you get completely stuck in snow while in 2WD and can't move due to wheel spin...no traction. If your try to get into 4WD while stopped and get nothing but a blinking light...what do you do? I suppose hitting the VSC button to turn off the traction control to enable auto LSD is an option, but if that doesn't work, is there any other alternatives?
  8. Oct 25, 2009 at 2:34 PM
    Coreyjon
    Upstate, Ny
    If your wheels are spinning, then the drive shaft is turning, if the drive shaft is turning, so are the intermediate shafts and gears inside the transfer case, if they are turning, and the shift motor is putting pressure on the gear to slip it in place, and everything in the universe aligns, then the gear will find its happy place and you will find your self in 4wd.
    now if for some reason you are stuck, in 2wd, and you can not get either tire (left rear,right rear) to spin, you would probably stall your engine if you wern't quick with the clutch. At this point, depending on how much of an emergency you are in, you could either get someone to pull you out, use the winch (if installed), or last ditch, disconnect the rear drive shaft, reattempt to engage 4wd and pull your self out that way (here is were a front locker might become useful)
  9. Oct 25, 2009 at 2:41 PM
    Cuseman18
    Cuseman18 Member
    Scott
    New York
    09 Access 5spd
    K&N Filter, Scan Gauge ll, Removed secondary filter, Running on 89 octane
    4 high I dont stop. If you have a manual transmission and the light blinks, sometimes its because the clutch is not pressed in all the way.
  10. Oct 25, 2009 at 2:59 PM
    GTVAPSAMTIK
    GTVAPSAMTIK Well-Known Member
    SOHAIL
    Fort Carson, CO
    2010 TRD OFF-ROAD 4X4 Automatic
    EXTANG Tuff WeatherTech Liners Toyota Bed Mat Coverkind Seat Covers
    True, I noticed when I switch from 2WD to 4H while moving it locks in really quick. Switching while stopped takes a while for it to lock into 4H.
  11. Oct 25, 2009 at 4:10 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    it will go into 4hi from a stop fine. if the light is blinking just put it in gear and letting off the brake is usually more than enough. If it still is blinking, put it in reverse and let off the brake. It just needs to get the gears aligned to engage. Put your truck into 4hi / 4low once a month to keep everything working, plus then you will know exactly how it works
  12. Oct 25, 2009 at 5:33 PM
    mpgnc64
    Mike and Denise
    Western NC
    If I was worried about waking up in a foot of snow in the driveway, I would just put it in 4HI just before I parked for the night. That way your covered and if it didnt snow just take it out of 4x4.
