4wheel drive electrical issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Burtini18, Apr 22, 2022.
  1. Apr 22, 2022 at 8:55 AM
    Burtini18
    Burtini18 [OP] New Member
    Heidi
    I'm having an electrical issue that is driving me mad. First of all I have an 09 reg cab, 5spd, 4x4. My truck is stuck in 4wd and will not switch out. The fuse under the small tray that flips out calls for a 25 and constantly pops when I turn the key on. I replaced the 4wd switch and it keeps popping thus not allowing the switch to work and engage it back to 2wd please help
  2. Apr 22, 2022 at 10:07 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds like you have something shorted to ground in the 4wd system, likely a wire or one of the actuators.
    I'd start with a visual inspection of the wiring, if I didn't see anything there I'd unplug the actuators one at a time and see if the fuse still blows.
    Whatever you do don't put a higher amp fuse in it.
    Alot of info about the system in the thread below.
    https://www.tacomaworld.com/threads/4wd-system-operation-help-thread.742420/
    TnShooter likes this.
  3. Apr 22, 2022 at 10:16 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Go unplug the actuator motor, engage the switch and see if the fuse pops. If it doesn't, your actuator motor is internally grounded and has failed. If it does pop, you need to go find the wiring short.
