4wheeler ramps?
Discussion in 'All Terrain Vehicles' started by Zombie Runner, Jul 20, 2010.
  1. Jul 20, 2010 at 10:52 AM
    Zombie Runner
    Zombie Runner [OP] Are these black helicopters for me?
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    what kind of ramps do yall use that have lifted trucks? Im getting a 2wd quad tonight and wonding if the 2wd quads will go up the standard ramps just fine. Im afraid of it trying to flip over. Ive always owned a 4x4 quad and never worried about it.
  2. Jul 20, 2010 at 10:55 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    i have 2 8ft folding ramps.i had a 2002 grizzly 660/1989 banshee with a 2000 dodge ram 4" lift and 35s. shit worked great. the banshee could stand on its ass behind truck,flip it foward on the tailgate and lift the rear up and roll it in.
  3. Jul 20, 2010 at 10:57 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    You'd have to have a pretty high tailgate or some short ramps for a quad to flip over on you. I've always used 2x12's with the aluminum ends you can buy at Home Depot. I think they're 8' long (I used them for a motorcycle, low ground clearance). I just upgraded to aluminum folding ramps, not as long but they have the bend about 2/3 of the way up to help the clearance issue. You could always find a ditch to back into or a curb to help the angle out a bit but with a quad I think you'd be fine.
  4. Jul 20, 2010 at 11:00 AM
    tbturner47
    tbturner47 Well-Known Member
    Travis
    Lenoir, NC
    '07 Indigo Ink Off Road
    Supercharger
    I welded up my own ramps:cool:
  5. Jul 20, 2010 at 11:23 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    I have the bifold aluminum ramps. You can use them together or take them apart. I take them apart because my trx700 is pretty wide, around 4'. Mine have the straps that I hook to the rear d-rings in order to keep them in place. I think they are made by a company called quad boss. They are 6' long and 4' wide when used together or you can separate and have two 2'x6' ramps. I always try and back up to a little hill or something. It makes it easier. Mine will wheelie when tryin to go up the ramps! So I understand you being worried about it flipping over on you. I usually put my left foot on the left nerf and my knee on the seat kinda in a standing position in case it does flip I can bail off the side!
  6. Jul 20, 2010 at 11:33 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    great info, thanks. this is what I was looking for. and kneeling on the seat in case of a flip is a good idea too! at the lake there is a ditch I can back into to make it pretty level to load. at the house its pretty much flat ground. I'll make sure and get ramps that have straps to keep them from slipping out
  7. Jul 20, 2010 at 11:38 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
  8. Jul 20, 2010 at 11:47 AM
    TacoSupreem
    Hayden
    Kentucky
    Yeah if you get a bi-fold make sure it's wide enough or can be taken apart. The straps on the ramps are a must! If your front tires are up on the bed and your rear tires pull the ramps off the tailgate it could be bad. :eek:
  9. Jul 20, 2010 at 11:56 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    those look legit. there is a harbor freight 2 blocks from my house. Ill check them out
  10. Jul 20, 2010 at 12:08 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    Ive got a 20% off cupon in my guns and ammo magazine Ill take with me ;)
