4WL question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jim1946, Feb 15, 2021.
  1. Feb 15, 2021 at 9:46 AM
    Jim1946
    Jim1946 [OP] 2020 TRD Sport 4X4
    San Francisco Bay Area
    2020 TRD Sport 4X4
    It’s been unused for months. The manual says run it 10 miles per month in 4WD.
  2. Feb 15, 2021 at 9:48 AM
    Uscgamecock7
    Uscgamecock7 Well-Known Member
    Nick
    West Columbia, SC
    2015 Tacoma Trd Sport DCLB 4x4(SOLD) 2017 Tacoma Trd OR 4x4(SOLD) 2024 T4R TRD PRO
    Mine clunks coming in and out of 4Lo sometimes..... its normal. Not all shifts coming out of 4wd are going to be silent. Can def hear the transfer case disengaging that front diff. Nothing to be worried about
    Sharpish and tacoman45 like this.
  3. Feb 15, 2021 at 9:51 AM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    I use the manuel mode and put it in first . What are you using 4Lo for ? I only use it when stuck or going to pull someone out that is stuck or to pull a bush out of the ground . You can also lock it in if the road is really bad and you have to go slow .
  4. Feb 15, 2021 at 9:56 AM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Is it cold where you are? If so that's probably why.
  5. Feb 15, 2021 at 9:58 AM
    530Taco
    530Taco Gone fishin'
    Adam
    Old Hangtown, CA
    '21 DCSB OR MT Cement
    I use 4lo all the time around my house, one way to the main road is a very rutted series of water bars, 4hi is too fast for the bumps, but after the bumps I leave in 4lo for the rest of the dirt/mud trail to the main road. It's maybe 3/4 of a mile, and I'll hit 5-6th gear (MT) cruising in 4lo around 20-25 mph. Did the exact same with thing 3 different 2nd gens, never had any 4wd issues in any of them.
  6. Feb 15, 2021 at 10:09 AM
    Jim1946
    2020 TRD Sport 4X4
    55 degrees today and wet.
    stevesnj[QUOTED] likes this.
  7. Feb 15, 2021 at 10:10 AM
    pltommyo
    pltommyo Well-Known Member
    Tom
    2016 Gray Tacoma TRD Offroad
    SSO hybrid bumper, Warn winch, RCI skid trilogy, RRW sliders, everything in the cheap/free mods thread, and of course the frame recall work.
    I can get 4th gear in 4LO, but it screams loud at 35MPH. Can't be good for it. 15 to 20MPH is my top safe speed I target in 4LO; faster than that means you should be in 4HI.
    tacoman45 likes this.
  8. Feb 15, 2021 at 10:10 AM
    Jim1946
    2020 TRD Sport 4X4
    I was just putting it into 4L and 4H to exercise it as I haven’t used it for months.
  9. Feb 15, 2021 at 10:12 AM
    stevesnj
    The actuator lube is a little stiff. Actuate it once a week until it goes away then once every month or two.
  10. Feb 15, 2021 at 10:14 AM
    Jim1946
    2020 TRD Sport 4X4
  11. Feb 15, 2021 at 10:18 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Are u shifting it properly. First you need to be in 4h to go into 4 low and stopped completely on a manual transmission u need to be in neutral also.
    The hammer likes this.
  12. Feb 15, 2021 at 10:19 AM
    Jim1946
    2020 TRD Sport 4X4
    Yes. Stopped, neutral, 4H to 4L.
  13. Feb 15, 2021 at 10:28 AM
    GOTSAND?18
    stock
    Hmm ...Mine doesn’t make any clunky noise .If this was the first time u used it will make a clunk . After that it should be smooth as butter . If you are still getting noise I would take to dealer ASAP and have them check everything. Best of luck .
  14. Feb 15, 2021 at 10:40 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    It doesn't hurt, in fact will help, if you're rolling slightly to engage 4lo. If you're at a dead stop there is a chance the gears aren't lined up so they will mesh and engage. If the wheels are turning slowly the gears will engage when everything lines up. Which is only a very slight rotation of the wheels.
    I find it easier to go to 4hi while moving then come to a complete stop, but prefer to find a spot on an incline. Shift the transmission to neutral then move the selector to 4lo. If it doesn't engage right away simply taking my foot off the brake and allowing the truck to roll a few inches will align the gears so they will mesh.
    If stopped in a spot where the truck cannot roll, and if the gears aren't aligned properly then the gears won't fully engage until you shift it back into gear. When that happens the shift will make an audible clunking sound as the gears mesh. Shouldn't hurt a thing and if it hasn't happened to you yet then you've just been lucky.
  15. Feb 15, 2021 at 10:48 AM
    #35
    CRSTRD
    CRSTRD Well-Known Member
    2020 Tacoma TRD Off Road
    I use 4LO quite a bit as I always seem to have "honeydo" projects around the house. Very good for driving on grass where you don't want to spin the tires. And yes, there is sometimes a "clunk" when things engage or disengage....not a big deal.
  16. Feb 15, 2021 at 10:50 AM
    #36
    Jim1946
    2020 TRD Sport 4X4
    Thanks everyone. I appreciate all the input.
  17. Feb 15, 2021 at 12:56 PM
    #37
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    MT here. I rarely use 4L, when I do I find second gear to work really well for me in most situations. If I’m in 4L in First gear it’s because I’m in a really tough situation or descending a very steep, rutted off-road trail. For most of my uses I find 4HI to be sufficient.
  18. Feb 15, 2021 at 12:58 PM
    #38
    Kev250R
    Kevin
    Orange, So.Cal.
    That’s true for most 4wd vehicles. I find it gives me a handy excuse to go play once a month! :p
    Jim1946[QUOTED][OP] likes this.
  19. Feb 15, 2021 at 1:15 PM
    #39
    Burqueboy505
    Burqueboy505 Well-Known Member
    Albuquerque, NM
    2019 Cement OR DCSB
    Totally normal for upshifting in low range
    Kev250R likes this.
