4x conversion to single cab 02 2.4L 2wd
Discussion in '1st Gen. Tacomas (1995-2004)' started by SimiGuy, May 11, 2010.
  1. May 11, 2010 at 5:56 PM
    SimiGuy
    SimiGuy [OP] Active Member
    Joel
    Simi Valley
    02 Tacoma Single Cab 2.4L
    6" adjustable coilover lift add-a-leaf black unique rims BFG AT KO's 410 rear end 2 10" subs xm radio alpine head unit and amps painted front bumper half a$$ intake
    This is my tacoma... Its a 2002 2.4L auto with 44K miles on it. I love my truck but I WANT 4x4.
    Is this even possible to do a 4x4 conversin with this truck?
    Should I just bassicaly find a V6 taco 4x4 and swap out the entire front end including motor????
    Is it possible to do a solid axle. Does my truck have to be a 4x4 originally to do a solid axle?
    Would a v6 go into my truck with just motor mount fabricating? If so which is the better choice 3.0 or 3.4L...
    Is there anyone that has done this to their trucks?
    Ive have seen 4x conversions on 2.7L extended cab tacos before but I have never had the chance to ask how, where, and how much they did it for.
  2. May 11, 2010 at 6:53 PM
    Barnone
    Barnone Guest
    Old fart here sells to sell it and buy a 4x4.
    Nice truck with low miles by the way, hate to see it messed up.
  3. May 11, 2010 at 7:05 PM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    Much better off to sell the truck and buy a 4x4. If you want to do a SAS then a 2x4 is good to start with but it is alot of work and pritty expencive.
  4. May 11, 2010 at 7:07 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    First off, the 2.4l is standard in the 4x2(in regards to first gens). The 2.7l is standard in the 4x4. So the 2.7 "conversions" were actually stock 4x4(unless you are referring to the pre's).
    Second, the five lug suspension is different from the 6 lug. So there is a lot more work involved to convert the 5 lug to a 4x4. I am not going to say it is impossible, but easier and faster to just purchase a 4x4
  5. May 11, 2010 at 7:54 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    go long travel, you can do the 4x4 stuff, you just have to hit on the gas a lil harder ha ha
  6. May 11, 2010 at 8:10 PM
    SimiGuy
    Joel
    Simi Valley
    Well I was thinking a conversion is ALOT cheaper then buyin a whole new truck... Considering a decent truck my year in 4x4 is over 7K. And buying used parts and finding deals I could get away with 1-2K build probably cheaper if i part and sell my lift kit. And do the install myself... with some help lol.
    And what is the differene between a 2.7 and 2.4L? In my Haynes repair book they are pretty much the same exact thing. Execpt for the power band the motor is almost exact.
    And since 5 lug suspension is different from what I noticed is that the cross members would need to be changed, and if I wanted to stay with independent suspension I would have to the weld on a 6 lug shock mounting bracket to match the 3 bolt patterns they have.
    So I would basically have to find my size truck in a 4x4 and take the entire front end off and drop it into my truck... and if I use 2.7L and keep my motor on the side I should be able to keep the same motor mount placements... I think lol.
  7. May 11, 2010 at 8:14 PM
    McJosh
    McJosh avidoffroad.com
    Josh
    Chandler
    2005 Reg. Cab 5 lug Tacoma
    Pioneer AVH-p2300DVD, 12" Memphis sub and Alpine MRP-M650 amp, 32" BFG AT tires and KMC wheels, tinted windows, satoshi grille w/ stainless steel mesh, Avid front & rear tube bumpers, Cobra wx75 CB with 3' firestik, GaragePro bucket seats, FlowMaster 40 series, aFe CAI, Black head lights, LoJack and Autopage alarm installed, Avid sliders.
    you could sell me your tires. :p
  8. May 11, 2010 at 8:19 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    The difference between the 2.7 and 2.4 is the compression ratio. Also, the 2.7 has balance shafts where the 2.4 does not.
  9. May 11, 2010 at 8:24 PM
    SimiGuy
    Joel
    Simi Valley
    lmao 300 bucks bro 80% tread on them left...
    balance shaft??? :confused:
  10. May 11, 2010 at 8:27 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Yes, balance shafts. They are in the block and are driven by the timing chain. They are equivalent to a harmonic balancer basically.
  11. May 11, 2010 at 8:31 PM
    McJosh
    Josh
    Chandler
    what size are they? I may just be interested.
  12. May 11, 2010 at 8:38 PM
    SimiGuy
    Joel
    Simi Valley
    30x9.50R15 :D:D:D
    I bought them for 145.00 each
  13. May 11, 2010 at 8:53 PM
    SimiGuy
    Joel
    Simi Valley
    Does anyone know what kind of tansfer case I would need to install a solid axle?
  14. May 11, 2010 at 10:47 PM
    McJosh
    Josh
    Chandler
    ok cool, same as mine. Wheels too?lol
  15. May 12, 2010 at 6:32 AM
    Barnone
    Barnone Guest
    Hate to be a kill joy but...
    So sell your nice truck for $5k+ (that's what I would pay) and buy a 4x4 for $7k+.
    No way you can do the conversion for $2k. If you do the conversion you will end up with a bastardized vehicle with little value and lots of headaches..
  16. May 12, 2010 at 7:02 PM
    SimiGuy
    Joel
    Simi Valley
    I agree Barnone, my truck is already a frankenstein as it is. Prerunner front fenders no rear bumper, radio doesnt even work. Half ass intake and no spare tire and jack.
    Its either 4x4 or back to stock. Maybe a simple fabtech lift shock and spring...
    idk I'm so undecided :confused: but something has to happen the front lift I have now is wasted and is not worth it to me to rebuild the shocks to my donahoe adjustable coilovers.
    If I could do the 4x conversion for under 2K in parts ill do it. But thats not being to realistic. I think this build will only happen when I get more funding time and more research. Maybe even another truck.
    And no the rims are not included lol ill pm you bro.
