4x Low Range Beeper Won't Shut-up!
Discussion in 'Off-Roading & Trails' started by MemphisSlim, Dec 25, 2011.
  1. Dec 25, 2011 at 7:47 PM
    MemphisSlim
    MemphisSlim [OP] Member
    2004 Tacoma 4x4
    A bit of help needed. I've found that while in 4x low range my 2011 Taco has a warning beeper that's annoying as hell. I asked the dealer to turn off or disconnect but they say they can't/won't. I'll be spending quite a bit of time in 'sugar sand' in Florida in the near future and find it easiest (especially on the clutch) to just run in low range.
    How do I make the noise go away???
    Thanks....
  2. Dec 25, 2011 at 7:49 PM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    It's not properly engaged. Go to 4Hi, stop, shift to neutral, and then engage 4lo.
  3. Dec 25, 2011 at 7:51 PM
    SCFirefighter
    Stephan
    Cary, NC
    Yeah I missed the clutch reference there and assumed Auto.
  4. Dec 25, 2011 at 7:52 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    DK ATRAC plug in....5,4,3,2,1
  5. Dec 25, 2011 at 7:58 PM
    MonkeyProof
    SoCal- SGV
    you have noticed that as well, so it's just not me :cool:
  6. Dec 25, 2011 at 7:59 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    I had mine translated.
    It says, "I'm not in. I'm not in. I'm not in."
    The after three times it starts saying, "Hey dummy, I'm not engaged! Hey dummy, I'm not engaged! Hey dummy, I'm not engaged!"
    Then after that it's too foul to repeat.
    :p
  7. Dec 25, 2011 at 8:04 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    this, especially in a low power truck in sand.
  8. Dec 25, 2011 at 8:06 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    So your saying a manual transmission plus 4wd sucks butt
  9. Dec 25, 2011 at 8:07 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    not with 4lo:D
  10. Dec 26, 2011 at 7:36 AM
    MemphisSlim
    2004 Tacoma 4x4
    Thanks ... seems to have been operator error. "read the manual" ... what a concept! Do you think that'd work with this damned computer? I usually just hit it with a hammer when it doesn't do what I want:rimshot:
    I way prefer the old stick on the floor to this switch on the dash ....
    PS re. the why 4 low ... as noted in the OP, deep dry super fine sand. Taking off in 4 hi is a good way to burn up the clutch.
  11. Dec 26, 2011 at 7:48 AM
    MonkeyProof
    SoCal- SGV
    That's because you're always at the mall
  12. Dec 26, 2011 at 9:59 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    FIRST: You must be in N (Neutral) not P (Park) when you go into or out of Low Range... otherwise it will beep alerting you that you are NOT in L4! If you are a manual tramsmission, then the clutch must be fully depressed.
    In sand, you need to FLOAT and not DIG IN.
    To float, you usually need to let air out of your tires... 10-15 psi is typical for very soft sand. Mud tires or 3 ply sidewall tires need more air removed to float than AT or street tires.
    To not dig in, you should be in HIGH RANGE, as low has too much low end torque and you will spin your tires and bury yourself.... deflating will help stop this.
    With the tires floating, you can drive over sand in 4WD High just fine.
    IF you do get stuck because you failed to do the above steps, then A-TRAC can drive you out of the stuck, since it is true 4WD and not just one tire in front and one in the rear spinning/ digging you in.
    There is a video of an FJ in 'sugar sand' at full pressure... but not getting stuck because he is using A-TRAC and all 4 tires are spinning together... powering him through... Letting air out would have made it easier, but he was testing the system at 32 psi.
    http://www.youtube.com/watch?v=_VHxslTiQug&feature=player_embedded
  13. Dec 26, 2011 at 10:10 AM
    MonkeyProof
    SoCal- SGV
  14. Dec 26, 2011 at 10:25 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Called it^
  15. Dec 26, 2011 at 10:27 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    op has a manual
  16. Dec 26, 2011 at 4:07 PM
    Gabex35
    Gabex35 Well-Known Member
    Gabe
    San Diego
    2020 Tundra Limited 4x4 Crewmax
  17. Dec 26, 2011 at 5:20 PM
    David K
    Obviously not! :rolleyes:
    Plus, the manual falls WAY short on details... Otherwise, there wouldn't be a need for half of the posts here on TW!! LOL
  18. Dec 26, 2011 at 5:24 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    Damnit! Dk is not blocked on the new iPad.
    :facepalm:
    Is now....
  19. Dec 26, 2011 at 5:26 PM
    David K
    You didn't read ALL of the post???:confused:
    He wanted to be in L4 for sand driving!:cool:
    So, I not only reminded him how to get into L4 (without a beeper).. but went one more step and informed him how to better drive in sand (or at least try it the way we on the west coast have for 50 years).:)
    You know, provide all the help he needs, or will need... just in case... Also, he isn't the ONLY person reading our answers... Ever think of that?:rolleyes:
  20. Dec 26, 2011 at 9:12 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    manual transmission
