4x Oil Pan Swap
Discussion in 'X-Runners' started by sf.larry, Mar 18, 2021.
  1. Mar 18, 2021 at 8:48 AM
    sf.larry
    sf.larry [OP] Well-Known Member
    larry
    2011 XR
    Thinking about swapping to the 4x oil pan on my 2011 this summer. Part numbers and advice are welcome! Thanks
    JohnGabriel likes this.
  2. Apr 3, 2021 at 9:15 PM
    JohnGabriel
    JohnGabriel Well-Known Member
    2005 x runner
    Hurst shifter and lexus isf bbk
    I am looking for the same.
  3. Apr 3, 2021 at 9:20 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    4x meaning 4x4 OEM oil pan?
    On the 2TR or 1GR?
  4. Apr 3, 2021 at 9:41 PM
    JohnGabriel
    2005 x runner
    1gr. If yo swap to the 4or oil pan you gain oil capacity and hopefully keep from cavitation in the pan.
  5. Apr 3, 2021 at 9:59 PM
    Key-Rei
    Key
    Florida
    Would have figured the 4x4 pan had less capacity given it's made in such a way to clear the front differential which isn't in the way on
    a 4x2.
    Cavitation should only be an issue if you're over filling unless I misunderstand what you're referring to.
  6. Apr 4, 2021 at 3:01 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Here is a good post on the differences. You’ll need to hammer the cross member in some.
    Be aware that there is an upper and lower pan. You’ll need both.
    Part of the oil pick up tube is in the upper pan.
    You’ll need the pans from a 4WD truck.
    https://www.tacomaworld.com/threads/1grfe-dry-sump-system.328150/#post-8633954
    https://www.tacomaworld.com/threads/blown-engine.557277/#post-18187524
    Unfortunately, @Coupe stopped making the spacer kit w/baffle.
    https://www.tacomaworld.com/threads/x-runner-oil-pan-spacer-fs.412286/
    Here is another discussion on the topic.
    https://www.tacomaworld.com/threads/engine-difference-between-x-runner-and-non-x-runner.663279/
  7. Apr 4, 2021 at 6:54 AM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    I could be persuaded to make another run of spacers, but I would need at least 5 people that wanted them.
    TnShooter and JohnGabriel like this.
  8. Apr 4, 2021 at 10:17 AM
    JohnGabriel
    2005 x runner
    I'm interested. Seems easier to do that than the whole pan and upper pan.
  9. Apr 4, 2021 at 2:42 PM
    sf.larry
    larry
    2011 XR
    I’m interested too but it’s gonna be hard to get 5 bc this is really only for the XR guys
  10. Apr 4, 2021 at 6:24 PM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    That is 2 out of 5.
    TnShooter likes this.
  11. Apr 4, 2021 at 6:31 PM
    TnShooter
    Deogee
    STOCK
    If it were me, and I owned an XRunner.
    I’d probably got to some other forums and get the word out about a possible “group/batch buy”
    That way, the odds are better you get this to happen.
    That is if, I were serious about getting one.
    Not directing this to you Coupe.
    I’m referring to the buyer(s)
  12. Apr 8, 2021 at 11:01 AM
    Sxorch
    Sxorch Member
    Thomas
    2005 Tacoma X-Runner
    Long tube header, AFE CAI,
    Question being, how much? Still around $200?
  13. Apr 8, 2021 at 11:34 AM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    The last batch I made was in the summer of 2018.
    I charged:
    $300 for non baffled spacers with all hardware, shipped.
    $450 for baffled spacers with all hardware, shipped.
    I asked for a $100 deposit and it would take about 8 weeks before I shipped( I might be able to do it in 6 weeks in 2021). In 2018 I asked for ten (10) buyers. This time I am only asking for five (5). I will do them at the same prices listed in 2018.
    When we get five (5) people that want them, I will ask for a deposit, then I will start machining them.
    Unbaffled spacer with extended black for oil pick up.
    Oil pan spacer with baffle.
  14. Apr 8, 2021 at 12:13 PM
    Sxorch
    Sxorch Member
    Thomas
    I'm in for one.
  15. Apr 8, 2021 at 1:05 PM
    JohnGabriel
    2005 x runner
    I'd be in for 1 too. Trying to decide if I want a baffle or not.
  16. Apr 8, 2021 at 1:33 PM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
  17. May 24, 2022 at 1:22 PM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    I have a couple of these oil pan spacers left for X-Runners.
  18. Nov 1, 2022 at 2:56 PM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
