4x2 Different Size Front & Back Tires
Discussion in 'Wheels & Tires' started by TN Cattleman, May 14, 2013.
  1. May 14, 2013 at 7:38 AM
    TN Cattleman
    TN Cattleman [OP] New Member
    Does anyone know of any issues such as throwing codes while running the stock 215/70r15 tires on the front and replacing the rear tires with 215/75r15 all terrain tires on a 4x2 Tacoma. It would be about .8'' larger diameter tires on the rear. Wanted to ask before trying it.
  2. May 14, 2013 at 7:48 AM
    rickmeseke
    rickmeseke subaru of america
    Ricky
    Brunswick, GA
    a white truck
    for a 2wd your fine to run larger tires in the rear.
  3. May 15, 2013 at 6:43 PM
    Headcase
    Headcase Active Member
    Mitchell
    Medina
    '10 Access Cab Manual-5 2.7L
    245 70 R 17's on Aluminum stuffed into the wheel wells
    I'm running 245 70r 17s on my 2010 access cab. Base 4 cyl. 2wd. No problems. Great consistent fuel mileage gain. Using the Odessey speedo app for a true speedo and odometer.
    Youll be fine with the tires.
    All the best.
  4. May 15, 2013 at 6:53 PM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
    It will save MPGs, you'll always rolling down hill.
  5. May 15, 2013 at 6:54 PM
    Chas of MRT
    Chas of MRT Total Automotive Performance
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    ^^^ Hahahah
  6. May 16, 2013 at 4:21 PM
    Headcase
    Mitchell
    Medina
    Naah them tires are on all 4 boys..yep
  7. May 16, 2013 at 7:01 PM
    TN Cattleman
    I guess you would be rolling down hill all the time with larger tires on the rear, lol. How big a tire that will fit the stock 15'' rims and have good clearance on a 4x2?
  8. May 17, 2013 at 4:30 AM
    Headcase
    Mitchell
    Medina
    To answer your question...suggest u go to the Tacoma world tire size calculator. You could put my tire size in 245/70r17. Then you could look up similar 15" sizing.
    On 15's with a two inch front n rear level kit you can fit 32's. Tight though.
    With no lift and no wheel spacers, mine fit fine at 30.5" diameter.
    Hope that gets you started at least
  9. May 17, 2013 at 4:45 AM
    eastcoastcowboy
    eastcoastcowboy just sittin' in the corner, havin' a beer
    Brian
    Redneckville, NB
    '15 Skewped!!
    Weathertecs, 265/70/17 Duratracs, Trifecta Tonneau
    I'm having flashbacks of my '84 Cutlass.
    Seriously though, could cause issues with your ABS and Traction Control.
  10. May 17, 2013 at 10:55 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    I also would think it cause issues with the ABS/VSC.
  11. May 18, 2013 at 9:08 AM
    TN Cattleman
    Would just .8'' larger diameter rear tires affect the ABS? Anybody actually tried it?
  12. May 18, 2013 at 10:53 AM
    Headcase
    Mitchell
    Medina
    Ive got no problems with abs/ vsc. They both work fine. No problems. No issues. Cant be scared by change. Thats what mods are about.
    .8 tire size change wont hurt. Dont let the nay sayers talk you out of something you want to do cuz they dont"think" itll work. You'll be fine.
    Im out...:cool:
  13. May 18, 2013 at 11:07 AM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    I used to run them that way on my '96 single cab Ram.
  14. Dec 13, 2013 at 7:37 AM
    topgun132
    topgun132 Active Member
    Luis
    Douglas, Az
    09 PreRunner sport package 2WD
    bilstein 5100 at 2.5" w/ 1.25 wheel spacers
    What are you driving ???
  15. Dec 14, 2013 at 3:36 AM
    Headcase
    Mitchell
    Medina
    What do you mean? What am I driving?
  16. Dec 14, 2013 at 1:01 PM
    Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    I used to do it on my first gen when I would buy used tires.
  17. Dec 14, 2013 at 2:54 PM
    topgun132
    Luis
    Douglas, Az
    Truck's setup !!!!
  18. Dec 15, 2013 at 5:10 AM
    Headcase
    Mitchell
    Medina
    Nothing except the tires and wheels. 245 70 17's on 17x7 alloys all around. Spacers were unnecessary. I have them but don't need em. The only thing I did for fit is remove the three screws holding that stupid lower fender box on so I could clear everything. No problems been running same "setup" for 3 years now.
    Hope that answers the question.
    Regards.
  19. Dec 15, 2013 at 9:58 AM
    topgun132
    Luis
    Douglas, Az
    Liff kit??
  20. Dec 16, 2013 at 4:08 AM
    Headcase
    Mitchell
    Medina
    Unnecessary to lift. Tires gave me 3 inches and better mileage. I know it sounds wierd but it changed my rear gearing ratio to the point that I cruise 55 mph highway at 1400 RPMs
