4x2 into a 4x4?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by prerunner05, Nov 13, 2009.
  1. Nov 13, 2009 at 2:36 PM
    prerunner05
    prerunner05 [OP] Well-Known Member
    David
    middlesex,va
    05 prerunnerSR5 5spd
    265/65/r17 . fog lights. secondary air filter removal,AFE Pro S dry drop in. double din navigation HU 6.5" componet speakers in the back
  2. Nov 13, 2009 at 2:40 PM
    gavonder
    gavonder She's Kickass!
    Bethel, Ct
    08 TRD Sport Access Cab
    Sunroof, Leer Cap w/ Thule rack, Factory Running Boards, Fog Light Mod, Hood Struts, Scangauge, w/homemade mirror mount, AC/Defrost mod, Rear Spring TSB, TRD Center Caps
    It's not the rear that you would need. You already have that. You would need the 4x4 front axle. But, I'm sure you would need a lot more than just that.
    GA
  3. Nov 13, 2009 at 2:42 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    Hold onto your wallet
  4. Nov 13, 2009 at 2:42 PM
    petersharp
    petersharp Well-Known Member
    Do you need to ask?! It's up there ^
    Louisville, CO
    Ex DC LB Sport owner.
    I'm a little confused, or this is a joke? How would replacing a rear axle make the car a 4 wheel drive? How about doing some work at the front end?
    There are a lot of threads on making a prerunner 4x4, and the over riding theme is - don't bother.
  5. Nov 13, 2009 at 2:44 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    It can be done, but you don't need to worry about the rear.
  6. Nov 13, 2009 at 2:45 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    lol wut
  7. Nov 13, 2009 at 2:46 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4R TRDOR Premium. ‘01 Tacoma Xtra Cab 4x4
    how bout trading in your pre-runner on a 4x4. that makes more sense
  8. Nov 13, 2009 at 2:46 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    you'll need a transfer case...wiring...a front diff...some cv axles...and the list goes on
  9. Nov 13, 2009 at 2:52 PM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Don't discourage him, give him help.
  10. Nov 13, 2009 at 2:53 PM
    outlawtacoma
    W. TN
    I did.
  11. Nov 13, 2009 at 3:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    And a shorter rear drive shaft. It can be done realativly cheap ($2000.00), and you can have a manual transfer case, as opposed to the electronic shifted one. With a doner FJ it should be a direct swap. I say an FJ, as the tranny is the same, but the transfer case is manual. aside from the ABS disconect software in the ECU for when in 4L (on some modles), it should be an easy swap.
  12. Nov 13, 2009 at 4:18 PM
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab
    If it were me, I would search for a 4x4 model, all the time effort and $$$ just don't seem worth it to me!
  13. Nov 13, 2009 at 4:20 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    HAve you looked into if theres a way to flash to ECU for that, or would you just have an ABS kill switch?
  14. Nov 13, 2009 at 4:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I havent looked to much into it, but I imagine a simple switch could be installed.
  15. Nov 13, 2009 at 4:36 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
  16. Nov 13, 2009 at 4:43 PM
    The_Dude
    The_Dude Well-Known Member
  17. Nov 13, 2009 at 4:44 PM
    Coreyjon
    Coreyjon Northern Alliance: Airlift Div
    Upstate, Ny
    08 DCab 4X4 SR5 TRD Sport
    iPod Adapter, Bilstein 5100's @ 1.75" front, Wheelers 3-leaf 1.5" + overload rear (2"), custom carrier bearing drop spacers.
    SAS with a manual transfer case would be awesome!!!! Whats a good fit up fron..a dana 40? Never looked into it. Interesting idea about the fj parts swap. wonder how much the t-case would be a direct swap or how much "work" to get that to work would be.
  18. Nov 13, 2009 at 4:53 PM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    I know the "retro" SEMA Taco used an FJ front axle, I'm not sure which model specifically though.
  19. Nov 13, 2009 at 4:53 PM
    prerunner05
    David
    middlesex,va
    you know what man yea i f***ed up o well get over it. I have always owned camaros this is my first truck. being that i never worried about 4x4 now that i got a truck and have done some mild off roading im interested in what i could do. becoming a tacoma Enthusiast i dont see the problem just looking for some advice i have $4200 left to pay on my truck and dont want to get rid of it just want ideas of what need. Thanks to most for the advice
  20. Nov 13, 2009 at 4:58 PM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    I'm with you man. :thumbsup:
    I'd rather convert than trade in. ;)
    She's my baby! :D
