4x2 Prerunner DC standard suspension - does it bottom out?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cycledrum, Jan 30, 2008.
  1. Jan 30, 2008 at 7:03 PM
    cycledrum
    cycledrum [OP] Well-Known Member
    Union City, CA
    88 4X4 Pickup xtra cab, SR5
    Ok, a friend of mine says get the TRD suspension in a Tacoma, because ...
    he has a 2005 Prerunner Access, no TRD. He put a sportbike and some other stuff, likely about 600 lbs max and claims the suspension (shocks) bottom out going over some highway bumps.
    Anyone else found this to be the case?
    I spend about all my time on pavement. I'm not going to buy TRD because the logo looks cool ... it's for off-road use.
    So, did Toyota just screw up the spring rates on the 05, or does a non-TRD come with undersprung, non adjustable suspension for its claimed 1,100 lb. abilities?
  2. Jan 30, 2008 at 7:05 PM
    cycledrum
    Union City, CA
    Ok, so things are a bit more complicated ...
    there's TRD Sport suspension, then TRD off-road setup.
  3. Jan 30, 2008 at 7:09 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    they have a tsb out there to fix the issue. the non trd trucks get trd shocks and a 4 leaf pack to hold up the bed. it also lifts the rear about 1.25"
  4. Jan 30, 2008 at 7:34 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Yeah, you should not choose the TRD because of the suspension. You can get a free upgrade to the TRD equipment and an increase in spring stiffness for free.
    The sport comes with the LSD. Offroad comes with the locker. It really depends on what you need.
