4x2 prerunner lift
Discussion in 'Suspension' started by 808JJCT808, Oct 2, 2013.
  1. Oct 2, 2013 at 10:52 AM
    808JJCT808
    808JJCT808 [OP] Member
    VA
    Prerunner13
    Im new to this so here i go........okay, so my taco aint off road, trd, or 4x4. Im just wondering if i could level out the front suspension and not really do anything with the back suspension, will that be okay as in ''No Problems'' in the later future? If so, what suspension should i get? Thanks for the sugestions!
  2. Oct 2, 2013 at 10:58 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Your truck is in fact a 6 Lug Prerunner?
  3. Oct 2, 2013 at 11:07 AM
    808JJCT808
    VA
    Prerunner13
    Yes.
  4. Oct 2, 2013 at 11:22 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Since your rig is brand new, you could run just a 1.25" spacer to level it out. Or you could run a set of new coils to provide the 1.25", or you could also upgrade the front shocks to some Bilstein 5100s which will also allow you to level out the front.
  5. Oct 2, 2013 at 12:52 PM
    808JJCT808
    VA
    Prerunner13
    Ok so you can lift the front without ruining your back suspension or anything else? I was thinking some coil overs . Will 264/75/r16 be the biggest tires size?
  6. Oct 3, 2013 at 12:04 PM
    texascolt45
    texascolt45 Well-Known Member
    mike
    groves texas
    prerunner 4 cylinder
    wheels,bilsteins,side bars
    I used bilstein 5100's on my 09 prerunner.set them as 1.75.nad I run 265/75 16 tires doesn't rub with aftermarket wheels.running a stock wheel it might rub the upper control arm maybe,not sure.
  7. Oct 4, 2013 at 6:15 AM
    808JJCT808
    VA
    Prerunner13
    You got a pic bro? How much was you bilstein 5100's?
