4x4 2023 sr5 pulling 6x12 uhaul trailer
Discussion in '3rd Gen. Tacomas (2016-2023)' started by I.E. Snapper, Jul 3, 2023.
  1. Jul 3, 2023 at 7:00 AM
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    I think it has all been covered here already but just in case...
    1. MPG's are going in the toilet. Just know that it's short term.
    2. Patience is a virtue. You are going to be freeway cholesterol. Stay right and stay slow.
    3. Drive like you play chess - think three or four moves a head.
    4. Be sure you load the tongue appropriately to avoid sway
    5. Do not over load the trailer - the space will accommodate more volume than the weight will allow.
    6. Try to load evenly left to right.
    8. ECT on. S-Mode and lock out 6th. You may have to lock out 5th too in the hills.
    9. Go down hill in the same gears you go up hill. Do not take advantage of gravity to make good time. Your brakes need to be operated with as much attention as the transmission and engine.
    10. Pay attention to the details. For example - I skipped 7 and you never noticed.
  2. Jul 3, 2023 at 7:32 AM
    woodsy
    woodsy Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    That's all you need to do.
  3. Jul 3, 2023 at 7:43 AM
    V01dnet
    V01dnet The Professor
    Kansas City
    2022 Army Green TRD Off Road
    When you’re on these forums, you’re going to get a lot of “purists” on here. The lesson you should extract is your truck can handle it just fine.
    Stevie17, auskip07 and MQQSE like this.
  4. Jul 3, 2023 at 7:47 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Was a purdy truck ... dat blue. :(
    Stevie17, Squirt[QUOTED] and wilcam47 like this.
  5. Jul 3, 2023 at 8:15 AM
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
    I know. The body and paint was almost perfect too. Probably better than the paint on my new truck :pout:
    Stevie17 and MQQSE[QUOTED] like this.
  6. Jul 3, 2023 at 8:28 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    VERY GOOD POINT!
    this trailer is big and heavy enough, that if improperly loaded, can manhandle the small Tacoma.
  7. Jul 3, 2023 at 8:38 AM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Stay to the right. Give two or three times the distance you usually do. Folks are gonna jump in front of you and you have to stay calm and back off some more. Use ECT, Sport mode. Use the lower gears for climbs and downhill. 5 or 5,500 rpm up climbs is normal. The first 10 miles you are gonna be thinking about turning around and getting a U Haul truck and towing the tacoma behind. Traffic sucks, try to gas up outside of town at the Mavericks or what ever you have to travel centers. The goal is to get there.
    Stevie17 and MQQSE like this.
  8. Jul 3, 2023 at 9:38 AM
    Amocat15
    Amocat15 Well-Known Member
    Bucks County, PA
    2021 DCSB TRD OR
    I pulled a fully loaded one of those with my 2015 2nd gen off-road to move my son into college. I put heavier stuff towards the front of the trailer and kept it out of OD on the uphill climbs in Western PA, and it did just fine. Would definitely use ECT in a 3rd Gen on the uphills. The Taco did quite well manuevering with that through Pittsburgh city streets!
  9. Jul 3, 2023 at 9:45 AM
    Vegvisir Overland
    Vegvisir Overland Well-Known Member
    Central OK
    2020 Tacoma TRD Pro Army Green
    Took the bed mat from 2nd Gen to 3rd Gen
    The computer will not let you destroy the transmission when you play around with the gear lockout aka "manual mode" in the automatic transmission. It will just Toyota Beep at you and fix your mistake.
    Stevie17 and Chew like this.
  10. Jul 3, 2023 at 10:03 AM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    Give the Taco a once over before you hit the road. Raise your tire pressure. And like others have said go easy and stay to the right. It will do just fine.
  11. Jul 3, 2023 at 10:08 AM
    AZ Pete
    AZ Pete Well-Known Member
    Arizona
    U Haul has a surge brake, no controller needed.
    GTGallop likes this.
  12. Jul 3, 2023 at 10:09 AM
    christsay
    christsay Well-Known Member
    chris
    Austin, TX / Santa Fe, NM
    2021 Army Green DCLB TRD 4x4
    JB Grand Raid Evo XXL mounted on an Alu-Cab. 5.29 gears.
    yep, under towing tips in the manual:
    • Vehicles with an automatic transmission: To maintain engine brak- ing efficiency and charging system performance when using engine braking, do not use the transmission in D. If in the S mode, the transmission shift range position must be in 5 or lower.
  13. Jul 3, 2023 at 2:01 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Don’t overthink this. Just leave the transmission in D, use ETC of you like. You have much more important things to spend your brain cycles on. Drive conservative, use your mirrors, take wide turns (watch side view mirror on all turns until you get a feel for it), plan for extra braking distance, use your turn signals, and don’t drive into tight spaces that require tight maneuvering. If you find your self in a jam, have someone spot you. Backing up a trailer takes practice.
    andthen likes this.
  14. Jul 3, 2023 at 4:43 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    u-haul trailers are hydraulic surge brakes. nothing they rent out has the connection for a brake controller.
    so the recommendation is a waste of money for this usage.
    gudujarlson likes this.
  15. Jul 3, 2023 at 5:27 PM
    #35
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Remember now...
  16. Jul 3, 2023 at 5:27 PM
    #36
    rndsommer40
    rndsommer40 Well-Known Member
    Ralph
    2022 TRD OffRd DCSB
    Plan your gas stops. I pulled the same trailer loaded 250 miles. You'll wish you had a larger gas tank but other than that ECT and a mix of S5 and S4 on steep grades and you'll be good.
  17. Jul 3, 2023 at 6:02 PM
    #37
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    While not quite as heavy at 1,240lbs empty, I had this trailer overloaded several times moving last year up and over the mountain.
    I used ECT mode and to get up and over the mountain I kept it in S3, which for those that don't know limits it in 3rd gear. This particular trailer does not have the surge brakes, but never did I feel un-easy. I used my head and let the engine do the braking for me on the mountain.
    Squirt and RustyGreen like this.
  18. Jul 3, 2023 at 6:47 PM
    #38
    soundman98
    NW Indiana
    it's a joke, but i had to do exactly that.
    home depot had a rental rep that absolutely refused to allow me to tow this 1,000 pound trailer with the tacoma. that's my dad's hastily borrowed f-150
    when i went to return it the next day i had 5 full pages of documentation printed off ready to speak to whoever i had to up to the corporate level that my tacoma could entirely pull it. i start talking to a different guy, and he just laughs, says "yeah, he's an idiot"...
  19. Jul 3, 2023 at 6:58 PM
    #39
    Mopar Mussel
    Mopar Mussel Well-Known Member
    Jurgis
    2018 TRD Sport, 2006 SAAB 9-5 Aero
    Use ECT and you’ll be just peachy. I used that same model of trailer to move to a city two hours away about a month and a half ago and it went very smoothly (shoutout to my gf for the moving help).
  20. Jul 3, 2023 at 7:03 PM
    #40
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Uhaul trailers dont have electric brakes, the large trailers like this have surge brakes which have a delay but defiantly work, so no need for a brake controller.
    I would recommend trying out the surge brakes before you load up the trailer so you get a feel for how they work.
    CaptainBart45 likes this.
